Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 09-18-2016, 03:02 PM   #41
Rich W's Avatar
I'm In , Kentucky
Take 3 on this posting. I'm having a bad day trying to post stuff. The Internet gods laugh at me.
Here's the video in MP4 format. The other one has sound but no video, it's all blurry, although the original plays on my laptop. MP4 is better, will probably play on your machine.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 09-18-2016, 03:24 PM   #42
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Still won't play on my iPhone.
All that shows is the name of the file.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-18-2016, 03:48 PM   #43
Rich W's Avatar
I'm In , Kentucky
How about this version of the .mp4 file. it says it's for the iPhone etc.
-Rich
Rich & Yvonne
Old 09-18-2016, 07:34 PM   #44
m.hony's Avatar
2013 30' Classic
I just can't figure out how to download or view it.
TAC #MS-10
Airforums #70955
Old 09-18-2016, 07:37 PM   #45
FCStreamer's Avatar
2014 30' Flying Cloud
If it's any consolation, I can't view any of them on my iOS devices either. I had to go to my laptop to see it. And that doesn't look right. Too much play.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 09-18-2016, 08:26 PM   #46
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
So I was able to watch your video. If your bars are that loose when every thing is hooked up something is not set up correctly. The amount of space between the pins and the frame and the looseness of the pin is normal. But the bars appear to have no tension on them--you should not be able to move them by hand when they are sitting on the L brackets and you are on level ground. Start by making sure the ball height is correct. If the trailer is level when sitting on the ball, you have eight washers in, and the L brackets are the correct distance from the hitch and at a height so the bars are parallel with the trailer frame when sitting in the brackets--you should not be able to rattle the bars like that because they should have a lot of tension on them! So something is not set up or assembled correctly, or possibly the bars are bent?.
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 09-18-2016, 08:56 PM   #47
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
On your video all the slack is normal. I'm assuming you are simply holding a bar loosely in your hands and moving it around. If instead its actually inserted into the hitch then something is seriously wrong with your setup. Your bars, when properly hitched should have lots of torque placed upon them such that no man could ever budge them, even if kicking. Add more washers, up to 8.
kscherzi is offline   Reply With Quote
Old 09-18-2016, 09:30 PM   #48
steverino's Avatar
2018 30' Classic
Ivins , Utah
I had problems with bending L-Pins and walking L-brackets until I implemented ROBERTSUNRUS's solution of drilling holes in the pins and installing roll pins. Ever since I applied this solution the hitch has been trouble-free for me.
See http://www.airforums.com/forums/f464...ml#post1231096
The L-pin's job is to act as a fence to keep the spring bar on the L-bracket. The problem is that the top of the L-pin usually rides on the top of the spring bar, and as the bar moves back and forth during turns, it binds, and applies forces that bends the pins and sometimes moves the brackets along the tongue. The roll pin keeps the top of the L-pin off the top of the spring bar, thus eliminating the bind.
This is exactly what Progressive's redesigned L-pin with the flip clip does.
Steve
2010 27FB
steverino is offline   Reply With Quote
Old 09-18-2016, 10:08 PM   #49
Rich W's Avatar
I'm In , Kentucky
Sorry for any confusion, I was just trying to show the play in the spring arm between the L-pin and the L-Bracket. The spring arm was just laying on the bracket, it wasn't inserted into the hitch. When hooked up I cannot move the bar at all.
I was just wanting to show that the spring arm has enough play in it to move inboard and outboard creating a loud pop or bang. I think this may be what others are experiencing and could be bending the L-pin. I have not experienced this. I have replaced the original pins with the newer ones with the spring loaded retainer. The L-bracket pads have eliminated most of the squeaking but there is still some at the spring arm socket. My rig is pretty level when loaded up. I clean the sockets and other hitch parts before each trip and check the bolts' torque.
-Rich
Rich & Yvonne
Old 09-21-2016, 05:27 PM   #50
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
When I was sent under warranty new L brackets, the pins fit much more tightly than they did in the old brackets. The result is that the pins are so tight, they push downward on the L brackets ands push them backward at the bottom. Eventually they will be far enough away the bars may fall off. Most of this movement seems to occur when backing.
I have informed the manufacturer of this problem and hope they will send me smaller pins that have enough slop in them to work properly.
Gene
Warped door on my '91 Excella mudmuffin Doors & Locks 10 12-28-2012 05:54 PM
Warped Tambour Doors McNanny Cabinets, Counter Tops & Furnishings 4 04-11-2006 07:05 PM
Warped Door? Rivetedude Doors & Locks 8 05-11-2005 03:02 PM
Warped door Baja Bound Doors & Locks 9 08-28-2003 07:42 AM
