Closed Thread
Old 09-05-2015, 06:55 PM   #281
cameront120's Avatar
1972 25' Tradewind
Originally Posted by rostam View Post
Right, I forgot the fairy dust sprinkles
That's rich. Remind us all what experience towing air streams you actually have.
North Vancouver, BC
cameront120 is offline
Old 09-05-2015, 07:55 PM   #282
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
Some questions earlier about the diesel SUV's handling downgrades. The Cayenne diesel with 27FB in tow (about 13,000lbs) will hold 65 mph in 5th on 5% downgrades. When I see the warning sign for steep downgrade, "Truckers use low gear" etc, I'll slow down if necessary then change down a few gears gradually to maintain the desired speed. No need for brakes. No drama. There is a significant amount of aero drag on the AS at this speed so the rig still stays "in tension" (I use a ProPride) even with some braking from the TV.
Engine brake required? With this combination, I'm not sure what I'd use it for, except to annoy the locals. On the other hand, if I was towing a 20000 lb trailer with a 1 ton, I'm sure I'd be glad of one, but I'm not.
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline
Old 09-05-2015, 08:26 PM   #283
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Ohiobrits, thanks for the info from experience. Probably my biggest concern about these vehicles is holding speed on the downgrades, and I feel much better about it.
We're nearing the point of reducing from three cars to two. One is a Suzuki Samarai which is our little chore runnabout. The Touareg-Cayenne-Q7 would be our tow vehicle 20% of use, and family car 80% of use.
We truly appreciate all the help getting there.
Doug and Cheryl
dkottum is offline
Old 09-05-2015, 09:21 PM   #284
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
My experience with the 3l Jeep diesel is the same as Ohiobrits. I actually can't recall using the brakes on the grades in Virginia and West Virginia. The 8 speed seems to have lots of choices for maintaining a reasonable and safe downhill speed with plenty of braking power, mostly not dropping lower than 6. About 14000 lbs GCW. My old Jeep with the Mercedes 3l Diesel was about the same, except higher rpm in a lower gear. No fuss with either of them. My guess is that the other Diesel SUVs are better. Jim
Jim Flower is offline
Old 09-05-2015, 10:17 PM   #285
Tuco's Avatar
1988 32' Excella
Ojai , California
If you have never used one you don't know what your missing. I didn't till I fixed mine. Thanks for the great info.
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 260k+ (The Beast)
Tuco is offline
Old 09-05-2015, 10:36 PM   #286
bono's Avatar
Mountain View , California
BMW X5M has different (more powerful brakes) and needs less distance to stop. I think PC Turbo has also better braking performance than "standard" PC. The point is that German SUVs have better brakes than trucks, but despite the numbers the "only truck can tow" crowd does not accept this...
Originally Posted by Knuff View Post
The standard brakes are the same unless you go carbon on the Porsche. I don't understand the whole discussion.
bono is offline
Old 09-06-2015, 09:12 AM   #287
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We still have the never lube hearings after the Kodiak calipers were installed. We installed the Titan Brake Rite II SD because of it's modular design. The electronics are a separate module from the pump. Not mentioned by the vendor at the time of purchase was that model is incompatible with ALL factory installed brake control systems.
We installed the Tuson DirecLink NE brake controller which plugs into the truck's ADP port. The system monitors all the truck's sensors to modulate the brakes. We did a simple bypass of the truck's built in brake controller so no truck computer error codes are thrown.
I would not have installed the Titan pump if I had found the Tuson system first. Their brake controller and pump when interconnected are capable of showing additional pump safety parameters on the cab display.
I will retrofit the Tuson ABS brake controller probably next year. It will still fit inside the front battery box. We will have to run four brake lines, one to each wheel, to support the ABS. One can order their basic pump which is upgradable to ABS, but the calipers and rotors have to ordered with the ABS sensor rings.
switz is offline
Old 09-06-2015, 10:12 AM   #288
Tuco's Avatar
1988 32' Excella
Ojai , California
Switz - What was the total cost of the conversion including parts and labor? Also what kind of time was need to complete this work?
Dave & MJ
Tuco is offline
Old 09-07-2015, 09:47 AM   #289
switz's Avatar
2014 31' Classic
Images: 8
The estimate on the bill was around 12 hours of labor and about $2,500 in parts which included the Titan Brake Rite II SD pump system, the two sets of 12" Kodiak Dacromet Finish rotors with stainless steel calipers plus 3/16" brake line and all the fittings.
switz is offline
Old 09-07-2015, 10:21 AM   #290
worried...happy...wo...ha
Knuff's Avatar
2015 25' FB International
Menlo Park , California
It is somehow telling that the truck crowd hijacks this SUV discussion and talks gibberish. I at least thought that the trucks came with brakes that could handle an AS, but obviously not...
Knuff is offline
Old 09-07-2015, 10:31 AM   #291
Mission , Texas
Pretty sure the "truck crowd" as you put it is actually more concerned about safe towing no matter what kind of vehicle you prefer.
The brake conversations made me curious because at least for the high end SUVs 4 wheel anti lock disc brakes are standard. On many pickups 4 wheel anti lock disc brakes are optional even though they may be tow rated.
The advantage of 4 wheel anti lock disc brakes is a shorter stopping distance, not that standard drum brakes WON'T stop the vehicle or handle the loads it is rated for.
But perhaps I'm confused.
nrgtrakr is offline
Old 09-07-2015, 10:31 AM   #292
N/A , N/A
This discussion is not about trucks vs SUVs/minivans/sedans. It's also not about body on frame vs unibody vehicles. It's about adhering or ignoring manufacture ratings. It's very simple unless you want to make it complicated.
rostam is offline
Old 09-07-2015, 10:40 AM   #293
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Uhh... the brakes being discussed in your example are the retofit of the trailers brakes, not the truck brakes and the addition of a new brake controller...
And really, this is not a competition.
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline
Old 09-07-2015, 11:22 AM   #294
1972 25' Tradewind
Here's a reminder about what the discussion is about from the very first post by the OP:
"Almost 12000 km whit my new VW Touareg Diesel and my 30 feet Airstream. It is a dream to tow."
Maybe once you've got an Airstream and actual, you know, towing experience you might understand how nicely these trailers tow even without a truck.
North Vancouver, BC
Closed Thread
VW Touareg diesel Never2late Tow Vehicles 8 06-17-2014 01:22 PM
Touareg and the Hensley question adwriter73 Tow Vehicles 3 10-25-2010 08:31 PM
touareg, bambi and weight distribution hitch ericwarren Hitches, Couplers & Balls 2 10-02-2008 09:19 PM
First road trip with Touareg and CCD... Xray Our Community 35 09-15-2004 01:06 PM
