Closed Thread
Old 09-02-2015, 08:55 PM   #211
2013 25' FB Flying Cloud
Kuna , Idaho
Originally Posted by dkottum View Post
Let's not have the debate again. Let's just learn something about Touaregs and Airstreams. Let it go guys, kindly go to a truck thread, we've heard enough of the cliche's.
Rude. The OP asking for opinions on the internet???????? Don't ask the question if you can't stand the answer............or it's not the answer you want. Geesh.
flyncloud is offline
Old 09-02-2015, 08:57 PM   #212
Mission , Texas
See that's the initial point ...
Nobody ever said no SUVs ever.
nrgtrakr is offline
Old 09-02-2015, 10:35 PM   #213
bono's Avatar
Mountain View , California
I would consider ProPride.
Originally Posted by jflipping View Post
We are going to be towing a 25 ft airstream with a 2014 toureg tdi.
Which hitch is the best??
bono is offline
Old 09-02-2015, 10:37 PM   #214
bono's Avatar
OP did not ask for opinions.
bono is offline
Old 09-03-2015, 05:27 AM   #215
N/A , N/A
Originally Posted by Tino643 View Post
... A got a new hitch is the Husky centerline. A add before the propride. A good system but heavy pricy and archaic! Whit my centerline, I don't have any sway at all!!!
OP clearly stated that ProPriode is a good system, but heavy, pricey and archaic. He is using a Husky Centerline.
And I thought the "rules" state that OP's opinion was final and not debatable in this thread.
rostam is offline
Old 09-03-2015, 09:32 AM   #216
cameront120's Avatar
1972 25' Tradewind
Bono was obviously responding to the question asked in post 218.
North Vancouver, BC
cameront120 is offline
Old 09-03-2015, 07:02 PM   #217
It's Porsh-Ah
Franswa's Avatar
Boston , Massachusetts
Since I have been closet following this thread since I posted way back when, I would ask any one with a reinforced hitch to post a picture, I am writing this only to help people understand a little about what is going on back there, I will preface this by saying that I know most manufacturers skimp on their factory tow hitches, it's one of the first upgrades if your going to tow heavy, and this is because aftermarket weight distribution, anti-sway etc put a great deal of strain on a vehicle over long distances. But out of curiosity I looked up a picture of a reinforced cayenne/taurege hutch and found the accompanying picture. This could pose a problem. Hitches are fastened to the solid unsprung frame of a full frame vehicle, or the unit body of a unit body vehicle. In the picture this reinforcement is welded (maybe can't tell) to that very beefy looking sub frame assembly that holds the rear differential and acts as the fastening points for the rear suspension. It all seems good until you know about the vehicles and understand that the hitch is solidly bolted to the body, however the reinforcement is welded to a floating sub frame assembly. The sub frames on cayenne's and nearly every other unit body vehicle are floating assembly's with rubber bushings isolating road vibration. They move, plain and simple. The body acts as the frame, the suspension is attached to the sub frames at either end. A common repair for me is to lower the sub frame and replace bent sub frame bolts after a nasty impact with a pot hole. I use a jig that lines the sub frame up with the factory assembly line holes to reposition it. The sub frames are not rigidly mounted to the body, most Porsche's are split between solid rubber mounts, and hydraulic (think silicone filled) mounts depending on whether it's a cheap V6 or a Turbo. I'm trying to say that the component being used to reinforce the hitch isn't reinforcing anything, under extreme flex, it may transmit some force to the body, but your flexing the rear of the body shell likely. The point of this is just to let people know there is more to a vehicle than what the Web says.
Sent from under the bonnet of some rich guys Porsche
Franswa is offline
Old 09-03-2015, 07:29 PM   #218
1994 34' Excella
Warren , Manitoba
Following this with interest. Have a 2009 Touareg gas, but if was a diesel would not be afraid to pull a 30' with it. Pull my 34' with a Duramax. Both vehicles weigh about the same, but the Touareg has far superior brakes. Use a Husky Centerline on the Duramax and love it. Head unit is heavy, but have pulled in some horrible winds with no problem. The combination of diesel Touareg and Husky Centerline will be a great combination. If I had a diesel in the VW would try to pull the 34!!! Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline
Old 09-03-2015, 07:35 PM   #219
N/A , N/A
Originally Posted by Franswa View Post
Since I have been closet following this thread since I posted way back when, I would ask any one with a reinforced hitch to post a picture, I am writing this only to help people understand a little about what is going on back there, I will preface this by saying that I know most manufacturers skimp on their factory tow hitches, it's one of the first upgrades if your going to tow heavy, and this is because aftermarket weight distribution, anti-sway etc put a great deal of strain on a vehicle over long distances. But out of curiosity I looked up a picture of a reinforced cayenne/taurege hutch and found the accompanying picture. This could pose a problem. Hitches are fastened to the solid unsprung frame of a full frame vehicle, or the unit body of a unit body vehicle. In the picture this reinforcement is welded (maybe can't tell) to that very beefy looking sub frame assembly that holds the rear differential and acts as the fastening points for the rear suspension. It all seems good until you know about the vehicles and understand that the hitch is solidly bolted to the body, however the reinforcement is welded to a floating sub frame assembly. The sub frames on cayenne's and nearly every other unit body vehicle are floating assembly's with rubber bushings isolating road vibration. They move, plain and simple. The body acts as the frame, the suspension is attached to the sub frames at either end. A common repair for me is to lower the sub frame and replace bent sub frame bolts after a nasty impact with a pot hole. I use a jig that lines the sub frame up with the factory assembly line holes to reposition it. The sub frames are not rigidly mounted to the body, most Porsche's are split between solid rubber mounts, and hydraulic (think silicone filled) mounts depending on whether it's a cheap V6 or a Turbo. I'm trying to say that the component being used to reinforce the hitch isn't reinforcing anything, under extreme flex, it may transmit some force to the body, but your flexing the rear of the body shell likely. The point of this is just to let people know there is more to a vehicle than what the Web says. Attachment 247230
Thanks for the informative post.
rostam is offline
Old 09-03-2015, 08:40 PM   #220
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The Touareg hitch reinforcement is working well, according to Can-Am. They have set up 210 Touaregs when I asked them about it last month, and consider it one of the top Airstream tow vehicles, second to an Audi Q7.
Doug and Cheryl
dkottum is offline
Old 09-03-2015, 08:56 PM   #221
Tuco's Avatar
1988 32' Excella
Ojai , California
I must be missing something. I keep seeing people here stating that the brakes are better on these SUV's than on a modern 3/4 ton and up diesel truck. I can see where the brakes may be better, but the braking ability is not. How can a vehicle without an exhaust brake be better than one with? I took time looking for an aftermarket exhaust brake for the smaller diesels and came up empty. If someone has a link to one I would love to check it out.
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 260k+ (The Beast)
Tuco is offline
Old 09-03-2015, 09:09 PM   #222
Palm Springs , California
Thanks for all the useful info about which hitch is best!!!!
jflipping is offline
Old 09-03-2015, 10:05 PM   #223
Mission , Texas
Touareg weighs ~5,000#, 70-0mph 177 feet
An F250 weighs - 8,500#, 70-0mph 221 feet
Stopping distance shorter, agreed.
Better brakes, do the math.
nrgtrakr is offline
Old 09-03-2015, 11:36 PM   #224
jcl
I should start by saying that I don't know the details of the Porsche unibody and subframe, but it looks pretty similar to the approach BMW use and I am familiar with those models.
The receiver starts off as a standard Porsche part, so it is already designed to handle a vertical (tongue) load, as well as fore and aft loads relating to braking and acceleration. In Europe, those fore and aft loads relate to the use of surge brakes, and so would likely be greater than in North America. The receiver may require reinforcement due to a higher static tongue load, I don't know. But the purpose of the strut isn't any of those, it is simply to counteract the rotational moment of the WD equipment. That strut in your photo will see a vertical load, and not much else. So the question becomes, can the subframe handle a vertical load of a few hundred pounds (or many hundreds, depending on the specific setup), and what degree of motion of the original hitch assembly will be permitted due to the compliant mounting of the subframe. My guess is that the vertical load won't be an issue, and the question is whether the compliant mounts allow sufficient motion of the receiver to lead to fatigue of the rear mounting location. There is at least one more issue, that of noise transmission. The compliant mounts isolate the subframe, and the attachment may lead to increased cabin noise due to the new noise transmission path. Whether or not that is an issue would be determined on first use, I would think.
All of the above is speculation, so I would look to the company that has done several hundred of these, and see what the results have been. I would personally prefer to see the strut mounted to the unibody, all things being equal, if there was an appropriate and accessible mounting location. But if there wasn't, it appears the mounting location on the rear subframe is working for some number of owners.
Jeff
jcl is offline
Closed Thread
VW Touareg diesel Never2late Tow Vehicles 8 06-17-2014 01:22 PM
Touareg and the Hensley question adwriter73 Tow Vehicles 3 10-25-2010 08:31 PM
touareg, bambi and weight distribution hitch ericwarren Hitches, Couplers & Balls 2 10-02-2008 09:19 PM
First road trip with Touareg and CCD... Xray Our Community 35 09-15-2004 01:06 PM
