Old 12-09-2015, 03:11 PM   #1
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
VW outtows one ton Duramax
Hey, don't kill the messenger...
http://youtu.be/k62gW3Se5e0
Brevi tempore!
Old 12-09-2015, 03:17 PM   #2
dznf0g's Avatar
Oswego , Illinois
Note that the VW is an AWD and has fronts ad rears spinning. Right at the end you can see the truck isn't in 4WD...fronts are rolling backward. This is just a demonstration of traction.
-Rich-
Old 12-09-2015, 03:20 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Well it does say something about the the little TDI, at least in comparison to two wheel drive one tons....
Brevi tempore!
Old 12-09-2015, 03:25 PM   #4
Images: 59
With no weight in the bed of a 2WD pickup it isn't a fair fight.
Old 12-09-2015, 03:42 PM   #5
2015 30' FB FC Bunk
Ayer , Massachusetts
This would not happen if they had a ProPride hitch and Michelin LTs.
Ted S. is offline   Reply With Quote
Old 12-09-2015, 03:49 PM   #6
KEIZER's Avatar
1980 31' Excella II
1973 31' Sovereign
Noonan , New Brunswick
I dont think if the chev was in 4x4 mode the results would be much differnt. Had a chev truck for around two years, was the worst two years of my life. Never carried a heavy load and the frame broke on both sides just rear of the rear axle.
WBCCI #6722
Ham Radio VE9NKD
KEIZER is offline   Reply With Quote
Old 12-09-2015, 03:55 PM   #7
Kevin245's Avatar
Once the Chevy broke traction it was over. I can pull a Kenworth with a VW Beetle if the KW breaks the drive wheels loose. Simple physics here, gain the coefficient of friction advantage and the fight is over.
Eleanor Roosevelt
Old 12-09-2015, 04:22 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
VW..."special tune"??
The Chevy is not set up properly... once it started the axle, u joint, leaf springs started twisting, etc...
No doubt the VW driver did a great job.
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-09-2015, 04:37 PM   #9
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
I found this far too funny!! Well played!
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 12-09-2015, 05:07 PM   #10
Tuco's Avatar
1988 32' Excella
Ojai , California
Without properly applied Canadian fairy dust the Chevy was doomed!
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 265k+ (The Beast)
Tuco is offline   Reply With Quote
Old 12-09-2015, 07:16 PM   #11
2019 30' Flying Cloud
Homosassa , Florida
I saw one of a Duramax doing the same to a semi. As Kevin245 noted, once the semi broke traction, the Duramax pulled it. I remember someone in that video saying the owner of the Duramax had spent 18k on the drivetrain. Not sure why anyone would want to do this to their vehicle but whatever turns them on I suppose.
Tater is offline   Reply With Quote
Old 12-09-2015, 07:32 PM   #12
Road Ruler's Avatar
Images: 38
High tech VS low tech. The results say it all.
Old 12-09-2015, 07:35 PM   #13
z , North Carolina
Ha!
Given the bicycles, and the smoke stack coming out of the bed of the truck, that's all I needed to see about the intelligence of this video. The impression I got of the Duramax driver was he was 12 years old @ best. Certainly didn't know how to drive the rig that's for sure.
Rating IMHO = 0.
FishinHatteras is offline   Reply With Quote
Old 12-09-2015, 07:36 PM   #14
z , North Carolina
Hmm
Got any pictures of that broken frame or what you actually did with the truck?
Something about this entire post that's crying foul.
Hope I can find one - 1/2 ton truck dansdad Tow Vehicles 6 10-18-2009 04:27 PM
One ton purchase unwise? Wingeezer Tow Vehicles 67 10-26-2008 03:02 PM
1/2 ton vs 3/4 ton towing? subfan1 Tow Vehicles 7 12-13-2007 03:10 PM
Big 3 1/2 Ton vs 3/4 Ton Trucks Streamer1 Tow Vehicles 40 11-20-2007 10:13 PM
