Originally Posted by finalcutjoe
Bob,
I just took the 'no WD' drive axle weight and subtracted 'truck only' drive axle weight to get tongue... right?
You know I'm using the Arrow... with 1400# bars I have to crank 'em up to max, just to get reload on steer axle
Joe,
That's what I thought, ours was 1080Lbs that way. 1275 on the Sherline.
What hole are you using on your jacks, I started out in the forth, with three showing open,(pic) I had to move to the third with two open. You could try shortening to get more tension.
Yeah... I know the strut bar ain't parallel, I was an Arrow newbie then.
Do you have the Autoride suspension on your Burb?
