Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 08-28-2005, 02:15 AM   #29
nickcrowhurst
Profile:
[quote=2airishuman]i'd really like to know more about how you commute from the the uk and work out the details for happy livin'. i've considered doing this myself. maybe you could post a note on what the uk/us cycle of living is like....
2air, my son and granddaughter are in the USA, so I spend 5 months, 1st November to 1st April in your country each year. I store my tow truck at my son's place, and the Airstream at a friend's farm. My wife and I spend our time exploring the coast in our tandem sea kayak. Living in the Airstream is, of course, a great pleasure, and we often stay at State Parks. The main challenge is to ensure that the home and vehicle on each continent are safe and secure when not in use. This would be trickey, and perhaps expensive, without family and friends in each continent. I leave the vehicles with a sophisticated "battery minder", with all oils and fluids just changed, and the trailer is carefully winterized. The air fare is about $600 return each, flying British Airways. We have a ball!
"no doubt for your rig you've done all the measurements, made lots of adjustments and ultimately dialed in what you percieive as the best settings....and the 25er is barely an effort for that dodge ram!"
Yes, you're right. I like playing with the numbers. I'm a mathematician by training. This means I'll spend hours working out these details, and forget to bring the Airstream keys from England!
"instead of trying to use the tables and potentially ending up under inflated, i prefer to use an infared temp gauge and a pressure measure of what happens once the tires are warm"
Yes, I have one of those infra-red thermometers, and use it at every stop. It's a great comfort to know, rather than guess, that the tires and bearings are at satisfactory temperatures. Last year I was using the infra-red at a rest stop on I95 when an RV with a toad pulled in. The driver asked me about the tool, and requested that I use it on his rig. Sure enough, one tire on his toad was in trouble.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 08-28-2005, 08:41 AM   #30
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
[quote=nickcrowhurst]
Nick.
Nick, I am curious regarding the tempatures that you consider "normal". I'm sure it has some correspondance to ambient air temps, amt of sunshine, road surface etc, speed you are traveling at. Can you provide some numbers to us all to give us an idea of what you are seeing with your infra-red device?
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 08-28-2005, 10:24 AM   #31
nickcrowhurst
Profile:
[quote=jcanavera]
Originally Posted by nickcrowhurst
Can you provide some numbers to us all to give us an idea of what you are seeing with your infra-red device.
Jack
Jack, I tow mainly on the east coast I95 and the Florida section of I75. These have no hills or mountains, so my use of the brakes is minimal. Ambient temperatures are usually about 70 degrees. Under these circumstances I usually see 90 degrees on the tow truck hubs, and 110 degrees on the trailer hubs. This is immediately we have stopped after applying the brakes gently to come to a halt. I always point the device through the slots in the wheel covers, directly at the hubs. I also measure the tire side-wall temperatures, and IIRC, these are about 90 degrees, perhaps ten degrees higher on the sunny side. I also use the device to adjust the brakes. After initial adjustment by feel, I take the rig for a 5 mile run, applying the brakes several times. As I come to a halt, I measure the temperature of all 4 trailer hubs. If one of the hubs is more than ten degrees hotter than any of the others, I loosen that brake adjuster by one click, at the roadside. If just one is more than ten degrees cooler than the others, obviously I tighten just that one by one click. It sometimes takes 3 or 4 minor adjustments to equalize the brakes. I purchased the device from RadioShack. On the toad I mentioned, 3 wheels were about 90, and one was 140, probably because of under-inflation of a tire or a binding brake. Nick.
Old 08-28-2005, 12:42 PM   #32
flyfisher
flyfisher's Avatar
Lancaster County , PA & MT
2Air -
Thanks for your post. This subject has been on my mind for the past couple weeks.
I did my first Cat scale weigh-in earlier this month in Missoula, MT, and paid $8.00 for a single weight, and would probably have paid the same as you, if we'd done a second or third weight as you did. My total gross weight was 16460#.
Not knowing much about how to do the weigh-in, I put both of my truck axles on the front scale platform, so we got just one total weight for the truck and a second weight for the trailer.
I have a 2000 F250 psd with the regular cab, long bed, 4x4, an A.I.R.E. fiberglass cap (maybe 200# I'm guessing), sprayed-in bedliner, Hauler Aluminum ladder rack (under 100#), Enkay Mudflaps, and Reese High Performance Dual Cam hitch (with 1200# Reese bars).
My total truck weight came in at 9000#, which included a full tank of 38 gallons of fuel, and included my wife, and various items in the truck bed, including my inflatable boat (about 100#) a Honda eu200i generator with electric cables, etc (another 100#), my mountain bike, some fishing gear, a few tools and other miscellaneous items probably not weighing more than another 200# max.
What concerned me is that I would add another 200# to the truck weight, making the total actual truck weight about 9200#, but the GVWR on my truck is just 8800# (the front axle GVWR is 4800# and rear axle GVWR is 6084# per the sticker on the door truck's door panel).
The only thing I can figure is that I must have an awfully heavy trailer tongue weight, because I never dreamed that my truck would be overloaded. ??? Airstream shows my hitch weight at 1125# in their sales literature.
I have a 2004 30' Classic Ltd, which has a GVWR of 8700#, and the scale weight for the trailer came in at 7460#. So I think our trailer weight was OK in comparison. We almost never carry any notable amount of water in any of our tanks, and we don't have much extra weight in the front of our trailer (maybe 100# of "stuff") beyond what the factory installed, including 2 full 40# propane tanks.
This coming week I want to weigh the truck without the trailer attached to see what it weighs by itself, and then weigh each truck axle separately when we have the trailer hitched up again (which won't be for another month, since we are residing at the Yellowstone's Edge RV park until then).
In the meantime, I don't think there is anything in the truck that we'd want to carry in the trailer, and there isn't much else in the front of the trailer that we can put elsewhere farther back to reduce the tongue weight.
Since I'm still a novice at this, does anybody have some suggestions?
Incidentally, I've been keeping my front truck tires at 75# and rear tires at 80# inflation. 80# is the max inflation shown on the tire sidewalls.
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 08-28-2005, 01:57 PM   #33
2airishuman
2airishuman's Avatar
Profile:
looks like it may be time for a diet?
flyfisher
my truck is a bit longer (crew cab) and the long bed ARE shell may weigh 300 or so....but your steer/drive weight is just a few hundred lbs less than mine....and we're carring a lot of the same stuff....you may have a bit more in the shell (no wifey in mine)....but those numbers are close.
i think ford increased the payload #s this last year with beefier front axle and bigger brakes?
yes you want to know your tongue weight since that is part of the truck load....and if you've got too much on the tongue, moving stuff back to the center or aft in the trailer will 'lighten the truck some'.....
how much?
well it depends on that next go round at the scales. also given your potential tongue weight PLUS the 7460 on the trailer axles.....you could be at or near the trailer limits. let us know what the numbers are when you do get to movin' again.
i found the www.catscale.com had a nice little tutorial on axle placement. by drawing a little schematic it's possible to plan the weigh-in to get the most specific measures while unhitching and moving the least times.....and don't forget to measure with the wd bars adusted in multiple settings.....this is only 1$ and requires no vehilcle movement so it takes just seconds to do....
might be time for a little spring cleaning......those brass plated fuzzy dice might need to go...and any fish you are catching can be drop shipped to me!
montana....i'm jealous right now.
cheers
2air'
Old 08-28-2005, 02:49 PM   #34
flyfisher
flyfisher's Avatar
2Air -
Thanks for your observations. I looked at the catscale.com website and it has been helpful.
Perhaps if I could just get my wife to ride in the back of the trailer that would solve multiple issues! Just kidding (she might read this and then I'd be in even bigger trouble).
I think I'll try shifting more items to the rear of our trailer before re-weighing, plus get a weight on each trailer axle (mine have a 4200# rating per axle).
Will let you know when I get the results.
John
ps - All of my fishing is catch-and-release. Nobody can disprove my fish stories that way. Sorry.
Flyfisher
Old 06-19-2006, 07:24 PM   #35
hookedonclassic
hookedonclassic's Avatar
Profile:  2006 34' Classic
Fond du Lac , Wisconsin
Stopped at the CAT scale tonight for the first time for a weigh-in. Didn't have wife with me and didn't have the clothes/food in the camper. Fresh water was full, gray and black tanks were empty as that is how we travel. STUFF I typically take along was in the back of the TV. Propane and diesel tanks were full.
I tried two different setting on the Hensley to get an idea of weight on the front and rear axles of the TV. I'll refer to the marks on the Hensley as 1, 2, 3. With the tension set at the middle mark (2), the front axle was 4,040 lbs, rear axle was 4,360 and the trailer axles were 8,220 for a total combined weight of 16,620. With the tension set at the tightest (1), the front axle was 4,140 lb, rear axle at 4,260, and trailer 8,220 for total 16,620. I have the 1400 lb bars on it. Ride is good on smooth highways but rough on concrete highways. I'll probably keep the bars at the middle setting to keep the ride decent. I know that some owners use 1000 lb bars while others use 1400 lbs bars. Would the 1000 lb bars improve the ride on concrete highways? Hensley said I could go either way.
Rich
2006 Classic 34 Front Lounge
2004 GMC Duramax CC SB
Hensley Arrow
WBCCI #5401
AIR #4489
hookedonclassic is offline   Reply With Quote
Old 06-22-2006, 07:09 PM   #36
2airishuman
Profile:
hi rich
one question i'd offer....
did you weight the truck without the trailer attached?
this is important...knowing what was on each truck axel...without the trailer.
also did ya measure the trailer tongue again without being connected?
as for 1000 vs 1400lbs (i'm using 1000)......
i'll have more on this in a few days.....
i'v got some new data and ideas....
will post more.....
after i talk with the hensley rep at the rally.....
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 06-22-2006, 07:34 PM   #37
silverback
silverback's Avatar
Profile:  2006 28' Safari SE
Phoenix , Arizona
I've got the truck height(s) measured and will get that weighed solo first. Our camping plans are preempted due to the Sedona fire (we were going to Munds Park but they're under an evacuation order) so I might as well visit the Cat scale. How did you weigh the tongue? Unhook at the cat scale? FYI - we're using the 1000 lb draw tite bars and I'm thinking about going down to 750.
-Ken
4CU Charter Member
2004 Silverado 2500 HD D/A
Honda EU2000i
Hensley Arrow
KE7DUI
silverback is offline   Reply With Quote
Old 06-23-2006, 07:39 PM   #38
2airishuman
Profile:
-Ken
hi ken and others....
yes if using the cat scales, unhitch with the trailer axles on the 3rd platform and the tongue on the 2nd.....get the trailer reasonably level front2back...
and ask the operator inside for an additional reading....usually each added reading is only a dollar or so, after the first 6-8 dollar weight...
one can also measure ft/rr tv axles as part of the full process, unhooked (but loaded with gear) and again hooked up while adjusting the spring bars....see the first post in the thread for my go round doing this...
cheers
2air'
Old 06-23-2006, 10:55 PM   #39
TIMEMACHINE
TIMEMACHINE's Avatar
Huntington Beach , California
2airishuman,
Thanks for the info on the CAT scale adventure. .....What did you think of the factory tour and your service at Jackson Center? Did you see anything new?
TIMEMACHINE is offline   Reply With Quote
Old 06-24-2006, 05:20 PM   #40
2airishuman
Profile:
Originally Posted by TIMEMACHINE
2airishuman,
hi time machine and welcome to the forums....
the factory tour is great, i've done it 7-8 times now and learn something new each visit....seeing how an airstream is built really helps one understand the issues (good or bad) in our own trailers....
there are several threads here on factory tours and even some photos....but really the virtual tour on airstreams own web site has pretty good pix of the key steps...
the service center guys are FANTASTIC......and i mean it.
great workers, very skillful and amazing people skills....airstream owners can be pains......if ya know what i mean.
some of them were flown out to the international rally, so i'm having some expert service done here in oregon next week!
as for new stuff this thread is old now........
but the new stuff right now that is also 'hot'.......
safari 25s rear door, ls, se are the big sellers and the models are pretty nice.
there is supposed to be a rear door classic at the rally next week, so i'll report on it......and maybe a base camp.....
now back to the weigh ins........everyone should visit a scale at least once!
cheers
2air'
Old 10-29-2007, 10:17 PM   #41
REDNAX
Aluminum Vintage Kin
Profile:  Corpus Christi , Texas
Okay, ya'll, I've had a Hensley on my vintage kin SILVER STREAK that Dave Tidmore and crew installed for me at Roger William's Airstream a few days after I purchased both truck and trailer. We've put probably 5,000-miles on it since May and I now have a little time to start the rest of the process of perfecting the tow vehicle and trailer for roadworthiness.
I've posted elsewhere my "feelings" about this hitch. It's a no-brainer, IMO. But my rig is not otherwise ideal. Not yet.
I grew up in a family that towed (Streamlines and Silver Streaks), and I have been a professional truck driver. I've usually owned old cars (just let go my '71 Chrysler daily driver). "I've learned and learned", as one old truck driver said one day, "and I still haven't seen it all"; a statement I agree with in my more temperate moments.
So I'd like to enlist your help in tracking down, through this thread, some if not all of the "roadworthiness" issues (balance, distribution of weight, etc) that can be encountered per my rig. Perhaps this will be of help to others. I have had to go to a lot of threads in this forum (and others) to find info on rigging properly (I am going to use A/S guidelines even though I do NOT have independent suspension on my trailer; please ask for any clarifications). I'd rather use this forum than others out there with no further comment.
No, I do not have a camera I can post pictures with at this time.
We'll be leaving Dallas in a few days bound for Corpus Christi (again) and I'll have the time to do some Cat Scale weighing, and rig measurements.
Your help is requested.
According to Andy/Inland RV I'll need:
1. Length of Trailer
2. Tongue Weight
3. TV Wheelbase
4. TV Spring Capacity
Also,
A. Truck Scale
B. Straight Edge (and level)
C. Tape Measure
TRAILER
1983 Brochure Picture (mine is nearly identical; a rear bath; brochure has fair info)
1983 Silver Streak Brochure Cover
1983 34' SILVER STREAK 3411 Supreme
As of 8/8/07 weight was 7,360# (tongue weight not measured)
This weight represents a current load that is changing monthly as we travel (not retired, deciding future jobs, where to live and the like. Plus, visiting our son as much as possible before he is shipped out by the USMC), so I expect to see a change on Thursday when I re-weigh. My future weight is unlikely to be higher than this.
When purchased, the trailer was nearly dead-on the factory weight of 6,820#.
TOW VEHICLE
2004 DODGE RAM SLT Cummins TurboDiesel, 2WD, 3.73 Anti-Spin, NV-5600 6-speed, QuadCab, 8' bed. 8,620#, hitched, fueled, usual load otherwise. A separate weigh will be made this time.
DODGE TOWING GUIDE
Dodge Towing Guide
Gross Vehicle Weight Rating (GVWR) = 9000 lbs
Payload = 2274 lbs
Curb Weight = 6726 lbs
Curb Weight Front/Rear = 4071 lbs/4071 lbs
GAWR Front/Rear = 4750 lbs/6000 lbs
Gross Combination Weight Rating (GCWR) = 20000 lbs
TRUCK SCALE TICKET
(full fuel, one pax, topper, bed with good load)
Steer: 4,240
Drive: 3,760
Gross: 8,000#
I will be taking static measurements of the vehicles the day of the weighing set once at a CAT Scale; trailer beltline, wheelwells of both vehicles, etc. Hitched and unhitched.
I will also be splitting the tandem axle on the scale in as level a manner as possible, as I believe I have a significant rear-ward bias due to the floorplan of this trailer.
ORIGINAL WEIGH TICKET: (with oem Reese hitch; truck with no load)
Day of purchase
Steer: 3,900
Drive: 4,160
Trailer: 6,000#
Gross: 14,060
SECOND WEIGH TICKET: W/D bars at max
(TV with full fuel, usual bed load and passengers. TT with full fresh water, empty waste tanks, empty propane [two 40# bottles]).
Steer: 4,060
Drive: 4,560
Trailer: 7,360#
Gross: 15,980
(A quick, but imperfect tandem split indicates a 3-400# rearward bias).
What information would you have me gather to get this underway besides the above?
Thanks in advance.
2004 2WD Dodge CTD Ram 2500 longbed 6-spd/3.73; Leer topper; 7,400#; 140,000 miles.
19 city/22 mpg solo (62 mph/1850 rpm)
1983 Silver Streak 3411 Supreme; 7,320# w/ Hensley Arrow (TW: 980#/13%)
http://www.tompatterson.com/Silverst...1983/19831.php
Rig is 15,700#; 15 mpg at 62 mph
REDNAX is offline   Reply With Quote
Old 10-29-2007, 10:37 PM   #42
2airishuman
Profile:
hi rednax
one item i've learned since the first weigh in...
at some/many scales you MUST roll off and come around again for each spring bar/set-up adjustment.
some scale sections (rear primarily) will NOT reset and measure accurately unless unloaded between measurements...
so ASK about re-weighs (which are only 1-2$)
btw i've since ADDED an extra leaf to the truck rear AND changed to a higher spring bar rating (1400)
with the original set up and at 30-35,000 miles of towing the truck began to sag slightly at the rear...
max bar tension NO LONGER redistributed load as first posted and the drive axle became too heavy.
so KNOWING tongue weight is important (mine is >1300lbs) and the newer 3/4-1 ton spring sets are more NOT nearly as stiff/harsh as 60s-70s-80s trucks.
leaf spring fatigue with lots of towing is not uncommon.
IF your goal is to reduce truck vibration into the trailer, consider the mor-ryde rubber rear shackle replacement...
i've posted that link in other places...
cheers
2air'
cheers
2air'
