Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 04-02-2006, 06:59 PM   #1
2airishuman's Avatar
Profile:
convex towing mirrors for the ford superduty.....
hi all those reflecting on what's behind ya......
the 1999-2006 ford f-250s can be factory equipped with perhaps the best thought out mirrors...
-big flat section top...
-1/2 round convex lower.....
-extendable arms....
so pretty well thought out for towing.....
the nissan have a scaled down, very similar style.....
and the 07 ge'ems finally have a sleek 2 arm style, but the area is too small...
anyway, cosmotini suggested some convex add ons for the fords in this thread.....
http://www.airforums.com/forum...highlight=2air
they looked great,
so i decided to try a pair....
more is good right?
yesterday i installed them....
here is my show and tell.....
cheers
2air'
Old 04-02-2006, 07:02 PM   #2
Profile:
shipped priority, packed well....the source is in cosmotini's post......
all the bits.....
box, brackets, mirrors, hardware, instructions....
and the usual set of warning labels/disclaimers.......
Name:	c betr mirrors 2.jpg
ID:	20076  Click image for larger version
Name:	c betr mirrors 3.jpg
Old 04-02-2006, 07:07 PM   #3
Profile:
after reading the instructions.....
several times,
i promptly folded them and
stuffed then in a pocket......
15 minute job tops.......
the first instruction is to loosen the 3 screws on the back of the convex mirror housing.....
i did this; then realized the screws weren't stainless.......
an hour later, i'm back from the local h/w store with replacements.....
i loosened and removed one, no problem.
so i took out all 3......not a wise move......
now all the pivot parts have fallen away
inside the mirror housing
which is sealed
like a watch case full of loose gears.....
and the watch case doesn't open....
now what do i do?.....
Name:	c betr mirrors 4.jpg
Old 04-02-2006, 07:11 PM   #4
Profile:
ok so 2 hours later.......
3.5 hours total,
for those keepin' score.....
i've reassembled the insides...
like a ship in a bottle.....
a black bottle.....
see those shiny stainless screws
i don't recommend this improvement....
the key piece to this mirror set,
is the bracket that is molded to fit the ford arms....perfectly.....
Name:	c betr mirrors 6.jpg
ID:	20079  Click image for larger version
Name:	c betr mirrors 5.jpg
Old 04-02-2006, 07:15 PM   #5
Profile:
so 15 minutes later the mirrors are attached to the brackets,
and mounted on the ford arms.....
the fit is exact...
really they look factory
and mounted close to the truck,
do not interfer with the arm extension
also they can be slide outward on the arms
if so desired...
looks good yes?
Name:	c betr mirrors 7.jpg
ID:	20081  Click image for larger version
Name:	c betr mirrors 8.jpg
Old 04-02-2006, 07:23 PM   #6
Profile:
so how's the view?
reward......
photos taken from drivers seat
eye level
mirrors adjusted for driving,
not towing
still the round convex addition
really improves the field of view
larger area than the small 1/2 lowers...
nice a clear
image not too small
note my pooch,
and the neigbors
who strolled by
with perfect timing....
i like it......
Name:	c betr mirrors 9.jpg
ID:	20083  Click image for larger version
Name:	c betr mirrors 10.jpg
Name:	c betr mirrors 11.jpg
Old 04-02-2006, 07:29 PM   #7
Profile:
so for anyone who'd like to improve on the already great ford mirrors
i recommend these.......'c betr' 5 inch convex add'ons.....
www.c-betr.com
from a distance they aren't noticeable and up close they look stock...
nice solid mounting hardware......now with stainless screws....
i'll take a towing shot or 2 soon....
the end
2air'
oh and the led light bar is a great way to add more brake/turn/marker lights....
plug and play....
click on the pic for a close up
really bright at nite
this pic in high noon
15 minute install tops
sort of.......
Name:	c betr mirrors 1.jpg
ID:	20086  Click image for larger version
Name:	c betr mirrors 12.jpg
Old 04-02-2006, 07:36 PM   #8
Coastalview's Avatar
Profile:  1978 29' Ambassador
Carmel , California
Images: 14
Those added mirrors look great. They make good use of the mirror arms. On my older 97 model, the mirrors are just plain crap. No wonder folks back then were side swiping everything! Jeff
78 Airstream Ambassador 29'
97 Ford Powerstroke 4x4 Crewcab Shorty
A few Citroen's and Peugeot's
AIR# 649
Coastalview is offline   Reply With Quote
Old 06-28-2008, 05:33 PM   #9
Profile:  Corpus Christi , Texas
Can you aim any of these spot mirrors at the tires? I always mounted xtra mirrors on my assigned tractor. But the ones I could aim towards to the drive axles were a "big deal" in a number of situations, to be certain of WHERE the tires were and HOW they looked in doing it. The overheads (trailer or truck roof clearance) weren't so vital.
Nice product, like to have them on mine.
2004 2WD Dodge CTD Ram 2500 longbed 6-spd/3.73; Leer topper; 7,400#; 136,000 miles.
19 city/22 mpg solo (63 mph/1800 rpm)
1983 Silver Streak 3411 Supreme; 7,320# w/ Hensley Arrow (TW: 980#/13%)
http://tompatterson.com/Silverstreak...983/19831.html
Rig is 15,700#; 15 mpg at 63 mph
REDNAX is offline   Reply With Quote
Old 06-29-2008, 12:18 AM   #10
Profile:
Originally Posted by REDNAX View Post
Can you aim any of these spot mirrors at the tires?...
hi red,
YES u can!
while not obvious from the install pix,
i usually have them directed so that i can see the drive wheels/tires and 2-3 lanes out on either side...
additionally the main (large upper) mirror can be moved with the toggle switch to see the tires.
any time i suspect a tire might have an issue and randomly when traffic is clear,
i point direct them toward the tires and mud flaps for a view...
matter of fact the s/d mirrors extend far enough to the sides, that i can see the TRAILER TIRES on curves
and all the side marker lights on the straights...
originally i'd considered mounting 2 rear view cameras in front of the trailer axles to monitor the tires.
but that itch was scratched after towing a bit.
the c'betr product doesn't yet fit 2008 trucks, but they've got other styles too...
C-Betr Blind Spot Towing Mirrors
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 06-29-2008, 07:53 AM   #11
denellen's Avatar
Profile:  2007 25' International CCD
1964 19' Globetrotter
vero beach , Florida
Talking Pooch lovers
Originally Posted by 2airishuman View Post
so how's the view?
reward......
note my pooch,
HI MAX. Good boy!
Dennis & Ellen
07, 25' Ocean Breeze
64, 19' Globetrotter
Air #7609
denellen is online now   Reply With Quote
Old 06-29-2008, 12:21 PM   #12
Profile:
Just bought a new 2008 F 250. The mirrors a wonderful. Now if I could have the same clear forward view.
I have a pair of Makeesh (sp) by Hensley mirrors that I no longer need so if you want a deal send me a message.
rtaylor537 is offline   Reply With Quote
Old 06-30-2008, 09:01 AM   #13
hi red,
YES u can!
cheers
2air'
Thanks for the experience. Yeah, I'm pretty good at the trailer "waggle" to check tires, 'cause nothing beats good mirrors to check the rig.
My stock Dodge tow mirrors are okay -- but not as good as I am used to -- am thinking of moving to an after-market brand that has two-arm attachment, and I wondered about these mirrors you showcased as I might be able to make them work (or fabricate something on my own).
I had these mirror glass replacements on my last truck:
Blind Spot Mirror Specialists - Safety Mirrors Online.com
and they are superb, they truly eliminate any blind spots (turning one's head is now a hazard once they're installed). But I haven't used them with a trailer as long as this one.
I may try the glass overlay with the CIPA towing mirrors, but some experimentation will be in order. In the meantime, I appreciate your experience with the add-on mirrors for spot work. I'll find some arrangement that is satisfactory for solo AND towing, long-term.
Pingbacks are On
1989 370 Ford 460 Overheating 1985air345 Mechanics Corner - Engines, Transmission & More... 14 07-05-2004 03:46 PM
Towing Experience app Towing, Tow Vehicles & Hitches 9 04-19-2004 09:51 PM
Towing Mirrors 53flyingcloud Towing, Tow Vehicles & Hitches 8 01-03-2003 04:28 PM
Towing cars CBBOB Airstream Motorhome Forums 13 07-24-2002 08:15 PM
Towing With a 1974 Ford F100 melprice Tow Vehicles 6 07-08-2002 10:28 AM
SEO by vBSEO 3.1.0
