Old 05-11-2015, 03:44 PM   #1
lake worth , Florida
Van towing
I have a 2013, 2500 Ford cargo van with a 4.6 liter engine, 3.73 rear axle ratio and 8,500-9,000 lb, GVWR. Can I safely tow a 23 foot airstream?
Fordvan is offline   Reply With Quote
Old 05-11-2015, 06:46 PM   #2
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
maybe.
you'll probably want to know the towing capacities of your particular van, as published by Ford, along with the other weight, drivetrain (rear axle ratio,) and tire info that are stamped on the white door pillar sticker, and on your tires.
then you can compare all that to the trailer you're considering, and
have a good idea where you stand....
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 05-11-2015, 07:01 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I certainly think so in terms of size and payload. I have caravaned with several people who towed 34 footers with 250 sized vans. Backing will be a bit tougher than it would with a shorter TV or longer trailer. Engine power will slow you down a little in hilly areas. Since you drive a van anyway you already know its limitations. What is your area of concern about a heavy van as a TV?
Old 05-12-2015, 12:21 PM   #4
My areas of concern are safety and dependability.
Old 05-12-2015, 12:36 PM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I used 250 Ford Vans for years. Pulled well but I blew two rod bearings at 125K miles. The flat sides did cause more sway when passed by trucks. Your rear end ratio is a little low for the mountains. Having a trailer package with transmission cooler is beneficial for mountains.
Old 05-13-2015, 04:53 AM   #6
Can I ask you what size Airstream you were towing?
Old 05-18-2015, 01:45 AM   #7
1977 31' Sovereign
1989 34' Excella
Pulled the 31 footer for about 15 years over 50,000 miles.
Old 05-19-2015, 04:59 AM   #8
Well then, I shouldn't have any problem pulling a 23'. Thanks.
Old 05-19-2015, 05:26 AM   #9
87MH's Avatar
1978 31' Sovereign
Images: 292
I would highly recommend that you avoid overdrive with a passion - this coming from a person who blew a van transmission while towing.
My opinion is that vans are the perfect road trip vehicle.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 05-19-2015, 06:42 AM   #10
1977 31' Sovereign
1989 34' Excella
Lots of covered, waterproof storage volume for junk(protected from prying eyes). sleeping facility and tent for side trips to places you can not take the Airstream.
Mercedes Van Executive Van Airstream Interstate eBay Watch Airstreams on eBay 0 05-14-2012 05:30 AM
2012 airstream avenue class b van generator and a/c 190 camper van fully loaded eBay Watch Airstreams on eBay 0 05-01-2012 11:00 AM
2012 airstream avenue class b van generator and a/c 190 camper van fully loaded eBay Watch Airstreams on eBay 0 04-19-2012 08:40 PM
2012 airstream avenue class b van generator and a/c 190 camper van fully loaded eBay Watch Airstreams on eBay 0 04-09-2012 05:40 AM
2012 airstream avenue class b van generator and a/c 190 camper van fully loaded eBay Watch Airstreams on eBay 0 03-29-2012 05:00 PM
