Old 09-27-2016, 09:48 AM   #1
Chris_P's Avatar
1982 31' Excella
Montgomery , Texas
Unknown part of tongue
Would anybody be able to tell me what the plate looking thing is in this photo? Is it part of the weight distribution hitch system?
Name:   ImageUploadedByAirstream Forums1474987688.603722.jpg
Name:   ImageUploadedByAirstream Forums1474987725.741748.jpg
Chris P
'82 Excella 31'
Lake Conroe
Montgomery, TX
Chris_P is offline   Reply With Quote
Old 09-27-2016, 10:02 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I do not think it was anything to do with a commercial WD system. However it does look like it may have been a home made system.
2004 Excursion 4x4
Old 09-27-2016, 10:50 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Looks to be backyard engineered.
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 09-27-2016, 11:18 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Looks like they were using Reese WD, bars but lost the brackets for the trailer. They must have just hooked the chain links over the top of the plate into the notch. It would sort of work but did not give any of the self centering action of the later twin cam models.
To save money, you could just try to do the same as them, but I would recommend you buy a properly designed system. Your listing does not indicate the size of the trailer or the TV. Better safe than sorry.
Old 09-27-2016, 12:10 PM   #5
1967 26' Overlander
Spartanburg , South Carolina
If that is in fact what it is, it would sort of work if the jack was strong enough to raise the rear of the TV with the trailer hitch. The weight would be transferred when the jack was raised. That said, what would the round part on the rear of the plate be for?
Jacob D is offline   Reply With Quote
Old 09-27-2016, 12:58 PM   #6
1977 31' Sovereign
1989 34' Excella
Most people use the tongue jack to lift the front of the trailer/back of the TV, after the ball has been engaged. This minimizes the stress and potential danger of just using the lever bar to lift the chain over-center. It does put a bit of stress on the tongue jack, but is better than a broken finger.
Old 09-27-2016, 02:09 PM   #7
1976 31' Sovereign
Oswego , Illinois
Smile
I would never try to fasten snap ups w/out raising front w/jack. If pipe slips off snap up can be worse than broken finger, minor would be shins banged up to other broken bones or worse. I use old motor cycle fork tube that has insert one end that is same dia. of Reese snap ups, length just rite. You could find from friend or motor cycle shop as when replaced it is junk to them. Plus they are hard chrome plated no rust. Pics look like mickey mouse contraption. Bill
Old 09-27-2016, 02:47 PM   #8
1973 31' Sovereign
Middletown , California
Looks like an attempt to solve the WD bars from riding so low. I'd bet the round part was where the bar went while grabbing chain links. Can you talk to the previous owner and get the rest of the hitch set up? Any funny parts hidden in the trailer? Otherwise get a Reese dual cam set up. What size trailer and truck are you using? Did it tow well on just the ball when you brought it home? Might not even need a weight distributing hitch.
ijustlee is offline   Reply With Quote
Old 09-27-2016, 08:31 PM   #9
Chris_P's Avatar
1982 31' Excella
Montgomery , Texas
It's a 1982 Excella 31' rear twin tt. Towed it from Alabama to the Houston area with a 2006 Dodge 2500 diesel without ANY towing issues. The Dodge isn't mine; I have and will tow the tt a short distance with my 2007 GMC Sierra 1500 5.3L.
Chris P
Chris P
'82 Excella 31'
Lake Conroe
Montgomery, TX
Old 09-28-2016, 09:06 AM   #10
Chris_P's Avatar
1982 31' Excella
Montgomery , Texas
Would these brackets have to be removed in order to use a standard set up?
Chris P
Chris P
'82 Excella 31'
Lake Conroe
Montgomery, TX
Old 09-29-2016, 06:01 AM   #11
1973 31' Sovereign
Yes, remove them. Standard brackets go right about there.
Old 09-29-2016, 09:18 AM   #12
Chris_P's Avatar
1982 31' Excella
Montgomery , Texas
Thanks for all the replies
Chris P
Chris P
'82 Excella 31'
Lake Conroe
Montgomery, TX
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 01:33 PM
Unknown Airstream part. Bob Riffle Airstream Classifieds 0 02-05-2015 04:55 PM
Unknown pink w/green stripe wire at tongue Skater Electrical - Systems, Generators, Batteries & Solar 1 08-08-2014 09:31 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 02:02 PM
