Old 07-22-2019, 08:01 PM   #1
2016 30' Classic
Idyllwild , California
Truck information -- what gives?
Hi,
Since we purchased our 30 Classic a year or so ago we’ve been using it for short trips, only loading it and our TV lightly. Now that retirement time has rolled around we are planning an 8+ week trip to Alaska next summer. For this trip we are planning to load both the TV and the TT more than we have before and would like to know payload, towing weights and limits etc. for the truck. So far this has been difficult information to obtain.
The owners manual for the TV (2010 2500 Ram diesel, long bed, crew cab 4X4 automatic) says to go to Dodge.com. The site says the information is not available. I emailed Dodge and have not heard back. I called Dodge today and found out nothing other than their technical department would be emailing us at some point. You would think I were asking for military secrets or something the way they act.
I found an aftermarket payload, towing information and weight chart on line but it asks what model transmission, axle ratio etc. that is coded in the VIN. I would prefer having factory information anyway.
Has anyone else had this problem? If so, do you have any advice on how to find this information that it seems to me should be easy and important for a truck owner to know.
Thank you,
Chirs
2partners is offline   Reply With Quote
Old 07-22-2019, 08:53 PM   #2
Alreddawg19's Avatar
2018 23' Flying Cloud
Redmond , Washington
Is there no sticker in the driver side door that shows payload and gross weight capacity? That's usually where they are.
Alreddawg19 is offline   Reply With Quote
Old 07-22-2019, 08:58 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
There should be two load information placards on the driver's door jamb. One placard is tire and payload information. The other placard is GVWR and GCWR information.
Have you registered your vehicle at Mopar? The information might be available there. And, you will be able to communicate with the manufacturer about that specific vehicle.
https://www.mopar.com/en-us.html
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 07-22-2019, 09:52 PM   #4
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
You need to visit the Ram site, not Dodge, to get the basic specs on your truck.
https://www.ramtrucks.com/en/towing_payload/2010/
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 07-23-2019, 06:17 AM   #5
2016 30' Classic
Yes there is thank you, with some of the information. I was hoping to get more info on towing.
Old 07-23-2019, 06:22 AM   #6
2016 30' Classic
A W Warn, thank you. I'll take a look at this.
Old 07-23-2019, 06:24 AM   #7
2016 30' Classic
See More, I think this is what I'm looking for but there seems to be some kind of computer glitch in pulling up the page. The page flashes on the screen and then is gone. Maybe I should try a different browser. Thank you
Old 07-23-2019, 10:10 AM   #8
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Generic profile
The Mopar site does not have vehicle specific data (after entering VIN) before 2015.
Screen grab for 2010 2500 series from ramtrucks site:
Name:	Screen Shot 2019-07-23 at 12.07.52 PM.jpg
Sir Tristan
Old 07-23-2019, 10:45 AM   #9
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Does the truck have the door placards?
They should have all the information needed to calculate loading, without any other information other than actual weight at the scales.
Alan
Old 07-23-2019, 02:40 PM   #10
Mockingbird Heights , California
The MOPAR/RAM website is absolutely worthless for finding out the payload on your vehicle... even if you input the VIN.
It listed my 2019 1500 Limited as 1840#, door sticker read 1320#.
As others have mentioned, read the door sticker.
Servus non essem
Non Servium
Gondul is offline   Reply With Quote
Old 07-23-2019, 05:16 PM   #11
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Unless you can find data specific to your vehicle ( = by VIN number), what you will find on the internet from any manufacturer on the internet is worthless. They simply don't put up enough fine grained data. One can wonder why, but they all do it that way.
The only answer is to go look at the sticker on your actual truck. What's there is a start. You then need to dig into what they do / don't include in the numbers. There is either fine print on the sticker and / or in the owners manual. Once you have that traced down you know what the numbers actually include. ( full gas tank ?? full set of passengers ?? passengers all weigh 110 pounds ??????? )
Next step is to run over to the local CAT scales and weigh your vehicle, vehicle plus trailer, and trailer alone. There is a lot of info on this in threads here. From these weights you can see if you are over weight *and* if hitch adjustments might help things.
After you have the numbers, the obvious question is - how close to the limit do you want to run? For some, the limit is "only a suggestion". For others anything much over 80% is not the best approach.
It's amazingly easy to overload a small trailer or an SUV. The 30' Classic is pretty robust. You *can* overload it, but it takes some effort. Depending on options, the 2500 also should be able to do its part. Again you *can* overload it if you try.
uncle_bob is online now   Reply With Quote
Old 07-23-2019, 06:23 PM   #12
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Check our hdrams.com for previous gen Ram info
Originally Posted by 2partners View Post
Hi,
...For this trip we are planning to load both the TV and the TT more than we have before and would like to know payload, towing weights and limits etc. for the truck. So far this has been difficult information to obtain.
Hi Chris, the other posters explained about the payload sticker on the door which is a good start. You might also find another sticker that lists the GAWR or gross axle weight rating (front and rear). Those three numbers plus the axle ratio will help you figure out the truck’s towing capabilities.
I recommend you navigate over to HDRAMS.com. https://hdrams.com/forum/index.php
Besides having specs on the new gen Rams, they have a page with all previous Rams. I’m sure you’ll find someone over there with the information you’re looking for.
Good luck!
Jeff
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB (traded)
2019 Ram 2500 Laramie Blue Ox 1500#
2019 Ram 1500 Laramie Sport,
2020 Retirement Plan
jeffmc306 is offline   Reply With Quote
Old 07-24-2019, 05:18 AM   #13
Eric 26 Argo's Avatar
Knoxville , TN
Try this site. It has a pretty good break down of the RAM line capacity. http://www.rambodybuilder.com/2010/d...ammlup2500.pdf
The only thing you left out was the rear axle ratio in your truck description. Your truck payload capacity will be the same no matter which one you have at 9600 lbs. The tow capacity with the 3.42 axle is 9500 lbs. while the 3.73 and 4.10 allow 12,000 lbs. So worst case you are limited to 2200 lbs. in the truck and 2000 lbs. in the camper. So I would say yes your wife can take that extra pair of shoes.
Have fun in Alaska.
Eric 26 Argo is offline   Reply With Quote
Old 07-24-2019, 06:00 AM   #14
Gainesville , Florida
Sometimes if you get a build sheet run, the info on it helps. Get it from service or parts at the dealer.
when when life gives you lemons . . . make Airstreams MarkR Airstream "In the News" 0 10-18-2014 12:37 PM
6 weeks on the road gives me furnace questions willbrackman Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-24-2009 08:31 AM
Sex offender gives bad name to AS's NewStreamer Our Community 18 01-11-2003 10:25 AM
