Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 02-15-2013, 04:45 AM   #1
1974 25' Tradewind
2000 34' Limited S/O
cottontown , Tennessee
triple axle
what would be the reason for running a steel wheel in center on each side on 34 ft triple axel with slide. are the factory aluminum wheels to weak or trailer just to heavy at 9000lbs year 2000
carpenter is offline   Reply With Quote
Old 02-15-2013, 05:30 AM   #2
Retired.
. , At Large
Probably C: Two aluminum wheels got damaged, and steel wheels at $50 each are cheaper than aluminum at $300 each. Or the repair shop could get steel replacements, but not aluminums.
Old 02-15-2013, 11:19 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Yep, somebody was trying to save money.
The factory shipped these with six aluminum wheels and a steel spare.
Old 02-15-2013, 04:21 PM   #4
1988 32' Excella
Robbinsville , New Jersey
If it was about strength the center axle would need the least do to more stress from turning on the other axles, also there are tandem axle Airstreams with gross weight rating of 10,000lbs with aluminum wheels.
Old 02-15-2013, 06:06 PM   #5
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
Could it be the aluminum wheel is in the spare carrier with a flat tire?
Alan
Old 02-15-2013, 08:10 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
That would be two aluminum wheels in the spare carrier, so I'm thinkin' probably not.
Of course it may be that it came with six steel wheels, like my 1983 Excella, and a PO found a deal on four aluminum wheels somewhere and never got around to the last two. I've seen lots of adds for four wheels, but never for six.
However, my guess is that Terry got it right in post 2.
On edit: About never seeing six wheels for sale. Immediately after I posted I thought, "I haven't looked at the classifieds in a while." The second add is for six wheels and tires from a 1997 Limited. It sure doesn't take long for circumstances to make a lair out of me here on the forums.
Vaughan
Old 02-16-2013, 04:14 AM   #7
SL4BLLT's Avatar
1972 31' Sovereign
Fort Bragg , North Carolina
Guess what is posted under parts in the forums dated Feb 14?
"I have six aluminum wheel that came off my 97 34' classic. The previous owner bought these from Airstream. They are the same wheels that were on a 97 limited. I just put on 6 new marathons size ST225/75R15 that only have 500 miles on them."
So if someone is looking for all six, for $1K they are there.
Maybe I can get some luck in purchasing some replacement side emblems. I've never seen the "International" Side Emblems being sold either. I've looked around inquired, but cannot located them for a 1972. I've got one in good shape the other seems to be warped. I was going to pull them off and paint them, but thought until I can get replacements, or if I can't that would be the last resort, I'll hold off. They've held up great for 41 years.
SL4BLLT
SL4BLLT is offline   Reply With Quote
Towing a 34' triple axle airstream floidoip Towing, Tow Vehicles & Hitches 21 12-23-2019 11:44 PM
95 airstream camper, 36 ft. triple axle eBay Watch Airstreams on eBay 0 01-23-2012 03:30 PM
Airstream excella 1000 1992 34 ft / triple axle 1 owner from new fabulous cond ! eBay Watch Airstreams on eBay 0 12-01-2011 03:00 PM
1985 Triple Axle 35 foot Airstream Sovereign Trailer with two awnings! eBay Watch Airstreams on eBay 0 11-08-2011 07:00 PM
35 foot Triple axle Airstream with rear beds, side bath eBay Watch Airstreams on eBay 0 09-18-2011 06:30 PM
