03-14-2014, 09:35 PM
1976 25' Tradewind
xxxx
, Delaware
Transmission cooler?
I FINALLY got my TV for my 76 tradewind!
Now I am installing everything I need to get going. But I am curious about whether a transmission cooler would be necessary. My 2005 silverado has a tow capacity of 8700, my Tradewind is 5800. TV only has 3.42 rear axle, 335 torque, 310 horsepower. Do I need a trans cooler? I am hoping the answer is no because I am pretty sure it would void my extended warranty. Would a transmission monitor be good enough to prevent any issues? My wise father's advice is if the transmission goes, it goes, and they replace it. Lol I AM within the tow capacity after all...
Thanks in advance.
M
03-14-2014, 10:15 PM
2007 16' International CCD
Somewhere
First, I don't think that I am the most qualified to answer these questions, but I'll start the conversation with some thoughts.
I suggest you you check with the warranty company to be certain -- in my opinion they should be happy to have you invest in keeping the tranny temp down while towing.
Given your rig, whether or not you "need" it is hard to predict. More likely if you will be towing in the mountains in Summer, less likely for flatland towing in cooler times. In all cases it will provide a margin of safety and a degree of peace of mind. Your father's advice is good in general, but maybe less so in the middle of a desert in the middle of your Summer vacation.
If it were me, and if the warranty was still good, I would install one.
03-14-2014, 10:22 PM
1967 22' Safari
Long Beach
Hello Merrypaws:
I'll bet you already have a transmission cooler on your 2005 Silverado. My 2003 Silverado came with one as standard equipment. Over the previous years I have had lots of transmission problems while towing. When I purchased this new Silverado in 2003, before pulling my trailer I scrapped the factory transmission cooler and installed the largest cooler that would fit. That ended my transmission problems. I'm very happy that I did that!
03-15-2014, 12:38 AM
2012 25' FB Eddie Bauer
Eugene
, Oregon
Simply installing a transmission cooler won't void your warranty. The warranty provider has to demonstrate that your modification caused the damage they are refusing to cover in order to refuse payment. In the event that they're able to do that it would still not void the rest of the warranty.
If you're interested in learning more, here's a little light reading.
As for whether or not you need a transmission cooler... I would take the truck to a reputable tow/hitch shop and see if you already have one, if not, it'll be cheap and easy for them to put one on. It'll provide an added measure of protection and allow for worry-free towing.
03-15-2014, 01:18 AM
Vancouver
, British Columbia
Originally Posted by phbarnhart
Doesn't that relate more to manufacturer's warranty on new products, as opposed to service agreements on nine year old used vehicles?
03-15-2014, 05:24 AM
ottawa (greely)
, Ontario
I'm going to say the same as others installing a trans cooler will not void your warrantee also your truck maybe already has a factory cooler ,do you really need one to keep your warrantee no but would I have one for sure ,the number one cause of failure is heat. If you plan on keeping your truck put a trans cooler. Ever since g.m. Put 100000 mile Warrantee I think all there trucks have trans coolers.
03-15-2014, 06:37 AM
2013 20' Flying Cloud
Cream Ridge
, New Jersey
A large capacity trans cooler is money well spent if you don't already have one
03-15-2014, 06:44 AM
2002 30' Classic S/O
Garden Valley
, Idaho
Joe is right and it typically only costs around $100 for the extra tranny cooler. I would also recommend an additional external spin-on filter system for another $100, it will save another issue of particles floating around in the fluid line. I change my external filter every 10-15k or every other engine oil change. I got my kit from Summit Racing.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
03-15-2014, 06:48 AM
Garden Valley
, Idaho
Here are some pictures of my external tranny filter on my 2008 Ford V-10.
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
03-15-2014, 09:29 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
I tend to agree with the position that a truck with an 8700 lb tow rating won't need a cooler.
Granted another external cooler won't hurt provided that it doesn't leak, but then a lot of the hose connections used on the majority of aftermarket coolers are crap, simple hose connections and hose clamps. These all eventually leak.
I have bought these coolers and put flare connections on the ends when I haven't been able to find one with built in inverted flare connections in the time frame I needed.
Few shops will take the time to run tubes and use inverted flares.
FWIW I use no external cooler on my lesser rated Silverado towing my 31 foot Sovereign, never had a trans overheat even up a long 8% grade.
03-15-2014, 09:59 PM
Salem
, Oregon
Hi, if your trailer is within your tow vehicle's tow rating, you don't need another trans cooler. Too much cooling can also cause damage. As mentioned above, aftermarket trans cooler's fittings are crap. A larger factory cooler would be nice with the factory connections, but still not necessary. Trans gauges also cause un-necessary panic; I don't recommend them either.
I have nine years of towing with the same tow vehicle, trailer, and hitch. I have towed in 13 Western States and 3 Western provinces. have towed in zero degree weather and in well over 100 degree weather. My tow vehicle just turned 110,000 miles. I have been up many mountains; Colorado being the toughest. To this date, I have the original trans and have it serviced every 30,000 miles.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
03-16-2014, 05:59 AM
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington
, Ontario
Check out Tru-Cool automatic transmission coolers. They are self regulating via the transmission fluid viscosity. I have used them on my Jeeps because I tow in a variety of weather conditions ranging from freezing to hot. When it is cold, no additional cooling is provided but when the fluid heats up, extra cooling is provided. Jim
03-16-2014, 07:02 AM
1981 31' Excella II
New Market
, Alabama
The best way to tell if you need a cooler or not is to monitor transmission temperatures and see how hot it runs while towing. I use a scangage II to monitor all sorts of stuff. If you start running over 200 F, I would get a cooler. Also be careful on adding anything that can restrict oil flow. Pappy's rig may not work on your truck. External filters can restrict flow so you need to do your homework on what you can and can't do as far as filters and coolers. I was able to get a stock Ford cooler for my Excursion that came off of a 6.0 l diesel version. It was 3 times bigger than my old one. It is almost too big.
Perry
03-16-2014, 08:13 AM
2019 23' International
La Habra
That's what I'd like to do as well. I'd ill to know if the stock Allison trans cooler from a Duramax powered truck is bigger than the external cooler in my 2008 Tahoe. I'd like to have a little more cooling for the summer months. Would anyone here know?
2019 GMC Sierra Denali
2019 23CB International
03-16-2014, 08:27 AM
Garden Valley
, Idaho
You can monitor tranny temps all you want, but when it does get hot on the guage, it's too late, the tranny is fried. For an extra $200 for both an extra cooler and external filter, you are just adding to the safety and longevity of your tranny. I have the external filter on my wife's Lincoln LT as well. Neither have ever leaked. When your tranny goes south, it will cost upwards of $4,000 or $2,000 at a minimum. I also recommend a Transgo Tugger Shift kit for around $100 that replaces a lot of the factory plastic parts and firms up the shifting and also saves the internal clutches.
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
03-16-2014, 09:59 AM
Maniacal Engineer
Lopez Island
I've overheated the transmission in our F250 pickup a couple of times as it started to leak fluid out the overflow; this is what prompted me to install a autometer gauge and a large B&M cooler. Since then we've not exceeded 200F on the gauge even in long 100F ambient pulls in second gear.
I will note that the trasmission changes temperature slowly; there's plenty of time to see that it may be getting a little warm.
- Bart
03-17-2014, 10:50 PM
Eugene
, Oregon
Ah yes, the extended warranty... that isn't really a warranty but an extended service contract.
So that's going to be governed by the terms of the contract as limited by contract law. I guess OP should probably read his contract.
