Old 03-16-2014, 08:27 AM   #15
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
You can monitor tranny temps all you want, but when it does get hot on the guage, it's too late, the tranny is fried. For an extra $200 for both an extra cooler and external filter, you are just adding to the safety and longevity of your tranny. I have the external filter on my wife's Lincoln LT as well. Neither have ever leaked. When your tranny goes south, it will cost upwards of $4,000 or $2,000 at a minimum. I also recommend a Transgo Tugger Shift kit for around $100 that replaces a lot of the factory plastic parts and firms up the shifting and also saves the internal clutches.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 03-16-2014, 09:59 AM   #16
Maniacal Engineer
barts's Avatar
Menlo Park , California
I've overheated the transmission in our F250 pickup a couple of times as it started to leak fluid out the overflow; this is what prompted me to install a autometer gauge and a large B&M cooler. Since then we've not exceeded 200F on the gauge even in long 100F ambient pulls in second gear.
I will note that the trasmission changes temperature slowly; there's plenty of time to see that it may be getting a little warm.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 03-17-2014, 10:50 PM   #17
phbarnhart's Avatar
2012 25' FB Eddie Bauer
Eugene , Oregon
Images: 14
Originally Posted by jcl View Post
Doesn't that relate more to manufacturer's warranty on new products, as opposed to service agreements on nine year old used vehicles?
Ah yes, the extended warranty... that isn't really a warranty but an extended service contract.
So that's going to be governed by the terms of the contract as limited by contract law. I guess OP should probably read his contract.
phbarnhart is offline   Reply With Quote
Automatic Transmission Cooling. Keyair Mechanics Corner - Engines, Transmission & More... 9 02-08-2012 09:37 AM
245 degree transmission oil on long steep grades ashe Towing, Tow Vehicles & Hitches 29 02-05-2012 06:18 AM
Coleman Thermoelectric Cooler Olivebranch Refrigerators 5 01-22-2012 08:00 PM
Transmission won't shift gear Packerfan316 Land Yacht/Legacy Motorhomes 2 05-18-2011 08:39 PM
G.V. Unit cooler. anyone hook one up John H. General Motorhome Topics 5 04-07-2011 07:15 PM
