Old 04-06-2019, 09:22 AM   #1
2019 22' Sport
Quartzsite , Arizona
Transferring Hitch to New Tow Vehicle?
Howdy,
Towing a 2019 Sport 22FB with an Equalizer brand hitch
Traded my Tacoma for a Tundra
I'm sure I'll have some adjusting to do but how do I proceed initially in regards to ball and hitch height? Should I just hook it up and take those measurements as being under load a consideration or try to match my previous TV ball height to start?
I read and watched videos on Equalizer's web site and it doesn't give me a starting point, only minor tweaks once close....
Any other advice welcomed.
Rounder44
Rounder44 is offline   Reply With Quote
Old 04-06-2019, 09:49 AM   #2
2019 22' Sport
Malibu , California
Went from Highlander to Mercedes GL for new 22. Measured ball hight on Toyota and then put on MZB and found it was 2 inches lower. Drove MZB to dealer with hitch and they lowered it. Husky brand and simple for them to drop the ball down one hole
Garfish is offline   Reply With Quote
Old 04-06-2019, 09:50 AM   #3
2004 19' International CCD
Longmont , Colorado
We recently installed our Equal-i-zer on our Tacoma. On the Equal-i-zer page buried within the support section, a couple of menus down, there are some measurements and guidelines you take to get your initial height settings for the ball on the shank.
We found this got us really close and into the right holes on the shank, then it was fine-tuning from there:
https://www.equalizerhitch.com/manua...-head-to-shank
Hope this helps, and congrats on the Tundra We've loved all of our Tacomas over the years!
PS: Though you should measure your own Coupler Height, the coupler on our 19' was at 17"...
cstein is offline   Reply With Quote
Old 04-06-2019, 10:42 AM   #4
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
I towed a 22 Sport with an Equalizer hitch. I found out that with proper loading of the car and trailer I didn't need the hitch anymore. It tows fine without the hitch and of course it is a lot easier to hitch up.
out of sight is online now   Reply With Quote
Old 04-06-2019, 11:51 AM   #5
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Reused the Hensley Arrow hitch from our 2013 25FB International Serenity onto our 2015 23D International Serenity we upgraded to 15” wheels and the same size Michelin tires we had on the 25FB. Used same 2007 Mercedes ML320 CDI turbo diesel tow vehicle. No adjustments were necessary. The 23D scales 6,069 pounds camping loaded and the Mercedes is happier with that load.
Old 04-07-2019, 10:53 AM   #6
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Short Answer: Measure your height from ground from old one, then match that to your new one.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Can anyone help with info on transferring ownership from CT to PA and proper tagging jackster1962 Our Community 17 09-21-2018 12:36 PM
Transferring Equalizer from '16 F250 to '17 F-250 DarrellT Towing, Tow Vehicles & Hitches 1 09-28-2017 11:15 AM
Transferring Gray Water to Black Tank BoscoMN Plumbing - Systems & Fixtures 7 01-11-2016 06:22 PM
New tow vehicle, now have a hitch question. dannyo Hitches, Couplers & Balls 8 05-29-2009 01:42 PM
New Owners - Tow Vehicle and Hitch Comments Claybuster Hitches, Couplers & Balls 6 06-12-2005 08:41 AM
