Old 07-19-2016, 08:30 AM   #1
1967 30' Sovereign
Chesapeake , Virginia
Trailer valets
I have seen some posts about the Power Mover, but am wondering if anyone has used the Trailer Valet XL....smaller and does not require battery, chain driven. Tongue weight up to 1000lbs and trailer up to 10k lbs. I was able to tow my 30 footer into my driveway forward with my truck and amazingly left myself enough room to wiggle my truck out considering the space. area is level and smooth, but looking for something to turn trailer around without trying to wiggle my truck back into tow position.
83spyder is offline   Reply With Quote
Old 07-19-2016, 08:47 AM   #2
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
I have used two versions of the trailer valet for the past several years with good results. You do need a smooth surface, concrete or wood etc... for it to work well. If you use it on gravel it will bog down on you. The latest model has a ball that screws into the receiver of your trailer. In my experience, you have to move very slowly by hand cranking the unit because the ball likes to work loose and the trailer can get away from you. I tried the drill like they show on their web site. It didn't work out so well.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
