Old 01-15-2017, 03:31 PM   #1
2017 27' Flying Cloud
Ocala , Florida
Trailer Valet XL - experience?
I currently have a 23 foot travel trailer that weighs 5500 loaded +/- and the tongue weight is about 480 lbs
I move it in my rather tight parking area with a Trailer Valet XL. I like how it works with my dewalt 18v drill.
Their specs say this model is good for up to a 10,000 pound trailer and 1000 lbs tongue weight.
Has anybody used one of these on an AS. I am getting close to pulling the trigger on a 2017 Flying Cloud 27FB -- the tongue weight is north of 850
Has anyone used the Trailer Valet XL on a 27 or larger AS?
Thank you
Mike
Mikenbern is offline   Reply With Quote
Old 01-19-2017, 10:39 AM   #2
DaveP's Avatar
2004 28' Classic
Monument , Colorado
I have one for my AS Classic 28 which averages around 8200 #s. I also am backing it slightly uphill into it parking spot. Works great!
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 01-20-2017, 02:14 PM   #3
Zionsville , Indiana
I pulled the trigger on one yesterday. We'll see how it works but I think I will be pleased. I also needed to get the ProPride Lot Bar and locking plate. All in, I think this will save me a lot of frustration putting the 26U into the storage garage. And possibly maneuvering in tight camping spaces.
The TV-XL is 50lbs. The Lot Bar is probably another 20lbs. This hitch equipment is heavy!
DRPREECE is offline   Reply With Quote
Old 02-01-2017, 12:14 PM   #4
DaveP's Avatar
2004 28' Classic
Monument , Colorado
BTW, the instructions for using the Valet are not completely clear. Once you put the correct hitch ball on it, put it into the receiver, lock the ball in place, then tighten the collar up against the bottom of the receiver. That way, the Valet will not end up tilting from side to side.
DaveP
Old 02-16-2017, 01:23 PM   #5
2016 26' Flying Cloud
Spooner , Wisconsin
I appreciate this thread as I too am looking at the TV to push my 26U around. I've used a manual trailer dolly on lighter (2k lb boat, ~200 lb. tongue) and the handle has enough leverage to keep the ball pointed up and the hitch directly over the dolly axle. It isn't clear to me how this retains that "straight up" orientation. That handle doesn't look long enough to control the 900 lb. tongue weight.
I don't have to go up a hill, but it is packed ground, not a hard surface and there are some lumps and dips in it. Does it seem likely to work on that, from your experience?
WherryWillie is offline   Reply With Quote
Old 02-16-2017, 02:16 PM   #6
Spooner , Wisconsin
Friends,
I looked up some additional videos (the e-trailer one in particular) and reread your earlier posts and I guess my questions are answered: that locking sleeve keeps in up-right, and he shows it rolling over gravel.
I think I'm going to get one of these things.
It appears to me that the 26U, with 903# tongue wait is inside the specs and will save me cutting a bunch of trees.
Old 02-17-2017, 05:43 AM   #7
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
I use mine on a packed gravel driveway. At times I need to lay plywood down and travel over that because the Trailer Valet will bog down into the gravel. It's not hard to do and I have used the Trailer Valet for four years. I started with the original model and upgraded to the XL last year when I bought my new Airstream.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 04-12-2017, 09:35 PM   #8
Lake Forest , Illinois
Drill recommendations
I have parking valet XL - Black & Decker 20V cordless with Flying Cloud 27FB won't cut it... any recommendations on best drill for this? Thanks so much.
kjbishop2 is offline   Reply With Quote
Old 04-13-2017, 03:34 AM   #9
Ocala , Florida
I now have my Flying Cloud 27 FB and the Trailer Valet XL works great using the Dewalt 18v drill
One note ~ be sure to put the plate that is on the top of the collar facing with the lip in front ~ this help prevent any tilting
Old 04-13-2017, 05:50 AM   #10
I prefer to crank it by hand and have total control over the speed and direction. When I tried a drill, it was too fast and didn't feel as safe.
Old 04-13-2017, 07:53 AM   #11
DaveP's Avatar
2004 28' Classic
Monument , Colorado
There are two points to attach the drill. The lower one is a low gearing and gives more power (and less effort for the drill). The upper point is a higher gear and will move the trailer along more quickly on a flat surface (but requires the drill to do more of the work).
I have a 28 foot Classic. I have to move my trailer up a slight incline into its parking place. Works just fine with an 18V Milwaukee and the low gear (or with the crank).
DaveP
Old 04-13-2017, 07:56 AM   #12
2015 30' FB FC Bunk
Ayer , Massachusetts
It says max tongue weight of 1000lbs.
I am slightly over that with my 30FB at 1150 lbs with propane.
Anyone pushed the limit?
Ted S. is offline   Reply With Quote
Old 04-14-2017, 07:37 AM   #13
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Hi Mikenbern,
Just curious. What plate are you talking about? Can you take a picture? Trying to figure out if this is something new that they have added.
Thanks.
DaveP
Old 04-14-2017, 07:54 AM   #14
Ocala , Florida
ID:	283380Click image for larger version
Hope this helps
Trailer Valet on Bambi Sport tjwoods1 2005 and newer - Bambi all models 47 05-08-2019 06:05 AM
Further experience with GMC Sierra 1500/6.2/max trailer tow pack truck DC Bruce Tow Vehicles 31 11-14-2015 07:52 AM
Trailer valet (two available) Gsmblue Airstream Classifieds 0 10-28-2015 12:44 PM
Wanted: wisdom and experience. And a trailer lifestyle Oneshot Buyer Guidelines 32 03-29-2015 08:35 PM
Nomadica Vintage Trailer Experience Top Commercial Listings 10 02-14-2012 08:50 PM
