Old 08-13-2012, 04:19 PM   #1
1965 20' Globetrotter
New Braunfels , Texas
Trailer tongue jack replacement
So we have sold our 64 Globetrotter due to a growing family and purchased a 1959 Streamline trailer. The other day my brother in law was moving the trailer and broke the manual tongue jack for the trailer. The only problem is that when I started looking for a replacement (electric or otherwise), I haven't been able to find anything that would fit with the bolt pattern to mate the jack to the trailer.
All of the jacks I have found have a 3 hole mounting system with a circular tube. Ours has a 4 hole mounting system with a non-circular tube. I have attached a photo, and if anyone would be able to steer me in the right direction I would be very much in your debt!
Skycop is offline   Reply With Quote
Old 08-13-2012, 04:24 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Did you look at the underside? Maybe the PO replaced the original jack with the one you now have the original bolt pattern is still there.
Richard
Old 08-13-2012, 04:37 PM   #3
I will pull it and see what I can come up with.
Old 09-03-2012, 03:37 PM   #4
So I am trying to pull the jack. The pad/foot on the jack is a booger to get off. From what I can tell, this thing comes with a 4 hole bolt pattern on the trailer. Any help would be appreciated and I am back to getting the jack removed.
Old 09-03-2012, 04:27 PM   #5
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
A good machine shop can probably fabricate and weld a three hole plate to your trailer tongue that will match the three hole plate on the jack
bimpy is offline   Reply With Quote
Old 09-04-2012, 06:22 AM   #6
I did manage to get everything off and yes, it is a 4 bolt pattern jack. Weird, but I will be doing some research on my own, but if anyone else has experienced this, I would appreciate any input.
Old 09-04-2012, 07:50 AM   #7
1977 Argosy 24
Milltown , Wisconsin
Buy a 3 hole jack, open up the center hole if needed. Set the new jack into the enlarged center hole and mark & drill the tongue to match the new 3 hole jack. Done!
ventport is offline   Reply With Quote
