Old 06-17-2019, 06:14 AM   #1
2019 28' International
Murphy , Texas
Trailer Sway
I have moved from a 19CB Tommy Bahama to a 2019 28' International Sig 28RBQ and when towing it home from Austin to Dallas, I noticed a significant difference in how the wind from 18 Wheelers affected the trailer (pushing it around quite a bit). My TV is a 2018 Ford F-150 and my hitch is a Blue Ox. I'm guessing this is fairly normal since there is a lot more surface to push.. ????
Jkreis is offline   Reply With Quote
Old 06-17-2019, 06:25 AM   #2
1981 31' Excella II
New Market , Alabama
Does the Blue Ox have sway control? This is a topic like motor oil on a car forum. You are going to get comments from the elitists that tell you that you have to spend $6000 on a Hensely or Pro-Pride hitch. I am using old school sway bars that are adjustable and work well when used properly. It is basically a linear brake that damps out sway. Without it anything above 50MPH is a no no. You will feel a tug at the steering wheel when something passes but you will adapts. I think my rig is more stable than the truck alone.
Perry
Old 06-17-2019, 06:29 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Maybe you have the WD tightened down too tight?
Is that possible?
J. Morgan is online now   Reply With Quote
Old 06-17-2019, 06:38 AM   #4
VeloBuckeye's Avatar
2018 27' Flying Cloud
Easton , Pennsylvania
Jkreis,
I recently went from a 19' non AS trailer (3000 lbs) to a FC27 (which is actually 28' feet long) that is about 5900 lbs. Had a Blue Ox Sway Pro on the smaller trailer and simply moved it over, but upgraded the sway bars to handle the higher tongue weight. My TV is also a 2018 F150.
My suggestion is to experiment with which chain link you lock into the latches. When my AS dealership first hooked it up, I noticed what you have. While I realize I was now towing a trailer that was now 9 feet longer, it was also twice as heavy. After three trips using various links, I found the sweet spot which ended being "tighter" than the original setup.
I also checked my tongue weight on a scale just to make sure all was in range.
VeloBuckeye
2018 Flying Cloud 27FB
2018 F150 Lariat PowerStroke Diesel
VeloBuckeye is offline   Reply With Quote
Old 06-17-2019, 06:48 AM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
OP - did you ever weigh your other rig (3-pass method on the scales) and if so, have you done the same with this rig and compared notes? Lots of components work together to make a rig stable - tires, tire pressure, shocks, level, hitch, etc....lots of threads here on BlueOx in particular that may be helpful for your diagnosis and setup.
Originally Posted by perryg114 View Post
Does the Blue Ox have sway control? This is a topic like motor oil on a car forum. You are going to get comments from the elitists that tell you that you have to spend $6000 on a Hensely or Pro-Pride hitch. ...snip...
No, I would just recommend a $100,000 1-ton dually diesel....
(Remove tongue from cheek...)
Elitists? Wow - thatís what it boils down to?
As an Airstream owner yourself - how do you feel when others assume youíre an elitist for owning such a pretentious excuse for camping? Oh - youíre not an elitist? Great. Welcome to the club.
And the VPP hitches are less than half your inflated insult price and 10x worth the value - but Iím an elitist snob, so.....
Sheesh.....
SteveSueMac is online now   Reply With Quote
Old 06-17-2019, 06:50 AM   #6
Baltimore , Maryland
If the trailer wasn’t loaded to travel then you will probably need to make adjustments anyway. Start over and readjust the hitch per the TV manufacturers guidelines.
Profxd is offline   Reply With Quote
Old 06-17-2019, 06:55 AM   #7
2007 25' Safari
Rogers , AR
When towing our 24' Keystone (shaped like a brick) with our Porsche Cayenne to Banff last year, we talked to several campers with Trucks/Blue Ox style hitches that experienced sway during their journey.
We used an Andersen hitch and never experienced ANY sway. We even had semis blow my tow mirrors in on me more than once.
Mr. Merk is offline   Reply With Quote
Old 06-17-2019, 07:00 AM   #8
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
Try increasing your rear tire pressure and adjusting your hitch to get more weight onto the rear axle (without going over the GAWR).
Your tow vehicle is a bit light to be pulling a 28 so it will sway a little when being passed. It's normal.
out of sight is offline   Reply With Quote
Old 06-17-2019, 07:14 AM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
(Just FWIW, My trailer doesn't sway at all when I'm being passed by anything, not even one iota)
Old 06-17-2019, 07:19 AM   #10
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Sheesh.....
And yet in the end, we get to drive the drive of "like it's on rails"....... no matter what they say...
Old 06-17-2019, 07:24 AM   #11
2019 30' Classic
Belen , New Mexico
Perry
Did I get cheated? Where do I send the other $3000?
Here is the funny thing. My TV is a 2006 Dodge 2500 Hemi. Sometimes, in the words of the 10 year old boy on our last trip, I get accused of having a "sweet truck". Other claim I'm elitist because it's a 3/4 ton and not a 1/2 ton. Sometimes, I get told I have an awesome trailer and sometimes I get told I'm an elitist because it's an Airstream. Here, sometimes people say "I wish I had that Pro Pride hitch" and others like you claim I'm an elitist without ever having met me.
Whatever. I drive in comfort and style with ZERO sway.
By the way, I'd never even heard of Pro Pride. The trailer came with an Equalizer hitch from the dealer. I was telling my neighbor, who owns a box trailer, about my trailering experience and he showed me his Hensley. The next day, I researched and bought the Pro Pride. Never looked back with buyers regret either.
The fact is, it's My truck, My trailer, and My hitch bought with My money.
Calling someone an "elitist" because they made different choices than you sounds a bit like envy.
Ephraim is online now   Reply With Quote
Old 06-17-2019, 07:30 AM   #12
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I must have really gotten cheated, I paid $1,200 for my used Hensley.....
Old 06-17-2019, 07:35 AM   #13
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
The trailers I see swaying the most are the ones traveling over 65mph.
Kay
Old 06-17-2019, 07:40 AM   #14
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Trailer Sway
You and I share the same year and model trailer.
Without anti-sway, my trailers propensity toward swaying starts at about 62 MPH.
The tendency is multiplied when going down hill and when being passed by big trucks.....
I think there's a reason that Wally sold these trailers with a "speed limit"......
Sway bars and sway control phibbs Towing, Tow Vehicles & Hitches 1 09-03-2012 05:48 AM
To sway or not to sway? cojer 1966-68 Caravel 11 03-15-2011 03:23 PM
67 Caravel Help: to sway or not to sway vonzellen Hitches, Couplers & Balls 15 01-26-2011 05:07 PM
to sway or not to sway... rayandre Hitches, Couplers & Balls 9 12-01-2010 06:52 AM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
