Old 09-13-2010, 02:22 PM   #15
r carl's Avatar
Lin , Ne
This alarm activates the trailer brakes, has GPS tracking and calls your cell phone.
GPS Tracking Security System, Trailer Dog Security System Products - TD 2000 G - Theft Deterrent System, Real-time GPS Tracking, Geo-fencing, 2 Way Cellular Communication, Security for Trailers with Electrical Power Source, Security Systems, Trailer
Old 09-13-2010, 02:49 PM   #16
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
that Trailer Dog thing seems pretty nifty, though hopefully the GPS/cellular lives in a different hidden box so if a determined thief stops the alarm and brake-activation part, you can still track its location with the GPS system.
Old 09-13-2010, 03:08 PM   #17
walter1's Avatar
1964 22' Safari
Foresthill , California
What is a workable hitch, couple, latch lock set for older (1964) single axle Airstream with 2” Marvel hitch?
Trying to s l o w them down, can’t stop them.
walter1 is offline   Reply With Quote
Old 09-13-2010, 03:13 PM   #18
2003 22' International
Waverly , Pennsylvania
I have to admit that I don't do anything to deter theft. Crazy? Probably!
I'm insured for replacement value, but who determines that - ultimately the insurance company. Unfortunately my trailer is financed, so I probably owe more than the current book value.
I figure if someone wants to steal it, it's going to happen and lock's aren't really going to help.
nayl is offline   Reply With Quote
Old 09-13-2010, 07:54 PM   #19
drew05's Avatar
2011 25' FB Flying Cloud
Peculiar , Missouri
I would like to thank everyone who has responded! Your advice and suggestions are very helpful, as were the links to other threads.
Thanks Again
drew05 is offline   Reply With Quote
Old 09-13-2010, 08:24 PM   #20
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Wish I had read this thread about 2 weeks ago. Airstreams are very desirable and a simple tongue lock or master lock on the hitch won't slow down a pro thief. Get some serious steel on your wheels. Mike the fixit said it right. On mine they couldn't get the electric lift to work cause the battery was dead so they tore the cover off it and found a way to get the trailer down on the ball, maybe hot wired it with a battery or maybe there's a manual way to disengage the gear. They came prepared that's for sure. So like Mike said use four different ways to deter them, then put a GPS tracker inside the unit, a motion alarm on the outside. If someone can see it they will want it and they will find a way to take it.
RichHog is offline   Reply With Quote
Old 09-13-2010, 08:35 PM   #21
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by jglabrown View Post
Looking at the Guardian G-37 in the above photo, it seems to me you could accomplish the same thing by inserting a hitch ball into the coupler and then locking the hitch.
Easily Defeated.
Whack right above the lock. The Latch mushrooms and the ball falls out.
Or if the shanks is still on it pull up with a stinger with no ball and off you go.
I use a lock simular to Robertsunus. His will work on a Safari but not a Classic. The lip is too tall.
Michelle TAC MT-0
Sarah, Snowball
Old 09-14-2010, 07:32 AM   #22
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
I'm thinking something like a bear trap coupled to the hitch. One wrong step and the thief will regret it.
Old 09-14-2010, 04:56 PM   #23
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I don't know how you can say that, "the G-37 will work on a Safari, but not on a Classic." I added a rubber horse shoe, cut from a tire side wall to make it fit tighter on my coupler; And I'm sure it will fit a Classic too with out any grinding like you said you would have to do with the Gorrila brand that you bought.
If you look inside of the second picture, you can see the rubber horse shoe glued inside of the top section.
ID:	110768   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-14-2010, 06:07 PM   #24
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
Has anyone thought of installing an insulated, hidden switch that would reverse the hot and ground while the trailer was stored and on shore power. It happens often enough accidentaly that you could claim ignorance when they came to haul the body away. Most likely the thief would give up after the second touch, but you would need some way to hide or lock up the electrical hookup.
Probably not a legal thing to do, but would sure be fun to watch the attempted theft.
Sam
samb is offline   Reply With Quote
Old 09-14-2010, 06:16 PM   #25
Salem , Oregon
Images: 18
Sam
Hi, this would only be good if your trailer could tell the difference between a thief and a innocent little kid. [or any other innocent person]
2005 Safari 25-B
Old 09-14-2010, 06:57 PM   #26
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
I think post no# 15 has the right way to go about a theft. This creates the event of catching the thieves redhanded and thrown in jail or even prison where those idiots belong. Furthermore a lot of simple phones have GPS built into them....you could almost leave one charging in a hidden place all the time...
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 09-14-2010, 07:16 PM   #27
Sam
Sam.
Excellent idea................of how to make an attorney, RICH.
Old 09-14-2010, 07:26 PM   #28
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
The goal for most owners is to make their trailer a more difficult target then the one down the street, that's about all we can do. Wheel boots help, but like any deterant can be defeated. Insurance is a must, but especially for vintage trailer owners replacement can be difficult or impossible.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Trailer Security (Preventing unauthorized towing) Craig Our Community 45 02-02-2016 04:43 AM
Enough security already! Melody Ranch Forum Admin, News and Member Account Info 11 07-21-2009 06:27 PM
travel trailer security bluegrass Our Community 6 09-04-2005 09:05 PM
Security... canny_banjo_man Our Community 14 06-18-2003 03:34 PM
