Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 09-03-2016, 06:03 PM   #1
Cispook's Avatar
2017 27' Flying Cloud
Greer , South Carolina
Trailer Dollies
Anyone have a preference or experience to share? Looking for pro and con.
I live on a private road with 5 homes; if my neighbor across the road is home I'm forced to pull straight in and then later maneuver out and park the AS. He is a super guy and I asked once to give me another few feet of clearance so I can cut back ... He did so one time. Bottom line is its my problem and not his.
I had my brother in law stop over and give me some technique and options as he is a professional truck driver. His first comment was "you're in a tough spot and there is no work around etc".
He took the wheel and it took him 10 minutes and 25-40 moves to get the trailer backed in. Confirming I need better options for getting the AS on site and in position.
I noticed everything on the Google search from non-powered to remote controlled battery operated with braking. Keep in mind that this will stay at home and not be going on the road with us.
Cispook is offline   Reply With Quote
Old 09-04-2016, 08:44 AM   #2
centennialman's Avatar
2016 23' International
Centennial , Colorado
I have to manuever between an overhead (big one) on a mid century modern house and a 40 foot scotch pine tree with a sharp turn back towards the storage shelter for the Airstream. I have used this for several years and it does the job. You have to go slow but it does work. Good luck! https://www.trailervalet.com/
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 09-04-2016, 08:55 AM   #3
Cispook's Avatar
I see they have an XL model. All I need to do is pull in and spin the trailer 180 and the back it up 8'. I would be happy with the spin and rebook to truck to back up. Thanks for your input.
2017 27FB FC
Old 09-04-2016, 09:46 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Found this, if it could be adapted for an Airstream might be nice to have.
http://www.easi-move.com
MICHAEL
Old 09-04-2016, 11:47 AM   #5
Cispook's Avatar
That is wild.
2017 27FB FC
Old 09-04-2016, 01:10 PM   #6
Reeds Spring , Missouri
What about putting a hitch receiver on the front of your TV? Flip the TV around once your home, and then back the trailer, while you are going forward. Watching might give you more control. Ask your B-I-L about that idea.
Connie M is offline   Reply With Quote
Old 09-04-2016, 09:03 PM   #7
2016 30' Classic
Houston , Texas
I use a ParkIt 360 dolly for reasons similar to your requirements. Works very well.
dhroberts is offline   Reply With Quote
Parkit360 Trailer Dollies dhroberts Towing, Tow Vehicles & Hitches 12 08-28-2018 08:04 AM
2-Wheel Tow Dollies hmsteader Land Yacht/Legacy Motorhomes 17 11-03-2009 04:43 PM
Hand Dollies -- Anyone Use One BillM2 Towing, Tow Vehicles & Hitches 40 07-09-2009 08:45 AM
Powered Trailer Dollies... GolfStream Tow Vehicles 18 03-05-2008 04:09 PM
