Old 08-14-2015, 10:18 AM   #1
Peterborough , New Hampshire
tpms
I have a 2010 23 foot flying cloud AS and have just installed a tire pressure monitoring system. I said in the instructions to set the tire pressure before linking it with the monitor, but do not use the pressure printed on the side of the tire unless it is the correct amount. I guess what I want to know is what is the proper amount of pressure is when the tires are cold?
terrylarock is offline   Reply With Quote
Old 08-14-2015, 11:04 AM   #2
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
I am pretty sure 60PSI is recommended pressure when cold
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 08-14-2015, 11:11 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Welcome...
You should set the 'cold' pressure each day before towing. There are many discussions about this... Roger Marble, a retired tire engineer, has this website with solid info.. RV Tire Safety
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-14-2015, 11:27 AM   #4
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
The tire pressure should be on the street side of your trailer on a metal tag. It should have the Cold tire pressure rating for your trailer. The pressure on the tire is the max PSI, also cold tire pressure.
I have an 2008 Safari 23 ft and you should have C rated tires which should be kept at 50 PSI Cold reading.
Sphere Guy
AIR 50601
Sphere Guy is online now   Reply With Quote
TPMS - Dill internal mount system wingfoot321 Tires 10 04-19-2016 08:39 AM
Why TPMS is worth it - in my case a DILL TPMS DaKarch Tires 2 08-04-2015 08:37 PM
Valve stems and TPMS cosmotini Wheels, Hubs & Bearings 8 08-06-2013 07:28 PM
Thoughts on TPMS mwells4654 Tires 33 11-02-2010 04:20 PM
Another TPMS... reday Tires 3 07-05-2009 04:53 PM
