Old 02-21-2013, 05:20 AM   #1
sandhill3000's Avatar
2013 19' International
Englewood , Florida
Toyota Tundra - Weight Distribution Hitch Question
Just purchased a 2013 19' International
GVW 4500lbs
hitch weight 550 lbs without cargo and water
I will be towing with a 2010 V8 5.7L Toyota Tundra with factory tow package
I have towed small boat trailers and a tent camper in the past without a weight distribution hitch but they were lighter. I have no experience with weight distribution hitches and I want to travel safely. I am wondering if I really need a weight distribution hitch with this size trailer.
Are any of you using a similar tow vehicle with a weight distribution hitch (type?) and are you satisfied with it?
Thanks in advance!
sandhill3000 is offline   Reply With Quote
Old 02-21-2013, 06:06 AM   #2
SteveH's Avatar
Common Sense , Texas
Welcome to the forum. I don't have a Tundra, or a 19 footer, but know folks that do, and they do not use a WD hitch. However, if it were me, I would use one because it would help the ride and handling of the rig.
I would only advise you to not get too big of a hitch for that weight trailer. I think you would want a hitch rated for 600 pounds of tongue weight, max.
Regards,
Steve
Old 02-21-2013, 06:08 AM   #3
aquinob's Avatar
Portsmouth , Virginia
Absolutely you need a WD hitch on this rig. The dealer you bought the trailer from should be able to sell you one and install and set it up for you. The WD hitch locks the rear of the truck to the front of the trailer in a single plane and prevents porpoising as you go over bumps. Some hitches also have sway control, which you may want, but might not be that critical on a 19 foot trailer. You may need some sort of helper springs on the truck as well if it goes down more than a couple inches with that tongue weight. I'm planning on some air helper springs when I get mine back on the road this spring.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 02-21-2013, 10:19 AM   #4
1988 32' Excella
Robbinsville , New Jersey
IIRC Toyota recommends weight distribution with more then 500lb tongue weight and sway control over 3500lb trailer weight.
You can buy a WD hitch where you bought the trailer and they should be able to properly install the hitch, you must insist on the correct bars they will try to sell you what they have in stock which might DAMAGE YOUR TRAILER. The information many dealers go by states the weight rating on the bars is the max tongue weight the bars can handle and will work with any tongue weight less then that rating, this is not true with an Airstream.
They might set it up right, from my experience and what I have read you would have a 1-in-10 chance of the dealer setting it up 100% correct and if you change the load in the trailer the hitch may need to be adjusted to be correct anyway. So you should learn how to correctly setup the hitch yourself.
Old 02-21-2013, 11:10 AM   #5
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Regardless of the tow vehicle, I'd always recommend weight distribution. Much better to have that load spread across front and rear axles, and some to trailer just for good measure. I'd also have some sway control; it may not be vital but it's extra insurance.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 02-21-2013, 12:22 PM   #6
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I have this exact set-up; 19' Bambi towed with a 2010 Toyota Tundra CrewCab.
Yes; you need a WD hitch. The overall control of the tow-vehicle and trailer is vastly improved. I simply would not even consider towing without a WD hitch.
Steamy1 is offline   Reply With Quote
Old 02-22-2013, 02:59 PM   #7
Englewood , Florida
Thanks to all of you for your input on this. I really appreciate it! I am definitely going with the WD hitch just not sure which one yet.
Old 03-08-2013, 07:54 PM   #8
Puyallup , Washington
Sandhill3000 - when you get your setup drop me a line I'm picking up a 2012 - 19 too and towing with a 12 silverado crew cab 4x4
srpuywa is offline   Reply With Quote
