Old 07-13-2017, 11:49 PM   #1
DrT
Langlois , Oregon
Towing with Surburban
Will it work to tow a Flying Cloud 25 rear twin with a 2015 5.3 liter Surburban, 4WD?
DrT is offline   Reply With Quote
Old 07-14-2017, 09:20 AM   #2
2012 19' International
Southeastern MI , Michigan
Yep.
2018 International Serenity 27' FB
Michelin 16 tires
Hensley Arrow hitch
Tow Vehicle: Ram Laramie 2500 crew cab, Cummins 6.7 Turbodiesel
Countryboy59 is offline   Reply With Quote
Old 07-14-2017, 09:36 AM   #3
DrT
Langlois , Oregon
Short answer, anything else?
Old 07-14-2017, 09:50 AM   #4
2000 30' Excella
Toledo , Ohio
Does it have the tow package ? If not you will need to add a brake control.
woodfox45 is offline   Reply With Quote
Old 07-14-2017, 10:40 AM   #5
2017 19' International
Tallahassee , Florida
I tow a smaller Airstream, a 16-footer, with a much older (2004) Suburban with the same engine (not four-wheel-drive).
It seems to do fine.
WhereStream is offline   Reply With Quote
Old 07-14-2017, 11:34 AM   #6
Might need a WD hitch with that. I never had a trans cooler added on, mine was fine and I towed much heavier stuff.
Loved my Suburbans. Last one was a diesel.
Michelin 16 tires
Hensley Arrow hitch
Old 07-14-2017, 12:44 PM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Suburbans were the standard for towing Airstreams for years. You will need a high quality, capable weight distribution hitch and sway control system set up by someone who actually knows what they are doing, as well as a brake controller. You may need a transmission cooler installed if you don't have one. Keep your truck and trailer loads reasonable, and reduce speeds as needed for climbing and descending steeper grades safely.
Continue learning, the best loading and w.d. hitch expert is you. Ask for advice on the internet and too many just tell you to get a bigger truck. As though money grows on trees.
Doug and Cheryl
Old 07-14-2017, 01:28 PM   #8
abqdor's Avatar
2016 25' Flying Cloud
Albuquerque , New Mexico
We towed our 25' FB for over a year with our '13 Yukon Denali which is basically the same as your Suburban. What we learned was transmission temps would climb dramatically and the short wheelbase (116" ours was not an XL) made us feel like the tail was wagging the dog in strong crosswinds. One of these towing threads suggested 110" wheelbase will tow a 20' trailer and each additional 4" of wheelbase will add a foot more of trailer length. Longer wheelbase does seem to make sense to me.
We just moved up to an F-150 Ecoboost with max tow package, 145" wheelbase, 36 gallon tank, but have not towed with it yet.
'17 Ford F-150 Ecoboost, max tow package
'13 GMC Yukon Denali 6.2L V8
'04 GMC Yukon SLT 5.3L V8
abqdor is offline   Reply With Quote
surburban nt-34sp help needed brummie Furnaces, Heaters, Fireplaces & Air Conditioning 7 06-27-2006 07:24 AM
Surburban furnace caps darryl97420 Furnaces, Heaters, Fireplaces & Air Conditioning 5 09-22-2005 10:05 PM
Surburban Furnace Ills - HELP Cat Furnaces, Heaters, Fireplaces & Air Conditioning 22 07-07-2005 07:22 AM
Surburban 1/2 ton as a Tow Vehicle dmreilly10000 Tow Vehicles 3 12-10-2003 10:45 AM
Surburban Furnace Pilot Cap? Darryl Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-10-2003 09:55 PM
