Old 06-25-2016, 04:29 PM   #43
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I can imagine your building excitement! Have a great time!
Good-looking, well-matched combination.
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
Blessed and highly favored
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 07-15-2016, 08:17 AM   #44
steverino's Avatar
2018 30' Classic
Ivins , Utah
Images: 8
Originally Posted by ghaag View Post
Hooked up today for a test run, heading out soon for the maiden voyage with the tow vehicle to the Oregon coast.
ghaag, please let us know how it goes. The new 3.5 ecoboost F150's torque and payload numbers are all going in the right direction; it will be in the running if I choose to replace my 2010 F250 diesel in the next couple years.
steverino is offline   Reply With Quote
Old 07-20-2016, 06:25 PM   #45
clamb's Avatar
2002 25' Classic
Portland , Oregon
I am really happy with my '16 F150 3.5 XLT screw, towing an '02 Classic 25'. Tongue weight is around 900. I went with the stock Goodyear Wranglers, and it felt quite drifty at first, then I ran the pressure up to the max of 51lbs, and it's good now, but still considering airbags. It's a real comfortable truck for a daily driver,. I got the 6.5 bed, so it is long and has a large turning diameter. I use the trailer backup assist and like it. The new Sync3 is very nice. IMHO, you don't need to go to a higher trim level for the bells and whistles which only rob your payload. I get 12.5MPG.
clamb is offline   Reply With Quote
Old 07-20-2016, 06:30 PM   #46
D44
D44's Avatar
2017 25' Flying Cloud
Lawn Guyland , New York
Switched the hitch to the new 2016 HD payload F150 yesterday. Short tow home from the shop; looking forward to loading up for a real shake-down tripClick image for larger version
Name:	ImageUploadedByAirstream Forums1469060972.344746.jpg
ID:	267391Click image for larger version
Name:	ImageUploadedByAirstream Forums1469060984.561640.jpg
Walt
WBCCI - 29375
D44 is offline   Reply With Quote
Old 07-20-2016, 06:45 PM   #47
2019 30' International
Pennsylvania , Pennsylvania
I've been pulling our flying cloud 25 with a 2015 F150 XLT. It has a 2,007 pound payload capacity. 3.5 ecoboost. No problems.
majorairhead is offline   Reply With Quote
Old 07-23-2016, 07:08 PM   #48
timdude's Avatar
Louisville , Kentucky
Name:	ImageUploadedByAirstream Forums1469322270.863482.jpg
I thinking about ordering a Flying Cloud 26u twin with a second AC unit. I have a 16 F150 Super Crew 3.5 Eco with max tow. Opinions with this combo?
timdude is offline   Reply With Quote
Old 07-23-2016, 09:04 PM   #49
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Originally Posted by timdude View Post
Attachment 267580
Perfection.
Research weight distribution hitches, get the best you can and set it up properly, it's of equal importance to your truck and trailer for a great towing experience. Then it's up to you to manage the weight and position of your loads in the truck and trailer, and learn to operate the truck, hitch, and trailer within their design parameters.
Doug and Cheryl
Old 07-23-2016, 10:59 PM   #50
1972 31' Sovereign
1985 31' Excella
2010 31' Classic
Hendersonville , Tennessee
We have ben running the 150 platinum with tow
package a for a 31 classic limited. Runs like a dreem
NashBuff is offline   Reply With Quote
Old 07-24-2016, 12:32 AM   #51
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Thanks to everyone for the feedback, it was very helpful in making my decision. Here is what I decided to go with.
2016 F-150 4x4 Supercrew
3.5L V6 Ecoboost
Max Trailer Tow Package
36 gallon extended range fuel tank
I am also planning on adding the air suspension kit, anyone with positive or negative experience with those?
Attachment 264784
Attachment 265189
Hi, you do know that you are supposed to drive 1,000 miles before towing for the break-in of your differential. [Looks like you had your truck for about 6 days]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-24-2016, 07:13 AM   #52
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I have a 30' Airstream Flying Cloud and looking for someone who might have experience towing with Ford F150.
Sounds like you made your decision. Good choice. Configured correctly the NEWER F150 should have no problem towing any Airstream currently made. Your question "towing with an F150" leaves it open to any model year, etc. The forum has MANY threads/posts on tow vehicles with many opinions on the best tow vehicle. Some forum members do not refer to payload/towing capacities of their preferred choices AND most salesmen are not familiar with towing AND payload requirements leaving the customer to find out.
Basically the decision should be based on this:
Look up maximum payload and towing capacity of the vehicle of choice. Is it more than the gross weights of the trailer - tongue (payload) and fully loaded weight (tow)?
Payload-wise- do you have enough excess for people and some cargo?
Get a good anti-sway hitch.
My tongue weight is about 100# heavier than Airstream's figure. Many of us find that, I believe to be true so, I would add that much.
As a 2009 F150 owner I would say that my truck's power in steep incline back roads of West Va was marginal. The 2015 Truck is TOTALLY different. It is a bear. I haven't been to West Va since the purchase again but I can tell how power wise, towing- it is BARELY impacted with the trailer back there towing in FL. The other truck strained much more. I was close to the tow limit of that configured truck. This one, I am just over half of the limit- HUGE difference.
If I were shopping right now and considering a F150 I would wait for the 2017. There are two major updates- 1) the second injector modification to address direct injection carbon buildup and 2) the 10-speed transmission. The first one is critical for those who hold on to their vehicles for a while. If you have been reading about the multi-brand issues with direct injection engines, it is pretty big. Basically it has been going on for some time but was brand specific. Now, it has spread across several brands as they adopted the direct injection design in about the last 5 years. BMW and VW/Audi were early adopters, mega problems. Then many others. Toyota came up with a solution, to cool the primary injector with another injector's spray to lessen the carbon build-up. Ford added this injector on the 2017 3.5 Ecoboost redesign. Hyundai, Honda have TSBs, Chevy has the issue as well, compounded by the oil blow-by of the cylinder deactivation. The buildup occurs behind the port where no fuel or oil additive can reach. The cooling of the valve keeps the oil from caking on the back side supposedly. To those with the single injector they say to run em hard! The modern engine dilemma.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 07-24-2016, 07:51 AM   #53
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
F150 pulling 30'
We have had our 2012 EB Supercrew Platinum max tow, short bed since new, pulling 25' AS's. Issues I have so far are 1) breaking on steep inclines coming down a long grade and, 2) turbo cooler starting to overheat in hot weather pulling up long 6%+ grades, as in Riverside to Las Vegas. Caused me to be extra cautious in those conditions. Both cases the weather outside was 100% +. Vegas I dropped from 60 mph to 45 and seemed to drop the temp down pretty quick, but happened to me 3 times over past couple years. For brakes, I just started using the trailer break on the dash to help take pressure off the truck brakes and that seemed to work. Only happened to me couple times on same grade in hot weather, back way to Borrego Springs from Ramona. Pulling up here in the Rockies of Montana, I have had no issues in the 4.5 years we have been towing our 25', even on the long 7% grade up to Banff, but weather was in the 80's.
If I was getting a 30', I would seriously consider a 3/4 T, Diesel with that size rig. That being said, many seem to like pulling a 30' with the F150's. The new 2017 F150 EB has my attention for sure for my next TV, but I intend to stay with 25'.
2015/16 Ford F150 Towing and Payload Research bhougland Towing, Tow Vehicles & Hitches 2 11-18-2015 11:11 AM
Am I stupid ? Ford F150 wingfooted Tow Vehicles 40 03-11-2011 08:33 PM
Ford F150 with 7300 Max. Trailer Wt. ?'s RavenDog Tow Vehicles 35 11-24-2009 09:08 PM
1969 Airstream 8x31 International w/ 1975 Ford F150 eBay Watch Airstreams on eBay 0 06-20-2009 09:10 PM
Towing questions: 1967 Safari with 1994 Ford F150 Billm67 Tow Vehicles 9 06-05-2006 11:01 AM
