12-14-2014, 03:28 PM
Stockbridge
, Georgia
Towing with F-150 - need advice
Has anyone pulled with a new f150 to know how it does? Towing capacity is 9200 and thinking of buying a vintage 29 to 31 foot airstream .
Thanks!
12-14-2014, 04:02 PM
2014 25' FB Flying Cloud
Prescott
Specifications
You'll find that many Airstream owners pull with an F150 however, you may want to be more specific.
Are you referring to 2015 models only or is a 2014 still considered new?
Are you looking at the Ecco Boost or conventional?
What size engine are you interested in?
And if that's not enough to evaluate, you can compare the gear ratios.
I pull a 25 ft. FC with an 2014 F150 5.0 L and so far have been very happy.
Best of luck with your search.
Cheers
12-14-2014, 04:39 PM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
One of the (often) overlooked issues when pulling an Airstream with a 1/2 ton truck (or other even smaller vehicle) is the total payload capacity of the tow vehicle. You need to determine the payload capacity or the proposed tow vehicle and then determine if the total of the hitch weight of the proposed trailer and any cargo you will be carrying in the tow vehicle (which includes the passengers, gear, fuel, cargo AND hitch weight of the trailer) fall within that limit. If it does, then you are generally good to go. Most contemporary 1/2 ton pickups can pull just about any Airstream, it's the payload capacity that gets most people in trouble. The gear ratios and engine choices generally make the towing experience more pleasant, but even the worst possible combination of these factors will generally not make it impossible to tow your Airstream. Oh, and you will be using a properly set up weight distribution/anti sway hitch setup such as a Reese, ProPride or Hensley, right?
Bob Martel
WBCCI# 5766
12-14-2014, 04:46 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
I pull a 1975 Sovereign with an F150 with a 4.6 V-8, it is right at the max for that particular truck. As long as you stay within your capacity ratings (the further in the better) you will be fine. The closer you get to the limits the less comfortable things will be.
Aaron
WBCCI #XXXX AIR #2495
12-14-2014, 05:16 PM
2008 25' Classic
Full Time
In all my research on F150s, Tundras and other 1/2 tons and visiting various forums that specialize in these vehicles I have not read of any reports of engine, drivetrain and suspension failures as a result of towing a travel trailer or 5th wheel. The worse case I've read is some have experienced coolant and transmission temperatures climbing up from normal readings on long grades when its 100F with the AC running. As long as you can't set up the WDH and brake controller correctly, maintain your vehicle/trailer and their tires you should be good to go.
Kelvin
12-14-2014, 06:04 PM
Stockbridge
, Georgia
Thanks, everybody. It's a 2014 4 wheel drive. Looking at towing charts now. We hope to be airstream owners soon. It's always been my dream! . Your replies are encouraging.
12-15-2014, 11:45 AM
Orcs
2014 25' Flying Cloud
Winthrop
First year of towing a 2014 25' FC RB twin with a 2013 F150 6 cylinder eco boost in the Pacific Northwest. Plenty of mountain passes to conquer , lots of 2 lane roads. This is the best truck I have driven and I find towing very easy. No power or overheating problems. I put a topper on the short bed so I can haul my generators, chairs, dog crates etc. 9200 lb towing capacity( you must take these numbers with a grain of salt) and axle and total weight capacity way within limits. I think you should allow about 2000 lbs as a buffer for safe towing.
12-15-2014, 02:58 PM
1972 27' Overlander
Penokee
, Kansas
We pull a 27 foot 1972 Overlander along with a 1200 lb. Yamaha Rhino in the back of our Dodge 1500 pu.. Everything is just fine until we get over 7000 feet pulling a long hill. No heating problems with our Dodge 1500 Hemi,, but sure feel the lack of power from the 98 Dodge Cummins we had before. It was unreal the power it had.. Miss the power but sure enjoy the $1 a gallon discount for fuel....
Flat ground below 6000 feet we have power to spare.
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
12-15-2014, 06:44 PM
Regular Guy
1978 31' Sovereign
Hot Springs
, Arkansas
I have pulled with my wife's Yukon XL and it was like it wasn't there.... If I want to boondock, I have a F Superduty with a 460 ci and the manual trans and a Dana 80 rear axle (5.38:1), it has a 12 ft x 8 foot steel bed that I could haul just about anything with. My point is bigger IS better when towing. Lower RPMs and engine loading are everything. My favorite TV was a 1983 Chev Suburban with the 6.2L diesel. It wasn't fast over the mountains but 20-23mpg on the road at 65mph was awesome.( Remember when diesel was 80 cents a gallon? ) Gobs of Torque make pulling FUN!!!!!! Merry Christmas!!!!!
12-16-2014, 08:46 AM
2005 25' International CCD
Charleston
, West Virginia
Thanks!
Tow vehicles provides two functions: they make it go and they make it stop. Not enough people give enough thought to making it stop. The size and capability of brakes in a 150 vs 250 is quite different. I have had three Airstreams over the last 12 years, two 31's and one 25' i have live in full time for the last 6 years.
I use GMC 2500 diesel trucks. I have had two, I put 250,000 miles on the first one and have 150,000 plus on the 06 I have now, a total of 400,000 miles on the two trucks. I have a very large pay load in the bed of the truck. I carry a 30 amp generator, 15 gallons of fuel, etc, etc.
My recommendation is to buy as much truck as you can afford. Just saying.
12-17-2014, 08:53 AM
Denver
I could afford a 1 ton, maybe more - and it is completely unnecessary to so with my 2012 20 foot Flying Cloud. There are many trade-offs of buying a vehicle that is designed to tow a mansion when you are just towing a small trailer. My recommendation is to buy the right truck - not the biggest truck...
There is such a thing as too big for a given application.
12-17-2014, 12:20 PM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
We are very happy towing our 34' with a 2009 F150 5.4L. There is a very active group of Airstreamers here in GA. Be sure to check us out at secamping.wbcci.net
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
12-19-2014, 12:12 PM
sequim
i was a great believer in 1/2 PUs with gas engines. that is until i started towing my boat, 10K. getting 9-10mpg and having the transmission continually shifting over modest undulations convinced me that something else was needed.
got a great deal on a 1 tone F350 diesel, way overkill for an AS i know. but, towing now is 14-15 and unladen 21-22. this is a 4x4 as well, crew cab with a short bed.
as already advised, check the wheel base before you buy. that makes all the difference in maneuverability of the vehicle and the tow. i have had long bed PUs in the past and this truck is shorter in wheelbase than the last on i owned.
i can tell the difference, easily when i back into locations. way easier, with a slightly shorter wheelbase, about 18" shorter in my case.
with all of my 1/2 tons, i added airbags as the suspension in these trucks is not up to this task. if i were doing this again, i would step down a notch and purchase a 3/4 ton but i could not be more pleased with this truck, running gear and performance.
i did drive all the brands but stuck with the Ford as the GM products seem old and tired and the RAM has a bump in the hood that prevented me from finding the right front fender, even with the seat at its highest position. and very noisy as well.
the F150 will more than likely do the job for you but as advised, watch your overall weight very carefully. that axle and running gear will not like it very much if you overload.
and one last thought, check the fuel capacity. the Tundra's i have owned had a paltry 26g tank.
12-22-2014, 10:26 AM
1984 34' International
Toronto
, Ontario
This is incorrect. First, your trailer should always brake itself. If it doesn't, then there is something fundamentally wrong with your towing setup. Never, ever, rely on your towing vehicle, of any size, alone to stop your rig.
Second, larger trucks don't come with extra stopping power built in. Truck brakes are designed to bring the vehicle plus load to a stop, not the vehicle plus an assumed towing load.
In real world comparisons, you might find that a smaller truck, or even SUV, with a more sophisticated suspension setup will come to a stop considerably faster than a heavier truck, especially if it's an older model.
12-22-2014, 03:19 PM
2001 25' Safari
Ridgefield
I have a 2012 F150 with the 5.0 V8, tow pkg, integrated electric brake controller, and 6.5' bed. I believe it's nearly identical to the 2014 models, but different from the aluminum body 2015 models. I pull a 25 ft Safari with no problems. This is my third tow vehicle and the best I've owned. Everything on this truck just seems to work as it should making the towing experience really nice. It handles inclines and declines well through the mountain passes here in CA. There are several threads here on the 6 cylinder Ecoboost vs. V8 F150s. I think they're all great trucks. The biggest concern for you with the vintage AS you're considering may be the overall weight, hitch setup, and braking capabilities.
12-23-2014, 11:40 PM
2014 30' FB FC Bunk
2+ Years
, Maine
Our 2013 F150 Ecoboost does amazing towing our 2014 Flying Cloud 30FB. We are full-time on the road so we have had plenty of time in tow. Went from a huge F350 and 44ft 5th wheel last May to this setup and absolutely love it. This is also the 3rd F150 I have owned and it is by far the best one yet.
As many have stated having the hitch setup correct and the electric brakes on the right gain is key as well. My wife says she always forgets that we are even have the Airstream behind us.
12-24-2014, 07:04 AM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Thanks!
There is no doubt that the F150 will pull the load you are talking about.
What I would be concerned about is; will the F150 safely carry the payload? As with any 1/2 ton truck, this is their weakness. What is the F150's max payload capacity?
Add up the weight of the people, pets, and other stuff in the cab. Then add the cargo you carry along in the bed. Add the weight of the hitch and sway control to the tongue weight of the loaded trailer. Does that total weight exceed the payload capacity of the F150?
ps: the payload varies with different cab styles, bed length, engine, and gearing. Look at the charts for the specific vehicle. Advertising is deceptively inaccurate.
Alan
