04-01-2012, 06:47 PM
1966 17' Caravel
Bethel Park near Pittsburgh
, Pennsylvania
Towing with an '09 Grand Caravan
I just got a 2009 Grand Caravan with a 3.3 engine and a 4 speed auto trans. I and wondering if any one has towed with this type of van. I own a 1966 17 ft Caravel with a empty weight of 2300 lbs. I do not carry a lot in my trailer. The Caravan book says it is rated at 4000# lbs towing with a tongue weight 400# lbs. I am planning on getting a class III hitch and rear airbags for the springs. Does this sound possible?
Ace in PA
04-01-2012, 08:14 PM
1972 27' Overlander
Penokee
, Kansas
At first I would say no,, but I am no expert on the newer vans by a long shot.. By the specs you point out by the over all scale of things you should be ok... I would pump the info hande off the web as much as possible ,, and from a few Mopar wrenches who know the weak links of your drive train and brakes..
Many on this fourm pull trailers 2 times as heavy with a 1/2 ton PU with at best a 1000 lbs more tow rating than what your are working with,.
Its better to ask a lot of questions to the right people,, and if moved to go ahead to start out careful and slow and work your way up to speeds after one "feels" how stable it all feels from the seat.
Sodbust
04-01-2012, 08:28 PM
Vintage Kin
Fort Worth
Do a search on CAN AM RV and any/all posts by AndrewT as he/they have been setting up vehicles like this for 40 years to pull A/S trailers. Thousands. The subject has been covered in some depth, and there are plenty of threads with plenty of reading.
Short answer: Yes, with proper hitch rigging and possibly some changes to tires, trans cooler, etc. You are unlikely to need/want airbags. Take your time on homework and get it right the first time. The info is all available.
04-01-2012, 08:33 PM
2011 28' International
Chatham
, Ontario
Agree with Rednax 100%. We tow a much heavier trailer with a minivan, albeit not a Grand Caravan, that was set up by Can-Am RV - Andrew T is your man.
04-01-2012, 10:10 PM
NO HUMBLE OPINION
1968 20' Globetrotter
ANN ARBOR
, THE GREAT LAKES
No Problem
I tow my 1968 Globe Trotter with a 2007 3.3, short wheelbase Dodge Caravan.
The weakest link in the system is the 41TE, transmission. All else is well. Love the van. Works great, not scary.
I installed an auxiliary trans oil cooler and a temperature gauge for the transmission.
Chrysler recommends towing in “3” instead of “D”.
Over the Cumberland pass, just to ease the load on the trans, I dropped down to 40mph and used “L”.
With caution, on the flats across Ohio I could hit 80mph in “D”.
Most of the time, I'm in “3” like Chrysler says, and going 65mph, but the gas mileage drops to 11.
The 3.3 engine doesn't care, and runs fine.
When able, I loaf down the hills in “D” and pick up some speed.
OEM shocks are marginal, so I installed coil-over Monroes on the back. I have a class three hitch, rear axle anti-sway bar, and first oversize Michelin LTX M+S on all corners. Tekonsha P2 brake controller.
Not a fan of airbags. You may not need them with a Weight Distribution Hitch.
I use the somewhat unique Reese 350 Mini-Lite WD hitch, which performs well. The Rig is very steady. Your van is longer and has more rear overhang, so you might want to use a “Grown-up” WD Hitch.
Minivans in general have comparatively weak transmissions. I've studied the 41TE transmission quite a bit. The latest/last generation is the best version. It works well unless it has to frequently shift from fluid drive to “lock-up”. This mostly only occurs at highway speeds in “D”, but can occur in “3”. I can't hear or feel or see on tachometer the moment that this occurs, as it is only a 200rpm engine change.
Ideally, I will someday discover an electronic method to over-ride the transmission computer which is overly complicated ( it studies your driving style and adjusts itself … No Thanks). There are Dealer and aftermarket trans computer “flashes” available, but they don't solve the problem. If you search a lot, there's a guy who does something with a couple of Radio Shack switches spliced in, but I'm skeptical.
Anyway, there's lots to figure out about setting up this marginal trans for towing.
Meanwhile, Heavy Service fluid and filter change schedule, Baby it along, and never overheat it. Use Chrysler ATF+4 and Mopar filter. No "fancy" ATF needed.
06-23-2012, 05:11 PM
1966 17' Caravel
, Pennsylvania
Towed The Caravel With The Grand Caravan
I towed my Caravel for the 1st time today with my Grand Caravan. It towed very good plenty of power. I did not use trailer brakes or weight bars. The braking was fine. The van has 4 wheel disc brakes. The ride was smooth. I will be towing it to The Bash III next week with the van.
See Ya The Rock!
Ace in PA
07-10-2012, 03:39 PM
St. Catharines
, South Western Ontario
Looks good. I believe you should get the WDH and trailer brakes set up soon. It will be much better overall, and safer.
07-18-2012, 09:22 PM
2020 30' Classic
Derwood
, Maryland
Get the brakes minimum - weight distro would also be smart - BUT get those trailer brakes hooked up ASAP!!!
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
07-27-2012, 09:28 AM
1964 17' Bambi II
1961 24' Tradewind
Strasburg
, Pennsylvania
See Ya The Rock!
Ace in PA
Ace- how did the van tow to the Bash, how was the rally, and any pics? (I am surprised at how no one has really discussed it!)
We are looking at a VW Routan to do our towing and that seems comparable to your minivan. See you down the road-
Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
07-27-2012, 03:37 PM
1966 17' Caravel
, Pennsylvania
Ben
Hay Ben
I ended not using the Caravan to tow to the Bash. Being a host I had to much stuff to get up there. So I towed with my Chevy Express. My wife drove the Caravan to Coppers Lake. The Bash III was a great time. Everyone enjoyed them self and eat way too much bacon . You can check out the Bash III thread for photos. http://www.airforums.com/forums/f290...2-a-79553.html
As you my know a VW Routan is a Dodge Caravan with VW emblems. My Dodge towed the Caravel fine on a test run. I have towed my Scotty on a few trips with the Caravan. I was very happy with it. Great MPG and plenty of power.
Ace in PA
09-03-2012, 05:32 PM
1966 17' Caravel
, Pennsylvania
09 Grand Caravan towing update
09 Grand Caravan Towing Update
This weekend I towed my 66 Caravel with my 09 Grand Caravan. We made a 200 mile round trip. It was all highway in the hills of WV and PA. I towed in 3rd keeping it out of overdrive. I did not use any WD system. My van did great. I had no sway and only had to to kick it down to 2nd a few times. When I was going up a big hill to keep it going over 60 mph. I got 13.8 mpg running the AC the whole way. I'm still planning on getting a WD system soon. But I must say it was a much nicer ride towing with the Caravan instead of my one ton Chevy van.
Ace in PA
TAC PA-1
WBCCI 2169
12-01-2012, 11:01 AM
St. Catharines
Nice pic Ace....
If you like the way it tows now you will luv it when you get the WDH connected.
For many years we towed our 23' with a Nissan Van. It had an overbuilt tranny (same as the tranny used in the V8 Infinity Q45's. The Quest had over 450,000klm's on it and the tranny had been problem free. I believe your 3.3 has more power than our 150HP/3.0 Nissan engine.
12-01-2012, 02:12 PM
Ottawa
, ON
Here's a photo of our 1974 31' Sovereign and our tow vehicle, a 2007 Ford Freestar. The Freestar has a tough transmission and a 4.2L V6 engine, and can tow Henri the Sov about anywhere.
We went to Florida and back, stopping at the AS factory in Jackson Center, OH on the way down AND back, got to my brother's place in Atlanta, saw my wife's sister where she lives not far from Orlando, and spent a week in an RV park, with Henri parked over looking the Santa Rosa Sound in the Florida Panhandle.
A trip of over 4,000 miles, and the worst thing that happened was that Henri's WH sprang a leak and needed replacing.
Of course, we DO have a WD hitch, set up by Andrew_T of Can-Am RV...
12-02-2012, 04:52 AM
1966 17' Caravel
, Pennsylvania
I'm still on the fence
Thanks for the in info. The Airstream and Caravan have been put to bed for the winter. We are heading to FLA later this month but the AS is is not going. The Caravel will be heading to Frank's Trailer Works in Baltimore for re-buffing and seam sealing. I had a new axle installed this year and it towing like a dream. I have not got a WD hitch yet. I'm still on the fence.
Ace in PA
12-02-2012, 06:52 AM
2003 25' Safari
Riverside
The Caravan has plenty of Power but most will only get about 30k on the brakes.
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
12-02-2012, 07:59 AM
Chatham
, Ontario
Ace in PA
A weight distribution system and some sway control will only benefit your towing experience, Ace. I know your tongue weight is quite low but even that spread over all the axles will give you a better ride. Oh, and sway control adds that extra safety factor.
Come down off that fence!
12-02-2012, 08:34 AM
2005 30' Safari
Kanata
, Ontario
Ace in PA
After many miles towing an SOB with similar specs to your Caravel utilizing a Toyota Sienna minivan, I consider the WD hitch and sway control required safety equipment.
As the minivans are front wheel drive, it's important to keep the weight balanced on the axles. I've encountered wheel slip in rainy conditions - it would have been much worse without the WD hitch. Lack of traction is not pleasant when you are trying to get through an intersection in a metropolitan area!
There have been times as well where we needed to pull the trailer up gravel inclines at campgrounds. Again, without the WD hitch, I don't think some of the inclines would have been possible.
One also need to be aware of the loading on the axles. The '04 Sienna has limited payload capacity. With the family aboard, and the trailer hooked up, and a very small amount of gear in the back, without WD we would have overloaded the rear axle. The newer vans have much higher payload capacity and axle ratings - this might be as much of a concern on the '09 Caravan.
As for sway control - it's impossible to predict the weather conditions in which you are going to want to / have to tow. Success without sway control so far does not mean a particular wind pattern will not cause an issue tomorrow. I've towed in some strong cross winds - you can feel the sway control working. I was certainly not keen to experience towing without this added control in those conditions.
As for air bags - being new to whole towing experience, I added air bags to the van when we started a few years ago. They were recommended on a Toyota Sienna forum. All WD adjustments were done without the airbags inflated - and then the airbags were inflated until the back end just started to rise.
I experimented with and without the airbags. In the end, I felt them to be useful as the back end of the Sienna was a little soft, and we'd get some bounce going down the road. The airbags helped the rig feel a little more solid. But they were not required.
I've towed the same trailer with my new F150. Not need for airbags on this tow vehicle!
12-06-2012, 10:24 AM
1996 25' Excella
Midland
, Ontario
towing with caravan
We tow our 25' Classic with our '08 T&C / 3.8 / 6 spd with very few issues other than comments from individuals that are convinced we can't do it. Proper weight distribution hook up and good tires are the key. You won't be the fastest on the roads but staying in the truck lane is ok. You should look at the hp rating and torque of 3rd gear in your 3.3 but with some confidence you should be ok
12-06-2012, 09:57 PM
Ottawa
, ON
The six speed gearbox is a key addition to an ability to get up to speed in good time, IMHO.
12-06-2012, 11:04 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Ace in PA
Nice picture, incidentally. Stay within your safety & operating limits ... and VFR.
