Old 06-20-2019, 05:01 PM   #1
2003 22' International
Omaha , Nebraska
Towing with a BMW X5
Does anyone tow with a BMW X5? If so, did you have BMW install the necessary equipment?
I'm new here - in process of purchasing a 23CB Flying Cloud and just trying to figure out what I need to do in the way of the hitch, etc
Thanks.
mgomel is offline   Reply With Quote
Old 06-20-2019, 10:43 PM   #2
jcl
Vancouver , British Columbia
Worth doing a search on X5 towing.
The X5 is an incredible tow vehicle. Several are posting here that have X5 tow vehicles. There have been multiple generations, and there are some differences between generations of the X5. Which generation are you planning on using?
You should plan on not purchasing the latest BMW dealer hitch with the removable ball as it does not accommodate weight distribution equipment. I would use an aftermarket hitch if it is a late model X5.
Plan on using the BMW wiring interface kit as it doesnít just provide a connection for the trailer lights, it tells the vehicle computer when a trailer is connected and does things like turn off the rear park distance sensors, enables the trailer stability control mode in the vehicle dynamic stability control computer, and so on. I have installed multiple BMW hitches on different model years, but not on the newest model; I believe they are similar.
You will need a brake controller. It can be wired into the X5, or you can go with a wireless version.
jcl is offline   Reply With Quote
Old 06-21-2019, 07:17 AM   #3
Omaha , Nebraska
Towing with BMW X5
Thank you so much for the information. My BMW dealership here doesn't really seem very knowledgeable, which is a surprise to me.
I'm a little hesitant about going with after market products, but seeing that's the way most people go.
Old 06-21-2019, 10:54 AM   #4
bono's Avatar
Mountain View , California
Which model do you have? E70, F15, G05? I believe only F15 has the hitch that does not accommodate weight distribution. The latest model should be ok, maybe subject to reinforcing. I remember that Andy Thomson at Can Am mentioned somewhere here that he was setting up new X7. The hitch should be the same, so he should know if reinforcing is needed.
BMW X5
SOB 33 ft trailer
Propride 1400
bono is offline   Reply With Quote
Old 06-21-2019, 11:16 AM   #5
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
I tow a 27FB with a Cayenne with no problems at all. The tongue weight of a 23FB is about 1/2 of the 27FB,(under 500lbs). I think you will find the X5 to be an exceptional TV for your 23FB. As jcl said, the newer BMW hitch does not allow for WD so it is best to go with an earlier model that has a hitch receiver.
As far as brake controllers, I went with this https://www.etrailer.com/Brake-Contr...sha/90250.html rather than going through the trouble of getting one wired in under the dash and it works great. Very easy to install and set up and when you are not using it the remote goes into the glove box.
thewarden is offline   Reply With Quote
Old 06-21-2019, 11:35 AM   #6
bono's Avatar
The newest BMW X5 (G05) has the hitch receiver. Only the previous model F15 used different solution.
BMW X5
SOB 33 ft trailer
Propride 1400
Old 06-21-2019, 12:16 PM   #7
Ayr , Ontario
A colleague just bought one for towing a 27'. Andy at CanAm did the setup.
gator.bigfoot is offline   Reply With Quote
Old 06-22-2019, 08:35 AM   #8
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
European AWD SUV's were great tow vehicles, but they ceased to be so after the EPA forced diesel engines off the market.
out of sight is offline   Reply With Quote
Old 06-22-2019, 09:49 AM   #9
mikextr's Avatar
1967 26' Overlander
Bugtussle , Oklahoma
My gasoline powered Cayenne Turbo does just fine, thank you. Dont know why a diesel would be any better.
mikextr is offline   Reply With Quote
Old 06-22-2019, 10:19 AM   #10
2014 22' FB Sport
Davie , FL
Lots of low-end torque on a diesel. No downshifting required. Just a much better towing engine.
Nothing feels better than low end torque. My next vehicle will be an electric which produces full torque at zero RPM. I'll have to keep my diesel for towing though unless they put in charge stations across rural America.
Old 06-22-2019, 12:30 PM   #11
jcl
My 3 litre gasoline BMW six cylinder made peak torque at 1300 rpm, thanks to the twin turbos and direct injection. That was several hundred rpm lower than the six cylinder diesel in the same model vehicle. The diesel also had significantly less power, due to the narrower engine rpm range. That narrower operating range creates more shifting on a diesel, not less, but that isnít a problem with an automatic. Biggest downside was that the fuel pumps smelled. I got rid of my last diesel 16 years ago.
Flywheel torque only matters to armchair spec sheet racers. Wheel torque is what makes the vehicle go, and with modern multi speed transmissions high rim pull can be achieved easily.
Old 06-22-2019, 12:56 PM   #12
2014 22' FB Sport
Davie , FL
Newer diesels are much better, as are the newest gassers. But the gassers gobble fuel when towing. A diesel will pay for itself at about $1000 per 10,000 tow miles.
When I was younger I wanted my max torque at 5000 RPM. Now I enjoy towing 70 MPH at 1500 RPM. It hardly ever downshifts.
Old 06-22-2019, 10:28 PM   #13
thewarden's Avatar
Mine as well.
Old 06-22-2019, 10:44 PM   #14
thewarden's Avatar
My Porsche gasoline 4.8 twin turbo V8 makes plenty of low end TQ. Over 550 @ 2200 rpm.
BMW x-5 2012 towing mirror jim huebner Towing, Tow Vehicles & Hitches 8 07-22-2012 04:44 PM
Anyone towing 5,000 lbs with a V8 BMW X5? adwriter73 Tow Vehicles 20 06-17-2010 01:14 AM
Interesting article Re BMW X5 & Towing Road Ruler Tow Vehicles 10 03-15-2009 09:47 AM
Bmw Towing Capacity Please Help ACHALAT Tow Vehicles 4 02-03-2006 06:42 AM
