Old 04-20-2016, 12:05 AM   #1
2016 30' International
Sarasota , Florida
Towing with a 2 1/2 receiver
Are there any issues with a 2 1/2 in receiver with an insert which reduces it to 2 in. For example, play, or movement between insert and receiver?
minddr is offline   Reply With Quote
Old 04-20-2016, 04:41 AM   #2
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
We found that the answer to your questions are yes. There has been play and movement. Therefore, we went to a 2-1/2" hitch, instead of the insert. No longer any play, at least not yet. We use an Equalizer hitch system and purchased the new hitch shank directly from Equalizer.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 04-20-2016, 05:07 AM   #3
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
We have a new Ram with a 2 1/2" receiver and the insert...
Although there is a little play with the insert in with no load, I don't notice any more play with the bar in than I did with the 2" receiver in the Ford...
Once loaded up, I can't see the difference.
It will be interesting to see what others say.
Bruce
Bruce B is offline   Reply With Quote
Old 04-20-2016, 05:53 AM   #4
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I put the insert in mine and welded it on both ends....solved the clearance problem.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 04-20-2016, 07:32 AM   #5
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Our 2015 F-250 has the insert. Sure, there appears to be a little play when you wiggle the hitch ball when it's not hitched to the trailer but I don't notice it at all when hitched up and towing. This is a non-issue, don't give it another moment of thought.
Bob Martel
WBCCI# 5766
Old 04-20-2016, 08:06 AM   #6
Tincampers's Avatar
Sneedville , Tennessee
I didn't like the insert or how far out the Blue Ox hitch bar sticks out. I replaced it with a Curt 17128. Nice hunk of steel.
Tincampers is offline   Reply With Quote
Old 04-20-2016, 08:09 AM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
When I was towing with a Silverado 2500 it had an insert. It rattled if I left in in the hitch and I thought someone might steel it. I got tired of having to remove it each time I used the hitch.
I do not have any equipment that used the larger opening, so I decided to secure the adapter in place. I did not want to weld it in, so I caulked around the inside of the receiver tube then slid the insert in place and inserted the pin. Then I caulked the visible end of the receiver and smoothed it with my finger. It looked great and functioned great. In the years I owned that truck that receiver adapter never moved enough to rattle again.
Old 04-20-2016, 08:36 AM   #8
2016 30' Classic
Erie , Colorado
No issues with mine. GMC 2500, ProPride, 2015 Classic.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 04-20-2016, 09:00 AM   #9
mcomeaux's Avatar
2016 27' Flying Cloud
Sunriver , Oregon
Hitch Play
2016 Dodge with 2.5" I use the sleeve with no problem.
mcomeaux is offline   Reply With Quote
Old 04-20-2016, 10:31 AM   #10
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have two tow vehicles. a 2005 2500 Suburban and a 2011 3500 Silverado. The latter has the 2.5" receiver with which we use an insert. We have a Hensley. When we tighten up the weight distribution, any play between the hitch bar and receiver is gone.
We have now towed the Airstream about 50,000 miles with the 2.5" and reduction insert. We have not had any towing problems whatsoever with this combination.
Brian
SuEllyn & Brian McCabe
Old 04-20-2016, 10:44 AM   #11
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I thought I read you shouldn't use WD with a sleeve. Not 100% sure however...
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 04-20-2016, 11:01 AM   #12
My Ram 2500 pulls without any problem using the sleeve insert.
jonnie3 is offline   Reply With Quote
Old 04-20-2016, 11:02 AM   #13
1977 31' Sovereign
Lynnwood , Washington
12K vs 10K capacity. Nothing beats overkill.
I would however, resist the temptation of using adapters. Except for short distances, an adapter will be an Achilles' Heel. Get a 2.5" hitch to match your 2.5" receiver.
Tom
TomKirk is offline   Reply With Quote
Old 04-20-2016, 11:05 AM   #14
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
We definitely experienced added 'play' or 'slop' with a sleeve, in former tow vehicle.
Started off snug, but would quickly degrade. Posted about it in another thread here somewheres with pix....
It would end up being about an inch or more on both axis, which vertically, translated to as much as 200lbs lost in weight distribution (for our particular setup).
Not sure what effect it had in the horizontal axis... using Hensley
Replaced it with another, supposedly "hardened steel" sleeve, and it did the same thing.
I don't have that kind of shank-slop in our current 2" receiver.
boondockdad is offline   Reply With Quote
class iv or v receiver? 2airishuman Hitches, Couplers & Balls 11 03-08-2005 07:27 AM
Receiver Extension bugdoc 1997 - 2004 Bambi 10 11-17-2004 04:41 PM
Reese Receiver needed jasper2222 Hitches, Couplers & Balls 2 10-06-2004 07:54 PM
2" Receiver at rear of Airstream? BeBop Hitches, Couplers & Balls 5 08-23-2004 09:13 AM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
