04-20-2016, 12:05 AM
2016 30' International
Sarasota
Towing with a 2 1/2 receiver
Are there any issues with a 2 1/2 in receiver with an insert which reduces it to 2 in. For example, play, or movement between insert and receiver?
04-20-2016, 04:41 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
We found that the answer to your questions are yes. There has been play and movement. Therefore, we went to a 2-1/2" hitch, instead of the insert. No longer any play, at least not yet. We use an Equalizer hitch system and purchased the new hitch shank directly from Equalizer.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
04-20-2016, 05:07 AM
2021 25' Globetrotter
Jamestown
, Rhode Island
We have a new Ram with a 2 1/2" receiver and the insert...
Although there is a little play with the insert in with no load, I don't notice any more play with the bar in than I did with the 2" receiver in the Ford...
Once loaded up, I can't see the difference.
It will be interesting to see what others say.
Bruce
04-20-2016, 05:53 AM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
I put the insert in mine and welded it on both ends....solved the clearance problem.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
04-20-2016, 07:32 AM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
Our 2015 F-250 has the insert. Sure, there appears to be a little play when you wiggle the hitch ball when it's not hitched to the trailer but I don't notice it at all when hitched up and towing. This is a non-issue, don't give it another moment of thought.
Bob Martel
WBCCI# 5766
04-20-2016, 08:06 AM
Sneedville
, Tennessee
I didn't like the insert or how far out the Blue Ox hitch bar sticks out. I replaced it with a Curt 17128. Nice hunk of steel.
04-20-2016, 08:09 AM
2000 25' Safari
Davidson County
, NC Highlands County, FL
When I was towing with a Silverado 2500 it had an insert. It rattled if I left in in the hitch and I thought someone might steel it. I got tired of having to remove it each time I used the hitch.
I do not have any equipment that used the larger opening, so I decided to secure the adapter in place. I did not want to weld it in, so I caulked around the inside of the receiver tube then slid the insert in place and inserted the pin. Then I caulked the visible end of the receiver and smoothed it with my finger. It looked great and functioned great. In the years I owned that truck that receiver adapter never moved enough to rattle again.
04-20-2016, 08:36 AM
2020 Classic 33
Box Elder
, South Dakota
No issues with mine. GMC 2500, ProPride, 2015 Classic.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
04-20-2016, 09:00 AM
2016 27' Flying Cloud
Sunriver
, Oregon
Hitch Play
2016 Dodge with 2.5" I use the sleeve with no problem.
04-20-2016, 10:31 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We have two tow vehicles. a 2005 2500 Suburban and a 2011 3500 Silverado. The latter has the 2.5" receiver with which we use an insert. We have a Hensley. When we tighten up the weight distribution, any play between the hitch bar and receiver is gone.
We have now towed the Airstream about 50,000 miles with the 2.5" and reduction insert. We have not had any towing problems whatsoever with this combination.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
04-20-2016, 10:44 AM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
I thought I read you shouldn't use WD with a sleeve. Not 100% sure however...
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
04-20-2016, 11:01 AM
My Ram 2500 pulls without any problem using the sleeve insert.
04-20-2016, 11:02 AM
1977 31' Sovereign
Lynnwood
12K vs 10K capacity. Nothing beats overkill.
I would however, resist the temptation of using adapters. Except for short distances, an adapter will be an Achilles' Heel. Get a 2.5" hitch to match your 2.5" receiver.
Tom
04-20-2016, 11:05 AM
2008 30' Classic S/O
Dearborn
, Michigan
We definitely experienced added 'play' or 'slop' with a sleeve, in former tow vehicle.
Started off snug, but would quickly degrade. Posted about it in another thread here somewheres with pix....
It would end up being about an inch or more on both axis, which vertically, translated to as much as 200lbs lost in weight distribution (for our particular setup).
Not sure what effect it had in the horizontal axis... using Hensley
Replaced it with another, supposedly "hardened steel" sleeve, and it did the same thing.
I don't have that kind of shank-slop in our current 2" receiver.
04-20-2016, 11:40 AM
Santa Rosa Beach
We have been using the reduction inset with our 2" Hensley hitch bar for some time now. The "slop" in our hitch bar with the adapter does not seem to be any greater than it is on our Suburban with a 2" Reese Class IV receiver.
Based upon this discussion, I placed a call to Hensley Manufacturing in Michigan and spoke to one of their technicians. I asked about this issue and was told that using a reduction insert did not present any problem whatsoever.
Brian
04-20-2016, 11:54 AM
2013 30' Classic
Greenwood
, Mississippi
Options:
1. some sort of shim or anti-rattle device to take out the slop/play
2. weld the sleeve, and then an anti'rattle device to take out slop and play
3. a new 2 1/2" shank and an anti-rattle device to take out slop/play
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
04-20-2016, 11:55 AM
2013 25' FB Flying Cloud
Colorado Springs
I use the Silent Hitch Lock. It not only keeps all movement to zero because of the bolt/nut combination, it also is keyed to keep your tow ball from being stolen!
http://www.amazon.com/Lets-Go-Aero-S...h+class+IV+pin
04-20-2016, 12:34 PM
2015 27' FB International
mesquite
I was told by equalizer that they did not sell to individuals only to dealers! Wanted to purchase a longer shank. Does not compute! !!
04-20-2016, 12:38 PM
2013 30' Classic
Greenwood
, Mississippi
I would think if you already own an Equal-I-zer hitch and then trade vehicles that they would sell you a longer shank if you needed one.
TAC #MS-10
Airforums #70955
04-20-2016, 01:57 PM
2015 30' Classic
Sherwood
, Oregon
My sleeve is flush with end of receiver with close tolerance fit. No more play than when I tow with my TV with the 2" receiver. I leave the reducer and locking pin in when not towing. Never heard any rattle..
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
