Old 04-21-2016, 10:58 AM   #29
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
I'd hesitate to weld it too but someone here talked about "caulking" it in... A urethane adhesive like 3M 4000 is UV stable. Strong as nails and can (with heat) be removed...
Sounds like it's not a bad idea?
Bruce
Bruce B is offline   Reply With Quote
Old 04-21-2016, 01:13 PM   #30
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Ours is welded... Reese V TowBeast.
No rattles, and a nice feature....the pin wall is twice as thick, less chance of developing an egg hole.
Its a crooked piece of time that we live in.
John Prine
Old 04-21-2016, 01:42 PM   #31
Durango , Colorado
I have a propride and need to use the insert with the Propride stinger. No problems, no movement, and no issues with towing.
However it does make trying to insert the pin in the ProPride stinger a pain. Now you have to slide the pin thru three holes on each side (the Ford receiver, the 2" adapter, and the Propride stinger) which makes perfect alignment difficult. There is very little clearance between the outside diameter of the pin and the inside diameter of each insert hole.
RVDreamer is offline   Reply With Quote
Old 04-21-2016, 01:48 PM   #32
2007 22' International CCD
Towing with a 2 1/2 receiver
Get an alignment tool. It's a longish tapered pin that you can use to pry the parts into position before you try to put in the hitch pin. Makes it easy to align without seeing through the holes.
Harbor Freight or your local big box home improvement store is a possible source.
KE4GNK/AE
'The Silver HamShack' (2007 International 22FB CCD 75th Anniversary model)
rmkrum is online now   Reply With Quote
Old 04-21-2016, 03:02 PM   #33
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Originally Posted by moxie t. moto View Post
I was told by equalizer that they did not sell to individuals only to dealers! Wanted to purchase a longer shank. Does not compute! !!
I don't get this one at all. I called, talked to a tech at Equalizer and ordered directly from him.. I lost the specific name but his initials on the packing slip are JS and it came from Progress Mfg Inc, 383 South 1100 West - Provo, UT 84601 Phone 801-377-9599.
The part number is 90-02-4700 - 2-1/2" Shank 12" longx3" max drop or 7" rise. Then I also ordered an extra ball as it is a little hard to find if the one I have goes bad.
I switched to the 2-1/2" shank as the reducer(s), I tried several, were getting bent and wedged into the receiver and at times very hard to get the reducer out. Now no issues.
Good Luck
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 04-21-2016, 03:16 PM   #34
2016 30' International
Sarasota , Florida
Thank you for feedback
This forum is great! Thank you all for your feedback. I ended up buying an Anderson aluminum insert which is supposed to have a tighter fit than others. Have not tried to tow yet. The dealer where we are buying the Airstream from told me they cannot get a 2 1/2 inch hitch and I had to get the insert. I am getting the Equalizer hitch. I think I read one of the responses saying they were able to get an Equalizer hitch with a 2 1/2 shank. I hope I am using these terms correctly.
minddr is offline   Reply With Quote
Old 04-21-2016, 03:55 PM   #35
paiceman's Avatar
I found the same one in a 2-1/2" shank on Amazon as well as on the Equalizer website. Not sure why your AS dealer could not get one, maybe they simply did not want to.
SAFE TRAVELS
Bud
Old 04-22-2016, 09:52 AM   #36
Sarasota , Florida
2 1/2 shank for Equalizer hitch
I called the equalizer and they told me they did have 2 1/2 inch Shanks but only for a drop up to 6 inches. Actually they have three sizes. However, my RV dealer says I need a 9 inch drop which they do not make it this time but interestingly enough they are thinking of making it. So I guess I will go with my insert.
class iv or v receiver? 2airishuman Hitches, Couplers & Balls 11 03-08-2005 07:27 AM
Receiver Extension bugdoc 1997 - 2004 Bambi 10 11-17-2004 04:41 PM
Reese Receiver needed jasper2222 Hitches, Couplers & Balls 2 10-06-2004 07:54 PM
2" Receiver at rear of Airstream? BeBop Hitches, Couplers & Balls 5 08-23-2004 09:13 AM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
