Old 04-01-2018, 05:48 PM   #21
gator.bigfoot's Avatar
KW , Ontario
I think a lot of this is covered in this thread.
http://www.airforums.com/forums/f463/porsche-cayenne-vw-touareg-audi-q7-owners-134917.html
gator.bigfoot is offline   Reply With Quote
Old 04-01-2018, 06:58 PM   #22
bono's Avatar
Mountain View , California
Then why so many folks are towing with trucks? If truck would be designed for towing, it would have low center of gravity, independent suspension, short rear overhang, etc.
I agree, if somebody is taking chain saw to campground (fortunately I did not have such neighbors so far), then pickup may be a choice. Otherwise German SUV are an alternative especially for those who appreciate good handling.
Originally Posted by GMFL View Post
Iíve said it before and I will say it again a tow vehicle should be made/manufactured to tow not Forced/Begged to. (...)
BMW X5
SOB 33 ft trailer
Propride 1400
bono is offline   Reply With Quote
Old 04-01-2018, 08:34 PM   #23
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Did your BMW come standard with a 7 pin plug and a class V hitch. If not then you are forcing it. And at some point your transmission or rear-end gear box will tell on you. There have been post on here about BMW X5ís that have suffered transmission problems from towing Airstreamís. Donít get me wrong I know they will pull the weight. But the components long term are not going to hold up.
Old 04-01-2018, 09:46 PM   #24
2007 27' International CCD FB
San Diego , California
I often drink the cool-aid from the other camp. Though it's also important to take those perspectives with a grain of salt and understanding. You should ask yourself, why do so many folks tow with trucks.
It's a matter of overall design and purpose. There's competing needs and qualities.
Independent suspension is great for hugging the road. But it's also generally not as durable. For anyone that's taken a modern multi-link suspension car much over 100k, they'd know that the suspension doesn't feel as accurate as the day they bought the car. Because there are rubber bushings at each pivot point that will wear. Even without towing, with general use, these bushing deteriorate! Just consider how fast they might deteriorate if one were to use their car to tow beyond design parameters regularly. With up to 10 or more bushings at each corner, refreshing these nice German suspensions can get VERY expensive.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Old 04-01-2018, 09:52 PM   #25
jcl
Vancouver , British Columbia
Did your BMW come standard with a 7 pin plug and a class V hitch. If not then you are forcing it. And at some point your transmission or rear-end gear box will tell on you. There have been post on here about BMW X5’s that have suffered transmission problems from towing Airstream’s. Don’t get me wrong I know they will pull the weight. But the components long term are not going to hold up.
You need to spec the optional BMW hitch, then you get a class III receiver (typically rated to 10,000 lbs) and a 7 pin connector. Trailer Stabilty Control is standard, and was so for 5 years before Ford or Ram first offered it on their pickups. Yes, the vehicle was designed for towing.
A class 5 receiver (rated up to 17,000 lbs) seems a little overkill.
jcl is offline   Reply With Quote
Old 04-01-2018, 09:55 PM   #26
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Originally Posted by jcl View Post
You need to spec the optional BMW hitch, then you get a class III (typically rated to 10,000 lbs) and a 7 pin connector. Trailer Stabilty Control is standard, and was so for 5 years before Ford or Ram first offered it on their pickups. Yes, the vehicle was designed for towing.
Good luck with that.
Old 04-01-2018, 09:57 PM   #27
bono's Avatar
Not sure why I would need class V hitch. Yes, it came with a 7 pin connector.
The fact that somebody was having transmission problems does not prove anything. Thousands of pickup owners are having transmission problems every year, some never towing.
BMW X5
SOB 33 ft trailer
Propride 1400
Old 04-01-2018, 09:58 PM   #28
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Again..... Good luck with that.
Old 04-01-2018, 10:00 PM   #29
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I drive a diesel.... because I hate cold weather.
Old 04-01-2018, 10:00 PM   #30
bono's Avatar
100% agree.
Again, 100% agree. I am willing to pay more for a better ride.
BMW X5
SOB 33 ft trailer
Propride 1400
Old 04-01-2018, 10:01 PM   #31
jcl
Are you referring to the receiver? Nothing wrong with using a receiver that can handle 1000 lbs of tongue weight. That doesnít determine tow capacity. Look more to axle and tire ratings.
Old 04-01-2018, 10:02 PM   #32
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Are you referring to the receiver? Nothing wrong with using a receiver that can handle 1000 lbs of tongue weight. That doesn’t determine tow capacity. Look more to axle and tire ratings.
No with transmission.
Class III Hitch is fine.
Old 04-01-2018, 10:08 PM   #33
jcl
It has been very solid. ZF 8HP 75 in the latest model. That is a heavier duty version of what RAM uses (for their V8 and Ecodiesel) and is the same model used by Aston Martin for the DB11.
Old 04-01-2018, 10:10 PM   #34
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Look I donít care what you tow with. Just be safe out there, stay within the limits the manufacture set forth and have fun. No vehicle is perfect.... unless itís my GMC 2500HD Duramax Denali Crew-Cab
Old 04-05-2018, 12:52 AM   #35
Maple Valley , Washington
We have a 2017 Q7 that we tow our 2018 19FC with. I will say that when trucks pass us by on the freeway, you do feel the pull. Before buying the trailer, I contacted CanAm and they reassured me that they have had extensive experience with the new Q7's which put my mind at ease. We did hook up a Blue Ox W/D hitch which helped with the sag and gave it more stability. Through the towing process, I will note the following:
Great towing on flat ground
Ok towing up hills
Terrible on brakes
I eventually bought an F350 and we now tow it with that.
As great of a car the Q is, it really isnt meant to tow something large.
jimmyle89 is offline   Reply With Quote
Old 04-05-2018, 06:52 AM   #36
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Originally Posted by jimmyle89 View Post
... I will note the following:
. . . Terrible on brakes
Trailer brakes should be set to slow/stop the trailer by themselves. If they were and you noticed a longer stopping distance for the rig vs solo this would be normal considering the increase in mass. I would think that a properly set up Q7 rig would stop in less distance than the F350 rig.
As a side note, it is interesting to note that if one goes with the longer (heavier) 25' AS it stop more smoothly and quickly than the smaller (lighter) 19' AS because the longer trailers have four brakes instead of just two. Another reason to go up to the tandem axle trailers.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 04-06-2018, 12:43 AM   #37
bono's Avatar
Terrible on brakes
Hard to believe.
Go big or go home. This is an example of some mistakes with the setup (German SUV having terrible brakes? First time I am hearing this) and solution - buy one ton truck to tow 19FC...
BMW X5
SOB 33 ft trailer
Propride 1400
Old 04-06-2018, 01:22 PM   #38
KW , Ontario
Ford recalls 350,000 trucks and large SUVs over transmission problem
The recall covers 2018 F-150 pickups and Expedition large SUVs with 10-speed automatic transmissions. Also covered are 2018 F-650 and F-750 trucks
https://www.canadianmanufacturing.co...mpaign=180406E
I guess those trucks weren't designed for towing since the transmission didn't hold up?
Old 04-06-2018, 04:25 PM   #39
1960 24' Tradewind
Kingsville , Ontario
Camping ????
Yes, a chainsaw in a cement padded glampground would not fit the bill. West coast campgrounds though....good wind = blocked road....no rangers around to save you.
Also , physics 101, I do not care about low centre of gravity, or perforated brakes or german engineered suspension ( I drive an A4) ; if you are heading down a mountain in a rainstorm, and something happens.... which sometimes it will ie deer or moose running out in front of you, having a trailer behind you that outweighs the TV is a recipie for disaster.
Be safe out there. And if you do not carry a chain saw at least carry a good Swede saw.
KZGoodchild is offline   Reply With Quote
Old 04-06-2018, 05:35 PM   #40
bono's Avatar
I would say that it is very common that a trailer behind you outweighs the TV, even with the truck / TT combo.
BMW X5
SOB 33 ft trailer
Propride 1400
Towing with Audi Q5 rando Tow Vehicles 12 01-11-2019 05:58 AM
2017 Audi Q7 for 27FB warbern Tow Vehicles 19 05-11-2018 11:36 PM
Towing with 2017 Audi Q7 Silverbuckle Tow Vehicles 2 03-27-2018 01:38 AM
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 01:33 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 02:02 PM
