Old 11-01-2012, 05:23 AM   #1
richinny's Avatar
2011 34' Classic
Towing speed record
Diesel Power sets land speed towing record at 141.998 mph
Ricky
Old 11-01-2012, 05:37 AM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Wow!
Lance
Top is offline   Reply With Quote
Old 11-01-2012, 06:20 AM   #3
WBCCI 1024,4CU
shivtik's Avatar
1985 31' Excella
Lake Havasu , Arizona
Images: 84
World Speed Record
I agree with the "WOW" - But you would be surprised at the type of speed records being set for those that will be attending this years 4CUnit-New Years Eve Rally at Pichaco Peak Az. Now this is a rally worth putting the pedal to the metal for.
shivtik is offline   Reply With Quote
Old 11-01-2012, 06:39 AM   #4
Some 40 plus years ago, as part of a research program, I towed a loaded 31 foot Airstream with a properly out fitted Buick, at 115 MPH.
This was recorded on film that also showed the calibrated speedometer and air speed indicator readings.
Of course I was much younger and a little more foolish back then.
Old 11-01-2012, 07:14 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
That speed with no trailer sway control used, amazing. The package looked very stable and solid during the run. Impressive record for towing a square box. I wonder what would have been the final speed result if they had used a slippery Airstream.
MICHAEL
Old 11-01-2012, 07:29 AM   #6
Sway control at higher speeds is sort of built in to the flat or near flat fronted trailers, as they offer a lot of wind resistance because of the flat front.
We also tested a 5' X 8' empty "box type" U haul trailer, with the same tow vehicle used with the Airstream tests.
We were surprised to find that the maximum speed was only 85 mph.
Wind resistance is a tremendous force, and has a huge negative effect on fuel consumption.
Old 11-01-2012, 08:11 AM   #7
1981 31' Excella II
New Market , Alabama
I bet he could have gone alot faster pulling an Airstream. The fastest I have been in a car is about 140 MPH and things happen real fast at those speeds. I expect that many stock pickup trucks won't go over about 120 assuming you can disable the speed limiters. Gearing is another factor. Trucks are geared lower so you reach redline alot quicker. 142 MPH pulling a trailer is impressive considering it was an SOB.
Perry
Old 11-01-2012, 08:17 AM   #8
Vintage Kin
Fort Worth , Texas
The amount of horsepower to overcome that square shape (especially on the TT rear) isn't surprising.
While we discuss that fuel economy doesn't change much in upsizing from, say, a 28' to a 34' (steady state highway), the drag produced by length becomes prodigious after a point.
That's a teeny trailer in the record attempt. An upholstered U-Haul.
Andy, what sized TT did you pull with that Buick? 80% of the record speed, but with about one-quarter the HP.
Old 11-01-2012, 10:22 AM   #9
Road Ruler's Avatar
Images: 38
More of a story about luck.
Wow, are they lucky that rig is still in one piece!
Old 11-01-2012, 12:11 PM   #10
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Back when I was a couple of years younger (about 35), I would use Georgia overdrive coming down mountains in an F-Model Mack and a 45' trailer. The speedometer would bottom out at 80 a long time before the bottom of the hill and the whole rig was really quiet. Now I figure I was really lucky, especially considering the bias tires in those days. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 11-01-2012, 01:27 PM   #11
Mike91208's Avatar
2009 27' FB International
LA LA Land... , California
We looked at Carson trailers before we bought the Airstream - they're very well-built and solid!
Mike91208 is offline   Reply With Quote
Old 11-01-2012, 01:50 PM   #12
Road Ruler's Avatar
Images: 38
I believe you but.........
the whole deal could have been so much better (to make it safer and probably faster).
Consider a dual axle Airstream, a much better high tech connection, a more suitable TV, and tires with a higher speed rating.
Old 11-01-2012, 02:53 PM   #13
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
What happens on the way to Metro-Detroit, stays at Metro-Detroit.
Lets just say it involved an exremely hopped-up Durango and a light 1970 single axle Safari.
:0
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 11-01-2012, 04:07 PM   #14
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
you know, I'm not that impressed with this. Nitrous and 1000 hp ??? I have had my AS up to 85 mph on the flat with my 382 HP Sequoia with a lot left. I'm willing to bet I could get it up over 110 mph on the flat with my 28' AS that weighs double or triple what that trailer does.
If we can raise the money to close highway 92 for a 6 mile stretch for 5 mins Ill give it a try
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
