Old 02-14-2014, 06:27 AM   #15
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
The truck/AS combination you mentioned should be just fine. I handled our 1977 Tradewind with much less for a number of years - and had some significant hills too.
Good recommendations from others on safe towing speeds. I always keep my speed under 60 mph (100 kmh) when towing. That's a lot of weight to stop or move when an emergency arises! Here's an interesting video:
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 02-14-2014, 06:53 AM   #16
r carl's Avatar
Lin , Ne
Hopefully the truck you have, or going to get has the factory tow package.
Old 02-14-2014, 07:18 AM   #17
2012 30' Classic
Homosassa , Florida
I have an 05 silverado 5.3 but with 3:73 rear. I pull a 30' Classic through Georgia, Tennessee and Carolina's. I run in tow haul mode and if it starts shifting frequently I shift to 3rd. It does lose power on steep grades but I still pass most in truck lane. I do tow at speed limit and build up speed just before climbing a mountain. I think you are fine with what you are towing. I would recommend LT tires and check your receiver. My 05 has 100k miles on it and I'm trading next week. Just wanted a new one.
Sent from my SCH-I545 using Airstream Forums mobile app
Tater is offline   Reply With Quote
Old 02-14-2014, 10:25 AM   #18
1999 28' Excella
New Orleans , Louisiana
Cruise Control?
I thought in towing an AS or any trailer you don't use cruise control.
Thought I saw that somewhere.
badkat is offline   Reply With Quote
Old 02-14-2014, 10:46 AM   #19
JFScheck's Avatar
Rockville , Maryland
Images: 33
Use Cruise Control & Tow-Haul mode (it was selected by the Touareg when it sensed the trailer was hooked up) for many, many, many miles, three different tow vehicles with three different trailers all over this continent, wouldn't drive any other way, assuming the conditions permit it....
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 02-14-2014, 11:03 AM   #20
2012 30' Classic
Homosassa , Florida
I don't use cc with my 05 since it shifts to lower gear more frequently than I like. Newer truck may be less of an issue but my 4 speed shifted in and out of OD on every rise in the road.
Old 02-14-2014, 03:23 PM   #21
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Re: cruise control.
I use it on long highway stretches. It is definitely NOT for comfort driving. In fact, since getting the Airstream, using cruise in a car has a different meaning now. It's only for fuel efficiency - not to set my mind on cruise control too (which sadly was what I was doing before). Having that trailer behind me makes me SO MUCH MORE AWARE of my responsibility as a driver!!! So the engine runs more efficiently but my min has to be 100% on all the time.
SteveSueMac is online now   Reply With Quote
Towing a with an Nissan Xterra AWCHIEF Tow Vehicles 7 12-22-2011 06:57 AM
Towing Question from a novice imaginair Tow Vehicles 13 10-20-2011 07:15 PM
Towing with a TDI VW Jetta PA BAMBI II Tow Vehicles 102 07-21-2011 09:27 AM
