Old 05-12-2012, 07:34 AM   #1
1967 24' Tradewind
Truro , UK
Towing help wanted.
I have a 67 Tradewind in Tennessee and want to tow it to Charleston SC on the coast for shipping.
In my ignorance, I thought I'd simply hire a pickup truck and tow it .....
Now banging my head against the wall. As most companies that hire pickups domestically wont allow towing and or the trucks are not set up for towing.
I've discovered that U-Haul will hire me a truck for towing but then there is the question of a brake controller, they dont have them fitted it would seem ?
I'd welcome any constructive advice please ?
Somewhere I read that Hertz equipment hire might be the place to go but it's saturday and they're closed.
Buzzardz is offline   Reply With Quote
Old 05-12-2012, 07:44 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Check with U Haul or Penske. Brakes are not required unless the weight of the towed trailer is more than a certain % of the towing vehicle, not sure what that ration is but they should know.
Renting a larger U Haul or Penske should more than cove this. It is the one way charge that may get you.
A bigger consideration will be if you can get the trailer level behind a larger truck. Airstream dual and tri axle trailer have to ride level in order for the axles to see equal weight on each axle. A single axle trailer this will not be a problem for what you are doing.
2004 Excursion 4x4
Old 05-12-2012, 09:23 AM   #3
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Sounds like you want to drive it yourself, but this might be an option to consider About Us - Horizon Transport or other contract RV towing compaines. You would need to weigh your costs vs. contracting. There are other compaines of course, but I know a former driver from Horizon from another forum.
Good luck,
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 05-12-2012, 09:42 AM   #4
1967 24' Tradewind
Truro , UK
Thank you both very much for your thoughts. I'd be interested to know that %ratio regards towing without brakes though, I was thinking that might be an option.
It is however twin axle.
Gary, I dont mind really whether its me or a haulage company.
U-Haul pickup trucks dont have a one way option, so I'd have to take it back to Knoxville anyway which is a pain.
I cant believe how so a simple job can be proving such a nightmare.
Old 05-12-2012, 09:53 AM   #5
HowieE's Avatar
Images: 12
Try this site.
Trailer Brake Requirements For Towed Vehicles
Penske may have oneway service and they may have brake systems built in because of the number of people trailering cars while moving.
2004 Excursion 4x4
Old 05-12-2012, 09:55 AM   #6
GCinSC2's Avatar
Buzzardz,
Not sure where in TN your Tradewind is or your experience level, you might be in for some beautiful driving on I-26 TN to SC or it might be 20 miles of white knuckle driving and second guessing your choice in the mountains. Hiring the job its their skills, their rig and their insurance to get a professional to do the job.
Gary
S/OS #001
Old 05-12-2012, 10:05 AM   #7
1967 24' Tradewind
Truro , UK
I'm pretty experienced with towing up to a couple of tonnes but never in the US. The Trailer is near Knoxville. I'm torn really, I'd like to do it but as yet have no vehicle. I think Penske only hire removal type trucks, is that right ? I want a Pickup really. I take your point about leaving it to the pros too.
Old 05-12-2012, 10:07 AM   #8
1967 24' Tradewind
Truro , UK
Also I'm not sure that Hertz equipment rental will hire to me as I'm not a business, just a private user ?
Old 05-12-2012, 11:04 AM   #9
1967 24' Tradewind
Truro , UK
Ok, this is one of the U-Haul 10' trucks...
Any thoughts ?
They do one way.
The assistant I spoke to said theres no need for a brake controller, you just plug into the four pin (adaptor may be necessary) and the brakes will be connected and work ?
Can that be true, it doesn't seem right to me ?
Empty weight: 5,790 lbs.
Towing capacity: Up to 6,000 lbs.
Old 05-12-2012, 12:01 PM   #10
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Any thoughts ?
They do one way.
It's not. He's thinking of the surge brakes that the U-Haul trailers have, not the electric brakes Airstreams (and plenty of other trailers) use.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 05-12-2012, 01:38 PM   #11
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Any thoughts ?
They do one way.
There is no brake wire in a 4 wire connector.
Richard
Old 05-12-2012, 02:08 PM   #12
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Towing help wanted.
Greetings Buzzardz!
Any thoughts ?
They do one way.
Unless U-Haul has changed their truck setups in the last six months, the trucks do not have electric brake controller so you will not automaticlly have electric trailer brakes. I frequently rent their car hauler trailers or their 12' box trailers . . . these trailers have surge hydraulic brakes so a brake controller isn't required for U-Haul equipment. What the trucks did have was a four-pole flat connector that supplies ground, clearanc/tail/running lights, left-turn and stop light, right-turn and stop light.
I suspect that the ball height on the U-Haul truck will be very close as the ball height on both the U-Haul car hauler and U-Haul 12-foot box trailer are set up for an 18" ball height . . . and the standard ball is 2" and may be welded to the hitch . . . I know that they were at one time. That is one reason I like to rent U-Haul trailers . . . they hook right up to the hitch that I normally use with my Overlander.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 05-12-2012, 03:24 PM   #13
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Towing without brakes
Some states require you to have brakes above a certain trailer weight. If I were you and had no capability of hauling the trailer, I would hire a hauler. There are lots of them available and that will also handle the insurance on the trailer that you will need to assure that you make a profit and not have a disaster and a major loss.
Old 05-12-2012, 04:42 PM   #14
1967 24' Tradewind
Truro , UK
Thank you all for your comments. I'm not ready to give up yet but I do seem to be drawing a blank on this one. What is it with brake controllers, why don't trucks with tow packs have them fitted as standard, or are they an old fashioned system now ?
I think the haulier route may well be the only way to go ?
How would I find out which States require the trailer to be braked ? I'll be in TN & SC.
I called a couple of hauliers but they only hauled motorised RV's not Travel Trailers, any suggestions of anyone I could call welcomed ?
Sure I'll crack it one way or another. Thanks again.
