Old 03-10-2006, 11:00 AM   #29
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
The Winner?
Originally Posted by lewster
2004 Dodge (Mercedes) Sprinter van LOADED (14,990 CGVW) pulling a 2006 19CCD........15.5-16.5mpg. By loaded, I mean a van full of service tools in roll-away cabinets, a 600 lb motorcycle and a bunch of other stuff .
Not knowing the weight of the 19' CCD, this could be the most efficient rig.
How much does the 19' CCD weigh?
Every time I go to buy a new rig diesel is just out of reach for my needs.
Rob
fastrob is offline   Reply With Quote
Old 03-10-2006, 01:08 PM   #30
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
With the cost of diesel higher and the initial cost of the truck higher is it worth it?
If I remember correctly, when I was at the GMC dealer last week, I think the Duramax/Allison combo was $7555 on the sticker.
Assuming 12000 miles per year at 18 MPG with $2.60 a gallon diesel compared to a similar gas powered truck at 12 MPG with $2.40 a gallon gasoline, you net a savings of $667 a year. At that rate it would take over 10 years to recover the cost of the diesel.
When I purchased my diesel, I received a $6000 rebate on the truck, so I figure I got the diesel for free. At that time diesel fuel was 30 cents a gallon cheaper than gasoline.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 03-10-2006, 02:28 PM   #31
1976 25' Caravanner
Campton , New Hampshire
'76 Caravanner 25'
'03 chevy 2500HD D/A 4x4
Thru the hills of NH, ME, and VT , 14-15 mpg
On a flat inter-state 17mpg @ 65mph
Pick had some good observation on Diesel vs Gas . One other thing to remember about a diesel , a good portion of the extra initial cost comes back in trade-in value . If you don't tow much distance it probably doesn't pay. If you do a lot of towing and put a lot of miles on per year , the numbers change significantly
ticki2 is offline   Reply With Quote
Old 03-10-2006, 10:06 PM   #32
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Towing Fuel Mileage
  • 1964 Overlander International -- 6,100 pounds gross weight
    • 1999 GMC K2500 Suburban, 7400 VORTEC, 4.10 Differentials
      • Solo 14-15 MPG (65 MPH maximum)
      • Towing 11 - 12 MPG (55 MPH maximum)
      • Towing in Rocky Mountains 9-10 MPG (55 MPH maximum)
    • 1975 Cadillac Eldorado Convertible, 8.2 Liter V8, 2.70 Final Drive
      • Solo 11-12 MPG (65 MPH maximum)
      • Towing 9-10 MPG (55 MPH maximum)
  • 1978 Argosy Minuet 6.0 Metre -- 3,050 pounds gross weight
      • Towing 12-13 MPG (55 MPH maximum)
      • Towing in Rocky Mountains 11-12 MPG (55 MPH maximum)
With either of my coaches, I utilize Overdrive when towing with the Suburban -- the directive in the Owners' Manual approves with the advisory to downshift to Direct Drive if the transmission begins to hunt. I now have in excess of 160,000 miles on the Suburban with no drivetrain problems other than an electronic trnasfer case module that routinely fails at about 15,000 mile intervals. I am still waiting to make my first trip to the Rocky Mountains with the Cadillac/Minuet combination -- the trip must wait until the suspension/wheel clearance issues are solved on the Cadillac.
Kevin
Kevin D. Allen
AIR #827
Old 03-11-2006, 12:30 AM   #33
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Originally Posted by Gen Disarray
Pulling my Trade Wind with my 91 f150 I get about 8mpg and I dont move all that fast
Well don't feel too bad. I get between 9 and 10 with my 95 f-250 460 cid towing my Caravel around. Heck I get 9 no matter what. Just like my dads ol' 72 f 250.
I can get it down to about 7 mpg if I decide to have a lead foot !
Chris
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 03-11-2006, 04:03 AM   #34
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
Towing Mileage
Hello -
We get 12-13 on flat ground (Indiana, Ohio, Michigan, etc.) and 10-11 on hills (Mass., Pa, Maine, New Brunswick, Nova Scotia).
2002 Silverado, 4.8 Liter with towing package towing a 2005 28' International - 60 mph (unless we're going downhill!)
Happy Streaming!
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 03-11-2006, 06:53 AM   #35
lewster's Avatar
Naples, FL , Hood River, OR
Sprinter weight
Rob
If I recall, the Sprinter weights are as follows:
GCVW: 14,990
Max trailer weight: 5000
Max cargo capacity: 3800
Empty vehicle weight: JUst under 6000
I'll look it up in the manual when I get a chance
Old 04-26-2006, 10:48 AM   #36
2003 25' Safari
Eden Prairie , Minnesota
2005 Ford F-150 Crew Cab 5.4 liter 3.73 gears
2003 Airstream Safari 25
Towing: at 55 mph 13 mpg
Solo: at 55-60 mph 19-20 mpg, at 70 mph ~17 mpg
Both lightly loaded, little wind, level to slightly rolling hills.
Big hills/mountains and/or city traffic kill the mileage (footage?).
Dan
dmac is offline   Reply With Quote
Old 04-26-2006, 11:21 AM   #37
bradk's Avatar
2006 19' International CCD
Calgary , Alberta
Images: 14
2005 Nissan Pathfinder LE - 270hp V6 - 200-300lbs of stuff
2006 Airstream 19' CCD - full fresh tank, full propane.
Surprisingly - 15.8 L/100km (15mpg) from Montana back to Calgary at 60mph, 13.8 (17mpg) from Calgary to Montana to pick the trailer up just 'slightly' quicker.
b.
bradk is offline   Reply With Quote
Old 04-26-2006, 11:29 AM   #38
ankornuta's Avatar
Lowell , Massachusetts
Images: 22
By the way.....
22.5-23.5 with out the Bambi. The van has a 2.7L Mercedes diesel mated to a 5 speed automatic with manual shifting capability. Don't have a clue as to the rear gears.
Lew, what kind of power/acceleration do you have on steep hills and mountain grades with that rig? I was looking at those and they're pretty neat.
ankornuta is offline   Reply With Quote
Old 04-26-2006, 11:30 AM   #39
ankornuta's Avatar
Images: 22
I got about 11-12mpg towing a 26' 1958 Overlander with my Jeep Grand Cherokee Ltd (5.7 liter Hemi - about 340hp - and all-wheel drive). That was, before I completely disassembled the trailer.
Old 04-26-2006, 11:40 AM   #40
PunkZTT's Avatar
2003 22' International CCD
Tempe , Arizona
Images: 14
Send a message via AIM to PunkZTT
2005 Nissan Frontier w/ 22ft CCD
I get around 11-13mpg towing through the mountains around AZ.
PunkZTT is offline   Reply With Quote
Old 04-26-2006, 11:51 AM   #41
1984 31' Excella
Norfolk , Virginia
Images: 11
Towing Fuel Milage
1984 31 Ft. Excella
1990 GMC Rally STX, 5.7L (350ci) 4:11 Positraction, LT245/75R16 LRE
11-14 towing on flat land.
19-22 No trailer
Beginner is offline   Reply With Quote
Old 04-26-2006, 12:15 PM   #42
Waterman's Avatar
1999 25' Safari
Wailuku , Hawaii
Towing Fuel Mileage
Towing 1989 32' Excella 1000 - 13.5 - 15.0 depending on wind/terrain @ 55MPH with mixed traffic conditions (some slowing and stopping)
Towing 1999 25' Safari - 14.5 - 15 MPG so far - trailer is new to us and we have not taken it on enough trips to know if we can do any better. Rarely drive over 62 MPH when towing.
Empty: 17.5 to 20.5 MPG mixed driving and highway mileage mostly @ 62 to 72MPH
Was kind of surprised we did not do better with the Safari but most of the lighter weight is probably offset by the wide body and more wind resistance....
'99 Dodge Quad Cab 4X4 Longbed with canopy - 24V Cummins Diesel
Waterman is offline   Reply With Quote
Towing Experience app Tow Vehicles 9 04-19-2004 09:51 PM
Kohler Fuel shutoff problems rdm Mechanics Corner - Engines, Transmission & More... 5 11-12-2002 07:11 PM
Towing Regulations by State InsideOut Towing, Tow Vehicles & Hitches 2 09-16-2002 07:35 AM
Towing cars CBBOB Airstream Motorhome Forums 13 07-24-2002 08:15 PM
fuel pressure PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 3 06-09-2002 08:40 PM
