Old 07-11-2016, 10:17 AM   #71
N/A , N/A
Originally Posted by jcl View Post
For your items 1 to 4, it would be silly to expect such things. But your error is in thinking that those factors are somehow limiting for a specific vehicle. They may not be. Consider a heavy pickup truck with a 10,000 lb tow rating. Install a 3500 lb receiver on it. Your combination is now rated to tow 3500 lbs. But what about your transmission cooler, your engine torque, your large brakes? Irrelevant to the 3500 lb rating. Now consider that the 3.5 Ecoboost can tow 10,000 lbs in many trucks. Install that same power train in a sedan with 1000 lbs less curb weight. Why would engine power then be a tow limitation?
As to your item 5, "road hugging weight" is a joke as much as it was when it was an advertising slogan in the 1960s. Spend the time setting up the combination. If you are relying on TV weight to compensate for improper setup, the battle is already lost.
I agree that its silly to expect items 1 to 4 for receiver reinforcement and WDH setup -- That was exactly my point. A Chrysler 300 with receiver reinforced is still a Chrysler 300 with 1000# tow rating as nothing regarding pulling/stopping power, transmission, cooling system has been addressed.
As for weight, there is a technical article regarding TV stability and one of the most important factors in stability of bumper pull rigs is the relative weight of TV and trailer. Sorry could not find the link.
I think we are getting into another cycle so I'm going to stop.
rostam is offline   Reply With Quote
Old 07-11-2016, 11:13 AM   #72
bono's Avatar
Mountain View , California
You are not... for sure.
bono is offline   Reply With Quote
Old 07-11-2016, 11:33 AM   #73
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We can only hope.
Doug and Cheryl
Old 07-12-2016, 01:34 AM   #74
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Well, My FC19 is using a Chevy Traverse for a TV. I learned from Bigbear it is not enough. So I have been shopping for a TV with around 10k TC. The wife is leaning towards F150/F250. Now, the argument becomes, whose money is gonna buy it? Mine or hers? I prefer to spend my money on the 2nd Amendment, while she prefers a purses.
I believe a TV with tow as part of the design is the way to go.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 07-12-2016, 02:31 AM   #75
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Here's my suggested answers:
F150/F250...... F250, of course
His/Hers...... 1/2 and 1/2???
More 2nd Amendment
More purses
Everyone's happy!
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
Blessed and highly favored
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 07-12-2016, 05:56 AM   #76
bono's Avatar
Trucks were not designed to tow. They were design to move cargo.
Old 07-12-2016, 06:19 AM   #77
Gainesville , Florida
Isn't cargo moved on trailers? What is used to pull the trailers? Cars are designed to carry people, otherwise they wouldn't need to be modified to pull a trailer. Use what you want, your business.
Old 07-12-2016, 03:37 PM   #78
bono's Avatar
Semis were designed for towing. If you are using truck, SUV, minivan for towing, you are compromising different matters (payload, braking, power, handling, number of passengers on board, etc.) with each of them.
As an example, I can't stand the handling of a truck, which in my option is not safe even without a trailer behind. This a subjective opinion, so no need to start a war.
Old 07-12-2016, 03:48 PM   #79
We had a roofing supply trailer at about 12000 pounds towed with a dually diesel truck designed for that. Show me what else would tow thst trailer. If you can't use a truck, suv or minivan then what do you tow with? A properly set up crew cab truck with payload in the bed is the best vehicle for towing. That's my opinion.
Old 07-12-2016, 03:50 PM   #80
Actually some would say a semi is just a heavy duty pickup with the bed removed and a fifth wheel hitch installed. On a larger scale.
Old 07-12-2016, 04:08 PM   #81
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I did find regulatory laws for Australia that specify capacities. They have to have ratings that match vehicle, hitch AND weight bars, and be within weight limits of the trailer being towed. Very specific. It ends up saying must comply with Australian standards. Interesting. I do not think things are spelled out well here but they may need to be considering all these tiny houses that are being built and towed around. Look out honey, a 2x4! Lawyers have to make a living too.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 07-12-2016, 11:19 PM   #82
2017 27' International
Box Elder , South Dakota
Flat bed tow truck
Does anyone use a tow truck, with a flat bed, to haul a small car as well as to pull the Airstream? Not worried about gas mileage.
alphamale49 is offline   Reply With Quote
Old 07-13-2016, 12:38 AM   #83
Thiss's Avatar
1971 27' Overlander
Monmouth , Oregon
I don't, but I sure wouldn't be afraid to if I had a race car and the money to go around the country.
1971 Overlander Twin bed, rear bath.
2016 Ram 3500 Cummins 4x4 Crew Longbed
Thiss is offline   Reply With Quote
Old 07-13-2016, 06:16 AM   #84
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
I wonder is this approach would work in North America. The tow rating, as far as I can tell, is not really measurable. No manufacturer has ever published the methodology by which they arrive at their rating and without that, how could you prove that a tow rating was valid or not? It's different for a tire or axle rating, of course, because that's a simple measure of downward force on the component. The rating will be set to a point prior to failure and will have been tested and documented. I really don't think you can do that with a tow rating because there are so many variables.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Subwoofer no work-y and TV capability TennisMan 2007 Safari SE 7 04-14-2018 03:29 PM
'76 Agrosy MH: Towing capability? MrJ Argosy Motorhomes 3 09-08-2014 09:52 AM
Shorewwod RV - Anoka MN - Service Capability TomR Commercial Listings 11 09-10-2006 06:25 PM
Increase Load Capability? RDM16CCD Axles 18 03-15-2006 04:15 PM
Towing equipment basics Craig Towing, Tow Vehicles & Hitches 11 04-19-2003 11:36 AM
