Old 01-09-2003, 09:18 PM   #21
eikel1we's Avatar
1975 25' Tradewind
, Michigan
Send a message via AIM to eikel1we
Hi to the towing gurus !!
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
2004 GMC Yukon XL 2500
Michigan - "middle of the mitt"
eikel1we is offline   Reply With Quote
Old 01-09-2003, 09:37 PM   #22
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
Send a message via AIM to thenewkid64 Send a message via Yahoo to thenewkid64
Oscar,
There are a number of reasons for the increased weight.
1 Bigger and more holding tanks. In 63 they had no grey water tank and the fresh was 20 gallons. Today we have 3 tanks and the fresh is 50 gallons. 30 gallons of water can weigh alot.
2. All of the units today come with AC and a awning as standard equipment. These were options that could be added, usally after manufacture, but as an owner you need to add them to the weight of the trailer. This means that published numbers can run lighter for older models.
3. Stuff. The older trailers had less storage than todays trailers and so the new ones have more cabinets to hold all of the stuff we "have" to take with us. Also those cabintes in the 60's were made of medium hard wood plywood, not the oak that is used today in many of the models. As a hard wood oak is very heavy stuff. Also they used to try to make them as light as possible, but now they don't seem to worry as much. I am thinking of John Irwin's drawers that weigh 8 LBS each empty. This is in a new 2002 international.
4. The newer trailers are wider than the ones from the 60's. I know I saw a list of the model year changes but I do not remember exactly. I think there is a 1 foot in width and a 6-8 inch interior height diffrence. This adds alot of weight even if it is alumimum.
Those are the biggest things I can think of, but I am sure that others can come up with a few more.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 01-09-2003, 10:29 PM   #23
eikel1we's Avatar
1975 25' Tradewind
, Michigan
It's me again (the non-computer person),
It would seem towing is one of the most questioned activities in AS Land. Including in my part of the kingdom. We passed on a 31' - '72 Sovereign LY. With the help of the great forums members we found we were under-powered.
We have, just today, passed on a '73 - 27' Overlander. Checked with Overlander '64 (Kevin) and found we are still under-powered. There seems to be a pattern developing !
We have a '97 GMC Sub - 4x4 - 1500 series towing pkg. with about 70K easy miles. What WILL the ..um....DARN thing tow (she says losing patience)?
We started out with an eye for and still would love, a Tradewind - '69 - early '70s. We have an idea of the features we'd like but don't know the year best to fit those desires.
Any thoughts thankfully appreciated,
suz and ike
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
Old 01-10-2003, 07:48 AM   #24
dmreilly10000's Avatar
1953 25' Cruiser
Canton , Mississippi
Images: 14
My 1963 Overlander (now sold) had no grey water tank. Most all the cabinets and other builtins were covered with 1/8th inch plywood veneer. The walls were painted aluminum - no covering. Floor was originally linolium, no rug. A far cry from my 10,000 lbs 1991 34' Excella.
dmreilly10000 is offline   Reply With Quote
Old 01-10-2003, 11:38 AM   #25
Send a message via AIM to keylime
Compliments of Airstream
Cover page from the owners manual ('65 TradeWind), no hefty truck, but a swell looking convertible.
regards...
keylime
keylime is offline   Reply With Quote
Old 01-10-2003, 12:55 PM   #26
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Sub pull
Suz, your Suburban manual should state what it's towing capacity is. Just remember to try and stay alittle under that limit (some say 75-80%). That's where I'd start. Also try a search in the forums under "towing" or "suburban." There was also a poll recently about what the members used to pull....a lot seem to have 1/2 ton p/u's. Your Suburban is a close relative. A clue to how much a relative trailer weighs is the Gross Vehicle Weight rating on the front road side. There should be a plate there with this info. I say "clue", as only actually weighing the trailer will you have an accurate number. Happy hunting - the Tradewind sounds fine.
Marc
Old 01-10-2003, 01:05 PM   #27
Road Ruler's Avatar
Images: 38
Thumbs up
Key lime....
Swell is right. You could also describe it as
"vacationing Al a carte".
Can't do it much better than that.
Wonder if the Plymouth has a Hemi under the hood?
Old 01-10-2003, 11:54 PM   #28
eikel1we's Avatar
1975 25' Tradewind
, Michigan
SUB PULL
MARC,
THANKS FOR YOUR INPUT. IKE HAS CHECKED THE MANUAL BUT I GUESS THERE ARE A NUMBER OF VARIABLES TO CONSIDER. WE'RE LEARNING - THANKS TO THE GREAT AIRSTREAM SITES AND ESPECIALLY THE GREAT PEOPLE !
suz
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
Old 01-11-2003, 07:49 AM   #29
Road Ruler's Avatar
Images: 38
Re: towing Airsteams in the 1960s ???
Originally posted by oldvws
Hi.....
When you look at all the old pictures from the 50s-60s you see them being towed by normal passenger cars.
Now everyone wants a big block V-8 or a Turbo Diesel.
So my question is "How did thy do it "
thanks for your thoughts.......
Not everyone wants at truck or turbo diesel although it is obviously the choice of a few of the more active forum members. True, large heavy Airstreams do have high demands especially when towing in the mountains.
Yes the were many sedans towing Airstreams in the 50's, 60's, & 70's. They got the job done but didn't do it with much finesse by today's standards.
In reality there are hundreds, perhaps thousands of late model cars and minivans competently, and safely towing RV's today and they are doing it better and safer than the passenger cars of 30 or 40 years ago.
In a nutshell modern technology has produced some very competent tow vehicles ( sedans, and minivans) that over the past 20 years of use and, on the road testing have proven to be a great success.
Many modern day towing experts now use a different approach when evaluating potential tow vehicles. Whether a vehicle has a frame, unit body, or combination of both is of secondary importance. If it weighs 3.500Lbs or 6,500Lbs again is not necessarily the key to a evaluating a successful tow vehicle.
A vehicles handling, stability, traction, braking characteristics and other key factors are now looked at as well as the vehicles weight carrying ability and axle load ratings.
Years ago when we drove on low tech tires a vehicles weight was used to "push down" on the tires to produce traction. The heavier the vehicle the better its ability to get traction. Today modern vehicles "tire to road" traction factor has much improved with the use of high performance suspension systems, sticky low profile tires etc, thus diminishing the need for weight to be the medium to "get grip".
Current technologies found in every part of vehicles that we are all using and taking advantage of are far superior than those found in the vehicles of the 60's and 70's. The thought of towing with a vehicle from the "60's" with non anti lock drum brakes, 78 series bias ply tires, no seat belts, etc is hard to imagine when you compare them with the vehicles of today.
Old 03-24-2003, 10:28 PM   #30
Station Wagons forever
RoadKingMoe
And others have already mentioned the older cars' full frames, torquey big-block motors, and truck trannies. Today, cars are made as absolutely light-duty as possible for higher gas mileage. They use smaller engines and get horsepower through rpms rather than torque. (HP=(torqueXrpm)/5252). The SUVs of today are just the full-sized station wagons of the 60's. Problem is the trailers have gotten a lot heavier, so larger tow vehicles are necessary.
RoadKingMoe is right on the money, as usual.
I love classic station wagons, from late 60's and early 70's, especially mopars.
  • They used to be easily available and frugal, cost-effective.
  • Lots of power and lots of room
  • More stable on the highway with lower center of gravity
  • Easiest vehicles to work on than modern cars, no computers. Easy to replace water pump, fuel pump & filter, radiator, spark plugs, anything
  • That classic feel instead of driving a plain-jane vehicle without a personality
The downside was - abysmal mileage, rust and relatively poor handling. Body fit wasn't as good, more noise while driving. Lately, there is another problem: Getting replacement parts. They are becoming rare.
I almost bought a 1965 Dodge Coronet Station wagon. Problem was, it doesn't run well on modern fuel. I don't remember if it had a towing package, probably not. I also almost bough a 1967 Plymouth Valiant with 30K original miles but parts for it really hard to find. It also had that 287 (?) engine, not 318.
The old 318 engine (still produced for Dodge RAM) is the best small block V8 available IMO, I couldn't wear mine out. For serious towing, I would want a 383 or 440, I think - and they would get less than 10 mpg. <sigh>
So if you want to do it right, tow your classic 1960's Airstream with a 1960's classic station wagon. <g>
In the context of A/S and towing - well, I think I would rather have a modern truck. Due to suspension.
Justice - When you get what you deserve. Mercy - When you don't get what you deserve
Grace - When you get what you don't deserve
ipso_facto is offline   Reply With Quote
Old 03-24-2003, 10:34 PM   #31
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I would just like to add that almost any GM V8 (with the right stuff and I know there are exceptions), could pull. GM killed the full perimeter frames after the 1996 model year. I have an '80 Delta 88, now in retirement that pulled upwards of 3400 lbs. The current '96 is factory rated 5000lbs of tow capacity.
I don't think the towing left until after 1996 and you either then needed to jump ship and go with a Crown Vic (that never had the guts like the GM counterpart) or you had to go with a truck or SUV (higher profit margin). But from the 60's to the mid to late 90's, small blocks were around and up to the task.
Eric
Old 03-24-2003, 10:58 PM   #32
Silvertwinkie
Indeed what a disappointment when GM killed both the Chevy Caprice and the Roadmaster. My Caprice has a towing package for 5,000 lbs. It doesn't, however have the LT1 'vette engine available for '94 to '96 years, which was well over 200 HP.
If I were intested in a smaller A/S, like Bambi or something, I would have used that. Fantastic as a daily driver. I do think earlier SW were a bit more "heavy duty" than this one.
Now GM doesn't offer a small block V8 sedan, period, neither does Dodge. Ford does, but not in a SW configuration and I don't know their towing ratings. You have to get the dreaded SUV or a truck.
A SW is a one size fits all kind of thing but a diesel truck is in fact better for serious towing, it is the ultimate towing vehicle for anything bigger than 30' - IMO
Old 03-25-2003, 09:37 AM   #33
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Ipso: just an fyi: the last production year for the 318 was 2000. I got one of the last ones....
Our resident Chrysler engineer tells me I should've gone for the 4.7 that replaced the 318 maybe....but I think I'd rather wait until people are saying "that engine has been the most reliable thing for the last 30 years!" LOL!
Old 03-25-2003, 09:41 AM   #34
Aluminut
2004 25' Safari
. , Illinois
Ipso,
I have the LT1 and it's great. The smaller engine also does a very good job. The station wagons could tow a bit more due to the extra support metal the wagon has by it's nature.
I agree that for anything over 5000lbs, a truck is the ony way you can go lately. I have heard that Dodge is going to put a car out with a Hemi, and GM is also bringing back the RWD cars, but most if not all will be unibody and as such won't safely be able to tow like an SUV or truck with a full parimeter frame. I'm glad that I got the Caprice and the Impala in '96 before they rode off into the sunset.
On a side note, a bunch of the components that went into the pre 2000 Chevy trucks are the same parts in the B-Body (Caprice, Impala, Roadmaster and D-Body Fleetwood). With minor modifications you could get the tow rating up to about 6,000-6,500lbs just like their truck counterparts.
Pulling Bambi is like there is nothing back there!
Eric
Old 03-26-2003, 10:49 PM   #35
Silvertwinkie,
You have the ultimate combination. Caprice with 260 hp LT1 and 19' Bambi, that must be awesome. I towed a trailer which weighted more than that with my Caprice for 2,000 miles. I did it in over-drive - stupidly, as I found out but it can be done. I was going 70 and the MPG went from the usual 22+ to 9. RMPs must have been pretty high. Anyway, it is a great combo you have there.
Something better options-wise than Chevy is a '94-96 Buick Roadmaster. You can easily find these pretty cheap. New, these vehicles were $27,000. I heard GM was losing money on them. And now, you can find them in good shape for 1/8 of the price. Pretty good deal I think.
Caprice/Roadmaster station wagons are the pinnacle of station wagon tradition. The bigger V8 offers plenty of power for towing these smaller units. Yet with overdrive, it gets 22-24 MPG on the highway, which is remarkable for a V8. In the 60's, these big block V8 got what, 10? Mileage wasn't even a concern then, with gas 20 cents per gallon. The gear is high enough where engine noise is not a problem. They are aerodynamic with a low center of gravity, thus making them far more stable than SUV and trucks with better road handling. The wheelbase is pretty long, one of the longest in passenger cars. The cargo room is outstanding.
A SW is a strange beast. If you need a sports car, they are not as good as a sporty car. If you need a truck, they are not as good as truck. But if you don't know what you need and want a multi-purpose one-size-fits-all kind of vehicle for occasional towing of a light unit, you need a station wagon. Furthermore, you want a SW.
http://www.stationwagon.com/gallery/gallery.html
chuck
Good. In the 70's chrysler products, various Dodges and Plymouths were used in Los Angeles and SF as taxi cabs and were getting insane mileage - 200,000, 350,000 miles and more. With 318. Slant six is yet another great engine also capable of extremely high mileage. 150K for these engines is nothing. The body will rust away before you break the engine and given that your truck has been galvanized, it won't rust like 70's mopars.
After early 70 and emission control, 318 lost a lot of HP. By mid 70's it only had a mediocre 145 HP. So I wouldn't use that to tow an A/S. Look for 60's and they are impossible to find and when you do find them they are expensive if in good shape. The late 70's were the worst of all worlds. With emission stuff, their HP was way lower than in 60's, yet their MPG was terrible. With thinner steel, they were more susceptible to rust.
Plus in '78, Chrysler was on the edge of bankruptcy and their products reflected that. I looked at a '78 Plymouth "Custom Suburban" SW (one of these super long SW) and the quality was nowhere near the level of 90's GM products and they lacked the simplicity of late 60's and early 70's classics. You have to be a SW fanatic to like one of these. Which the owner was. Even put it on www.stationwagon.com.
I got a truck, I don't practice what I preach.
Old 03-27-2003, 07:11 AM   #36
Aluminut
2004 25' Safari
. , Illinois
Ipso,
Nice wagon site. The Caprice LT1 is a nice tow vehicle. I have modded it out and I am currently at about 274hp and 334ft/lb torque. I plan on adding some headers and a more free flowing exhaust. I hope to have it at or slightly above the 300hp mark by the middle of summer if possible.
The only complaint I have is when a car flies by me at over 75-80 or a truck going 65, the whole rig shakes. I know what causes it, I'm just not sure if it would be reduced if I had a truck.
As for pulling though, 9-10mpg is what I get towing. And you're right on the money when I'm not towing, I get about 22-23hwy.
BTW, my MPG was based on being in regular "D" non- overdrive. I have found though that if you use overdrive, you can still tow, but you must make sure the torque converter is locked at it's respected RPM band. For me it's between 1400 and 1800 rpms.
Regards,
Eric
Another towing question ipso_facto Our Community 34 08-28-2010 03:47 PM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 08:05 AM
Just found-great towing guide! maxandgeorgia Towing, Tow Vehicles & Hitches 0 03-21-2004 08:19 PM
Airbags and Towing with Car mcostanzo Tow Vehicles 0 07-02-2003 02:40 PM
Frequently Asked Questions about towing femuse Towing, Tow Vehicles & Hitches 3 04-19-2003 09:29 PM
