Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 04-25-2005, 08:57 AM   #1
Thomas Wille
Profile:
Towing Advise
I recently purchased a 98, 25' Safari. Looking for advise as to towing this unit.
I have a 2001 Jeep Grand Cherekee V8. with a factory tow package.
Thoughts on additional towing devises, braking etc would be appreciated.\
Regards,
Tom Willey
Thomas Wille is offline   Reply With Quote
Old 04-25-2005, 09:10 AM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Rivet
Regards,
Tom Willey
Tom, first of all, welcome to the forums!
Do you have a brake controller? Can you see around the trailer effectively? Does your towing package include a transmission cooler? Do you know if you have a charge line from the tow vehicle to the trailer? This uses the tow vehicle's alternator to help charge the trailer's battery while you are towing. Also, is you Cherokee 2WD or 4WD? A very quick recomendation I can sefely make, is if you have organic gear lube in the differential, to get it changed and replaced with synthetic gear lube. This can better handle the heat generated by towing a heavy load at high speeds. Many are the Chrysler truck owners that found out about this inexpensive upgrade too late.
Change is inevitable, except from a vending machine
AIR#2611
Old 04-25-2005, 09:54 AM   #3
vajeep
vajeep's Avatar
Profile:  1976 27' Overlander
Richmond , Virginia
Images: 49
Jeep Grand
Tom,
I asked this question about a year ago. Many towing "opinions" are offered on our forum. I like the forum because I feel that you always get honest real life answers. Often the answers are not what I want to hear, but that is what I like about the fourm.
http://www.airforums.com/forum...ead.php?t=5607
As for us we found that our Jeep Grand was not really a great tow vehicle for the trailer that we wanted. We sold the Jeep and got the 2500 Suburban.
Much has been discussed about using a Jeep as a tow vehicle, just search under Jeep.
Good luck in your information gathering!
Abe
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
WBCCI# 7627 / VAC
Air #2798
vajeep is offline   Reply With Quote
Old 07-10-2005, 07:24 PM   #4
rudderdancer
rudderdancer's Avatar
Profile:  1982 31' Excella
Victorville , California
Unhappy tow vehicle drifts at times with trailer hitched
Help. I'm currently on vacation with our 31 ft and Chevy Avalanche. At times when hitched, the truck wants to drift left or right. It seems unrelated to any wind. Could there be something wrong with the tandem wheels of the Airstream? The truck was aligned right before we left. It only happens when we're towing not when unhitched. It this just something common?
rudderdancer is offline   Reply With Quote
Old 07-10-2005, 07:51 PM   #5
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
rudderdancer,
welcome to the forum!
do you have a friction sway control? is it set too tight?
john
you call them ferrets, i call them weasels.
Old 07-10-2005, 07:54 PM   #6
j54mark
Profile:
No, this is not "something common". It is a serious problem and needs to be addressed before you have an accident.
Is this something new, or is this your first experience with this coach and tow vehicle combination?
What kind of hitch? Does it have load distributing bars? Does it have sway control of any kind? Is the coach/hitch set up to ride level? Have you checked the air pressure in all four coach tires? How about the truck tires' pressure?
Do you have a 1/2 ton Avalanche or 3/4? Isn't the wheelbase on an Avalanche pretty short for a 31' coach?
There are other questions which come to mind, but we need all but the last answered first.
Mark
'85 Sovereign, 25'
Towing Experience app Towing, Tow Vehicles & Hitches 9 04-19-2004 09:51 PM
Towing Regulations by State InsideOut Towing, Tow Vehicles & Hitches 2 09-16-2002 07:35 AM
Towing cars CBBOB Airstream Motorhome Forums 13 07-24-2002 08:15 PM
towing enclosed racecar trailer fangthorpe Mechanics Corner - Engines, Transmission & More... 1 06-30-2002 04:45 PM
Towing my 1964 Safari Neenm Towing, Tow Vehicles & Hitches 6 06-28-2002 04:26 PM
