Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 10-27-2003, 06:58 AM   #1
BURNZEE's Avatar
Riverside , Missouri
towing a '66 Safari
I am looking at purchasing a 22' 66 Safari. For the short term future, I would be moving/towing it with a 66 GMC 3/4 ton truck. Since I am new to this kind of thing, I was looking for opinions on wether this truck can tow a trailer like this. I would only use it to tow the trailer within a 60 mile radius, but usually more like 20 miles at any one time. Truck is very sound mechanically. Also, does anyone know the tongue weight of this trailer? Thanks for your help and opinions.
BURNZEE is offline   Reply With Quote
Old 10-27-2003, 07:50 AM   #2
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
My biggest concern with the truck is the Drum breaks being over heated by the aditional weight if the trailer breaks are not up to snuff. Get a GOOD break controler like the Jordan or the prodigy and if the truck brakes are up to snuff you should be ok on that front.
Next question is engine size in the truck. 252 and 292 I would have some concern but should be ok otherwise.
Lastly is the gear ratio. In the 60's GM wasn't so timid about putting in some gear because it was before the gas crunch. You probably have a 3.73 gear and you should be fine.
Trailer is going to be about 4,000 lb loaded simular to our Caravanner. Our caravanner has bad manners without a sway control of some sort. Single axle trailers with a lot of isde area seem to have this trait. Don't even notice it with the sway control.
I would recomend 750lb weight bars and Dual cam Reese set up. Seems to work very well on ours. At the very least get a friction sway control.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 10-27-2003, 05:38 PM   #3
BURNZEE's Avatar
Thanks 59 toaster. This is super valuable information. Took the plunge and purchased the airstream. I'll be picking it up tomorrow. I'll probably have many questions in the future.
Thanks again.
Towing 19ft Bambi with 2009 Tacoma v6sr5 w towing package Shany Tow Vehicles 6 07-03-2017 10:44 PM
Sprinter one-ton towing/non-towing hwy mpg? gecko Tow Vehicles 18 08-02-2014 10:57 PM
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
Towing my 1964 Safari - what tow vehicle do I use Neenm Tow Vehicles 6 06-28-2002 04:26 PM
