10-03-2011, 11:57 AM
lander
, Wyoming
Towing a 34' triple axle airstream
Hello; i just acquired a 1977...34'.....triple axle airstream which was delivered to my home. Question: I have a 1991....4x4 ford van with a 351 engine..........will this be adequate to tow the trailer safely from point a to point b (1200 miles)? I do not plan to tow the trailer on vacations etc., just tow it to a warmer climate in the winter and leave it there. It is possible that i will only tow the trailer once.......and worst case would be towing it once every few years! Thanks
10-03-2011, 12:07 PM
moderator
Brandon
, Mississippi
If it IS a '77 then it's a conversion 34'. I've seen photos of 1 triple that was an extended 2 axle. The production 34's started in the early 80's. If your's is a custome build it will be hard to make broad statements because we don't really know the weights and details.
Towing...it's gonna need a higher ratio (low geared) rear end in the van. Ya' know what ratio you have?
10-03-2011, 12:36 PM
1982 34' Limited
Brunswick
, Georgia
I believe the first year of the 34' production models was 1982.
You will find many opinions on tow vehicle setups here. I would look at mfg ratings, gear setup, and wd hitch numbers to help make that decision.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
10-03-2011, 12:40 PM
lander
, Wyoming
34' towing
Yes, it is a conversion trailer.....the front end was wrecked. All the pieces and parts used in the extension were purchased from airstream and it is a very good job......not a hatchet piece by any means. I do believe my van is geared 3:51. I do not care about getting anywhere fast......just safely. Thanks for your reply!
10-03-2011, 12:43 PM
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview
, New Mexico
Do you have any pictures?
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2006 F250 superduty crewcab
10-03-2011, 01:01 PM
Montreal
, Quebec
A Taurus SHO
I know you guys will think this is nuts, but last weekend while I was at my dealer, CanAm in London, ON; Andy let me drive one of their setups, a Taurus SHO with the 3.5l Ecoboost (similar but not the same as used in the F150) pulling a 34' tri-axle.
I would only recommend that before commenting  ; realize one thing , I drove it; and you didn't.
You wouldn't believe how awesome the combo was. I have no words to fully explain how great it felt. BTW, he used a Hensley connected to one of their custom reinforced receivers.
I should have taken pics!!
Ron
Montreal, QC
2010 Flying Cloud 30'
Dual Solar Panels, 1500w Inverter
4 Lifeline Group 27's
KVM R4LS HD Satellite
Honda EU3000
2012 ML350 BlueTec Diesel
2012 RAM 1500 Laramie Longhorn 3.92
Hensley
lander
, Wyoming
Hope this comes through!
1977 airstream.
10-03-2011, 05:27 PM
'87 Avion 32S
grants pass
, Oregon
34 ?
Are you sure that's only 34' ? It looks longer than that.
Neat trailer,
more pics please.
1987 Avion 32S
Front Kitchen-Rear Bedroom
10-03-2011, 05:49 PM
"CLOUDSPLITTER" (tahawus)
Hoover Beach
, "Niagara Frontier" NY
Complete maint ck on the van, focus on brakes,trans and cooling systems.
Make sure you have an adequate WD hitch with working sway control.
Same on the AS, brakes, tires, working break-a-way switch, wheel bearings, lights and 7-way.
Drive careful and enjoy your new STREAM!!
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
 2006 3/4 Burb 8.1
Hensley
10-03-2011, 06:05 PM
moderator
Brandon
, Mississippi
Here is a top 10 thread for you, specially since you have a non-standard situation...
http://www.airforums.com/forums/f238...-in-17984.html
Tongue weight is the big question
10-03-2011, 06:31 PM
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant
, South Carolina
I blew up the picture and printed it off so I could compare measurements with my own 88 34.' I used the distance from the back of the back tire to the front of the front tire to establish a known length and worked out the rest.
Mine Floidoip
tires 7'8" 7'8"
rear overhang 10'0" 8'8"
front overhang 17'2" 20'0"
total length 34'10" 36'4"
If this thing is for real, that tongue weight has got to be very high. Mine is 700# and the distance from the wheels to the front of the tongue on Floidoip's is nearly 3 feet longer. Whew.
I would love to see more pictures.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
10-03-2011, 07:00 PM
Rivet Master In Training
1965 22' Safari
Mount Airy
, Georgia
That is a LOT of Aluminum !!!!
10-03-2011, 07:19 PM
"Bess" Full Timers
Suquamish
, WA
We've seen one of Andy's jobs in Ajo, Arizona, a 34 footer towed by a little dweeb ( no offense) suv. Client was overjoyed!
"A settled wisdom, plus the itch to be elsewhere"
10-03-2011, 08:17 PM
2002 34' Classic
Windsor
, Ontario
| Thread Tools |
| Display Modes |
