Old 01-13-2013, 06:23 PM   #1
Alexandria , Virginia
Towing a 31' Shell
Hello everyone, this is my first post and I am new to the forum. I hope to be an airstream owner really soon, which is why I am posting.
I found a 31' shell about 4 hours away. I am looking for some direction on how to secure the airstream and make sure I can get it back home safely. It doesn't have a floor. So, I was wondering if making sure the shell was secure to the frame and putting down a temporary floor with plywood would be sufficient to tow it securely.
Thanks in advance for your feedback.
Joshua - VA is offline   Reply With Quote
Old 01-13-2013, 07:13 PM   #2
1986 31' Sovereign
Miami , Florida
Tough, tough call. The Airstream is a monocoque structure. The floor definitely contributes to the structural integrity of the whole. Tow it without everything tied together an who knows?
I would have it flat-bedded home but that may be $$$.
Mike
Old 01-13-2013, 07:57 PM   #3
Protohyp's Avatar
1977 31' Excella 500
Los angeles , California
Send a message via AIM to Protohyp
I think even with a flatbed at that height the shell will be wanting to move and sway. There is probably now way to do it safely without a floor properly secured and the whole trailer mounted again as a unit. Look up Colin Hyde in New York. They do a lot of rescues. Sounds like it will be a lot of work to get it 4 hours to you
Protohyp is offline   Reply With Quote
Old 01-13-2013, 08:29 PM   #4
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Its a little risky but I have seen it done and we have heard about it here a time or two. The shell is just bouncing around on the outriggers held in place by the original bolts? Is the belly wrap still in place or can the wind whip up inside? Freeway speeds might make an incredible news @ 10 story.
Cheers.. Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 01-13-2013, 09:54 PM   #5
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
You could secure the shell to the frame by using some strips of plywood that were the same thickness as the original floor. You would need to remove the bolts (which are probably rusty anyway if the floor rotted out) slide the strips of plywood into the c-channel and install new bolts through the c-channel and strips of plywood and into the outriggers. That should get you home.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper (65avion.home.blog)
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
