Old 04-05-2019, 06:22 AM   #1
2018 22' Sport
Nashville , Tennessee
Towing a 22' Sport with a Clam Shell Adapter?
I recently purchased a BMW X5 (diesel) with the tow package. Max tow capacity is 6,000 pounds (tongue weight - 600 pounds). I currently have a 2" ball, but I understand that I need a 2 5/16" ball to tow our 22' Sport.
Has anyone ever seen this?
2" to 2 5/16" Clamshell Adapter
Will this solve my problem, or should I see about having a different ball placed on it altogether?
tkambler is offline   Reply With Quote
Old 04-05-2019, 08:10 AM   #2
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
Balls are cheap. I'd get a new ball. To put it on you'll need a good sized wrench to get the 450 ft-lbs of torque required. I did mine with a 26" pipe wrench from Lowes for $25.99.
out of sight is online now   Reply With Quote
Old 04-05-2019, 08:22 AM   #3
2014 22' FB Sport
Davie , FL
You can actually get a 2 5/16" ball already assembled on a 2" square ball mount. I think I got one at Home Depot for about $20.
Old 04-05-2019, 08:47 AM   #4
waninae39's Avatar
2017 22' Sport
NCR , Ontario
dont do that
the 2" receiver works as a system with the rest of the installed undercarriage towing equipment h/w. adding a larger ball will NOT increase your capacity.
the receiver size is tied to the capacity of the whole undercarriage towing assembly
unfortunately if you want to use the larger ball, you will need to update the undercarriage towing equipment as a whole.
if not, you may end up failure one day as you drive.
waninae39 is offline   Reply With Quote
Old 04-05-2019, 08:49 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
I just don't see that as a long term solution...maybe as an emergency option if stranded.
Buy the ball and be certain.👍
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 04-05-2019, 08:51 AM   #6
2014 22' FB Sport
Davie , FL
The Airstream coupler requires a 2 5/16" ball. The BMW receiver requires a 2" ball mount. It has nothing to do with towing capacity.
Old 04-05-2019, 09:16 AM   #7
1996 25' Excella
Tillsonburg , Ontario
But the new ball. Less than $20 at Tractor Supply Co.
JCW
JCWDCW is offline   Reply With Quote
Old 04-05-2019, 09:51 AM   #8
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
seriously, you're really thinking about this rather that obtaining a correct size ball to tow your new $50,000 AS you're kidding - right???
_________________________________
La Dolce Vita Brick & Mona
2004 International 25CCD "Blue Streak"
2013 F-150 SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
drbrick is offline   Reply With Quote
Old 04-05-2019, 09:53 AM   #9
2013 20' Flying Cloud
Westerly , Rhode Island
If you don't have the right ball the real question is what hitch do you have? Is it a weight distributing and sway reducing hitch or just plain shank with a ball?
I can't speak directly to the BMW you have, but towing a 22' with a vehicle rated at 6000 lbs., a good WD hitch is pretty much standard equipment. Lots of options, take a look at the Reese Straight Line hitch to give you an idea what you need.
smithcreek is online now   Reply With Quote
Old 04-05-2019, 09:55 AM   #10
Danger danger Will Robinson...🤪
Is he within the towing limits of the TV?
Cheese and crackers got all muddy...all the OP wants to do is toe his trailer. Has nutt'n to do with increasing anything.
I've swapped my balls many times, on AS's and boats, no problems.👍
W. H. Auden
Amanamus
"Tahawus"
Old 04-05-2019, 10:05 AM   #11
2014 22' FB Sport
Davie , FL
He's towing a 4500 lb trailer with a 450 lb tongue weight using a BMW diesel rated to tow 6000 lbs with a 600 lb tongue weight. Assuming he doesn't exceed the BMW payload limit by overloading the back of the car he's well within safe tow limits, with or without a weight distribution hitch.
Old 04-05-2019, 10:23 AM   #12
2017 16' Sport
West Palm Beach , Florida
I have looked in to this you can not use the BMW clamshell used in EUR it is a L shape receiver. It can not handle the USA trailer specs. Plus, the WD hitch has major effect on car frame. Call Cam-Am in canada to fix the car frame or you will have flex. BIG NO NO NO. Andy Thompson is the top person on car towing. Best trip you will make for car. IT IS A GREAT TOWING VEH with right fix.
truffies is offline   Reply With Quote
Old 04-05-2019, 10:26 AM   #13
1976 Argosy 28
London , Ontario
Hi the larger ball is designed for higher capacity tow rates and includes a shank that is a bit more robust as well - or so I've always assumed. Buying the larger ball and properly installing it is important. Ymmv. All the best with your adventures!
tree
SW Ontario Canada
28' Argosy centre bath (1976)
front and rear curved windows
Tree is offline   Reply With Quote
Old 04-05-2019, 10:44 AM   #14
Lots of reports of 22' having higher tongue weights than the specs state. Also, manufacturers often specify weights well below the max towing and tongue ratings where sway control devices or weight distribution hitches are required.
For instance, my Tacoma is rated 6500 lbs. gross trailer weight and 650 lb. tongue weight, but the manual states a sway control device is required above 2000 lb. and WD hitch above 5000 lb. Even with that requirement I can tell you, our FC20 weighs well under 5000 lb. and benefits greatly from a WD hitch.
Really not a great idea to advise people to throw caution to the wind without even knowing what the facts are.
Clam Screen Roomf Sold trumpetguy Airstream Classifieds 1 12-22-2017 07:20 AM
Happy as a clam Diesel75 Member Introductions 11 10-12-2012 01:38 PM
T@B (Tab) Camper / Tailgater - Clam Shell - Like Airstream - No Reserve! eBay Watch Airstreams on eBay 0 06-11-2012 05:50 PM
Towing Adapter for lights FloridaMV 1974 - 1979 Sovereign 2 01-25-2010 02:17 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
