Old 03-13-2019, 07:21 AM   #1
KPW
Vienna , Virginia
Towing 23í Flying Cloud with Silverado 1500
Was hoping to get some intel through searching this forum but canít seem to drill down to these specifics.
Would like to purchase a 23í FC (GVWR 6,000) and tow with our 2013 Chevy Silverado 1500 (GVWR 7,000) but am nervous about approaching that 7,000 maximum once hitch and passengers are added. I know that once we would get the rig, getting it weighed once full will give us data. But we certainly donít want to purchase a trailer thatís fundamentally too heavy for our TV.
Anyone out there towing a 23í with a similar TV scenario?
KPW is offline   Reply With Quote
Old 03-13-2019, 08:21 AM   #2
CAB & DAB
dbdreams's Avatar
2019 19' Flying Cloud
Fayetteville , Texas
KPW,
we have a 23CB and have towed one all over the states with an Armada, replaced the Armada (and trailer) due to an accident with a Titan. A half ton P/U works very well with the 23s. Ours have been on some very steep high passes in the Rockies and does very well. What engine and rear gears do you have? If you have the V-6 high altitude step grades will be a real challenge, with the V-8 you should be fine. Get a good WD hitch and plan your loading to get the weight where you want it and have fun.
David
dbdreams is offline   Reply With Quote
Old 03-13-2019, 08:32 AM   #3
2013 20' Flying Cloud
Westerly , Rhode Island
The first number you need is the payload rating which is GVWR minus actual gross vehicle weight. My guess is it's probably in the 1500 lb. range and you are fine as long as you don't overload the truck or front of the trailer. Next is max trailer weight. That will give you an idea how the truck is equipped as far as engine, axle ratio and hitch go. That one really depends on the exact model, engine, axle ratio, factory hitch, etc.
smithcreek is online now   Reply With Quote
Old 03-13-2019, 10:21 AM   #4
The gvwr is just for that vehicle. You want to look for the gcwr which is the max allowable combined weight of the tow vehicle plus the trailer.
WindRat is offline   Reply With Quote
Old 03-13-2019, 10:21 AM   #5
You will be just fine pulling a 23í with a 1500
Old 03-13-2019, 03:01 PM   #6
2017 23' International
hendersonville , North Carolina
Silverado towing
Yep, you should be OK. Couple items to check. Does your truck have factory tow package? Just because it has a hitch from factory does not mean it has tow package (trans cooler, oil cooler, high capacity radiator, higher amp alternator, brake controller). What axle ratio? (3.42 is OK, 3.73 is better). What are your tires rated at? Load range D is OK, load range E is better (higher capacity rating and stiffer sidewall for less sway possibility). Once you pick up your 23FB head to the CAT scales fully loaded with everything you are going to travel. That will give you the real picture. Happy travels.
uraljohn is offline   Reply With Quote
Old 03-13-2019, 03:06 PM   #7
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
I did it for years. We did however move up to a 2500 last year for increased payload.
Dept of ďOverKillĒ
Old 03-13-2019, 04:14 PM   #8
weirdstuff's Avatar
2018 23' International
San Diego , California
We tow our 2018 23CB with a Ford F-150 ecoboost with tow package. Have been all up and down the US and Canadian Rockies, and the Tetons. All good. But, we are also at maximum payload on the truck. Thatís with 2 adults, 1 50# dog, 2 mountain bikes. Surprising how quickly the payload adds up.
weirdstuff is offline   Reply With Quote
Old 03-14-2019, 09:31 AM   #9
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Our "Rule of thumb", right or wrong, has been to provide and extra 20% towing capacity to your tow vehicle based on max weight to be towed. This has always worked well, especially in the Rocky Mountains from the top of BC to lower NM.
Happy trails.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 03-14-2019, 10:00 AM   #10
2018 27' International
Jacksonville , Arkansas
Basically, you'll be OK.
Ideally - be sure to get the factory tow package, AND the built in Brake Controller.
On my GMC 1500, once the brake controller is calibrated to the trailer, stopping with trailer will feel much the same as without. Most folks worry about "pulling." Reality is many vehicles will get the trailer rolling, but stopping can become exciting if the trailer brakes aren't doing their share of the work. As said before, don't get the V-6. It's fine with an empty truck around town, but once you climb a hill with the trailer, you'll be trading trucks again. The 5.3 is OK for the medium trailers, especially if you have the 3.42 or 3.73 axle ratio. I'm using the 6.2 with a 27 ft AS, and I LOVE the torque and tow/haul mode. Good luck!
Deeno is offline   Reply With Quote
Old 03-14-2019, 10:20 AM   #11
2017 27' Flying Cloud
Volente , Texas
I’m pulling a 27FB with my 2009 Silverado 1500.
Jerry
Current trailer: Homebuilt "Standy"
Future trailer: 25 - 27 ft. Airstream
Donutboy is offline   Reply With Quote
Old 03-14-2019, 01:43 PM   #12
PCJ
2018 30' Classic
Eden Prairie , Minnesota
For years I pulled another camper that was rated at 5,500 LBS with a 1/2 ton Chev P-U that was rated at 9,000+ and it did pull it but . . . there were times with step hills you'd be happy with 45 MPH.
So that being said last year when we purchased our 30 Classic and we were going full time we bought a 1 ton Chev diesel so we would not ever experience that again.
PCJ is offline   Reply With Quote
Old 03-14-2019, 01:57 PM   #13
WaLee's Avatar
Nevada City , California
Iím pulling a 23 with 1/2 ton denali 6.2. It goes faster up mountains than I need to.
WaLee is offline   Reply With Quote
Old 03-15-2019, 06:24 AM   #14
2011 23' FB Flying Cloud
Boca Raton , Florida
Tv 1500
I have towed our 23 FB Flying Cloud all over the country from Florida to Canada and everywhere in between with my 2008 Tundra TRD. Zero problems. Proper hitch and stabilizer you're good to go!
bobgoldstein is offline   Reply With Quote
Can a 2002 Chevy Silverado 1500 Tow a 1976 31' AS Sovereign? seanfitz24 Tow Vehicles 8 02-12-2015 09:11 AM
Silverado 1500 w. 6.2, 403hp gas? Howard L. Tow Vehicles 8 07-17-2012 07:38 PM
2012 Chevy Silverado 1500 Brake Controller Wiring AirHeadsRus Brakes & Brake Controllers 9 11-20-2011 05:20 PM
TV for '08 25' Safari - Silverado 1500 or 2500? Roamin Cat Tow Vehicles 25 03-24-2008 06:34 AM
Towing capacity of a Chevy Silverado 1500 luca_brasi Hitches, Couplers & Balls 11 10-03-2007 09:07 PM
