Originally Posted by jrevering
Help!
I have a 2012 GL350 and just purchased a 2012 19' International. I have he factory tow kit installed. Whenever I plug the 7-Way connector in the LED lights are slightly dim and the break lights or turn signals don't work. I hear there is a compatibility issue with the MB and the LED lights? Anyone have any ideas on what I can do? Also, do I need a tow break control or will the factor tow kit be sufficient?
Thanks!
It is a known resistance issue between the AS's LED's and the GL's LED's (apparently there is none, or something to that effect).
However there is a fix! Go to your VW parts store and explain your problem. They will sell you a short cable (about two feet) with built in resistance and plug that cable into the GL's 7 pin, and then into your AS's. The problem will magically go away. The cost of the cable from VW is approx. $40.
