Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 03-09-2019, 03:55 PM   #1
Boise , Idaho
Towing 16' Sport
Hey everyone, I am picking up a new 16' Sport this weekend and have a question on sway control.
My tow vehicle is a 2009 Dodge Ram 1500. It weighs around 5,700 lbs. The Bambi weighs about 3,500 lbs.
I have decided that I will probably be okay without weight distribution. But sway control could be a good idea. Does anyone have any recommendations on easy sway control set ups that don't require WD?
This is what I have found so far: https://www.etrailer.com/p-83660.html
Thanks!
James3344 is offline   Reply With Quote
Old 03-09-2019, 04:05 PM   #2
2019 23' Flying Cloud
Waterford , New York
My 1500 Ram is rated to tow 8000. It is 4wd and diesel, the towing capacity of the 2wd gasser is more. What does your owners manual say?
Larry1492 is offline   Reply With Quote
Old 03-09-2019, 04:16 PM   #3
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
Thanks!
You can get a friction sway damper for less than $50 on Amazon. But if you load your trailer so that you have at least 10% of its weight on the tongue then you wont need it.
out of sight is offline   Reply With Quote
Old 03-09-2019, 07:05 PM   #4
Liquid Cooled
RedSHED's Avatar
2017 27' Flying Cloud
near Indy , Indiana
We pulled ours bare ball with 2014 Ram 1500. It was fine.
Here's us about 1/3 the way back from Maine near Albany with that combination.
http://www.airforums.com/forums/f42/...ml#post1724633
RedSHED is offline   Reply With Quote
Old 03-09-2019, 07:10 PM   #5
2019 22' Sport
Another option for sway control is the electronic sway control that plugs into your 7 pin and senses sway and applies brakes.
https://www.etrailer.com/Weight-Dist...SABEgLQEvD_BwE
Most definetly don’t need weight distribution for that setup unless the scales say otherwise
Kanusport is offline   Reply With Quote
Towing 19ft Bambi with 2009 Tacoma v6sr5 w towing package Shany Tow Vehicles 6 07-03-2017 10:44 PM
Avoiding Chicagoland while towing? EZ-Pass when towing? JustSomeGuy On The Road... 86 04-24-2015 10:33 PM
Sprinter one-ton towing/non-towing hwy mpg? gecko Tow Vehicles 18 08-02-2014 10:57 PM
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
