Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 03-08-2008, 08:28 PM   #15
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
Originally Posted by On Air
I was surprised that my milage went way down while towing, but I didn't use it except for week-ends and vacations.
This is something we all see....all too common a tale.
I found the closer I traveled to 55mph, the better the mpgs were. I typically travel at 62mph and on the flatland, get between 12-13 depending on headwinds. A good tail wind can get me slightly above 13mpg...but before you Honda folks flip out, keep in mind I've got a 6.0L, nearly 2x that of the Honda V6. I clearly did not get a Greenpeace sticker when I bought the Burb, but ironically, I found an honorary membership card to OPEC. At over $3/gallon, to fill at 39 gallon tank, with the stated observed MPG, you can clearly see why OPEC loves me, as does Exxon Mobil....I must have contributed .5% to their gross profits last quarter.
Old 03-08-2008, 08:35 PM   #16
1978 Soverign
greg_n_sam's Avatar
Profile:  1978 31' Sovereign
Gatlinburg , Tennessee
Images: 11
Here is a hint to the wise from a former owner and accident victim of trailer sway with a 2000 Honda Passport..... Similar SUV as yours... pulling a 16' UHaul trailer...
Sunny summer day mid afternoon, One of the tires must have been low and the trailer began to sway big time at 50 miles per hour. Within seconds the trailer became uncontrollable and swung my suv around like noodle. Next thing I remember is laying on the ground and seeing my truck laying on its side.
If you are going to pull anything with your honda, you need sway protection. The tow package of the honda vehicals ... well, downright blow arse. So, a word to the wise... If you are gonna tow with this vehical, please, please, please install a different weight distribution system and incorporate a good anti-sway system such as a Hensley Arrow...
Good luck and I hope all goes well for you.
greg_n_sam is offline   Reply With Quote
Old 03-09-2008, 11:14 AM   #17
Wayward's Avatar
Cary , North Carolina
A 12' open-frame U-Haul weighs in at 2500lbs, empty, has no sway control and surge brakes. Throw in some unbalanced cargo and I would consider that a far more difficult towing configuration for a Passport to deal with than, a Pilot hooked up to 2800lb Bambi with electronically controlled brakes and a sway bar.
Hensley is an excellent product but, especially for a lightweight Bambi, there are other extremely effective anti-sway devices you could consider, for a fraction of the Arrow's price.
The Pilot/Bambi can be easily set up as a safe towing combination.
..............Scott
2006 Safari SE FB
2000 F150 4.2L
Raleigh, NC
Old 03-09-2008, 12:52 PM   #18
georgezink's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Lawrenceville , Georgia
Ditto Scott!
Articulate and well thought out response...
I might add - check out the reliability on the Pilot transmission - outstanding (per Consumer Reports rankings). Also, no comparison between a Passport and a Pilot...
flcracker
georgezink is offline   Reply With Quote
Old 03-09-2008, 02:23 PM   #19
1978 Soverign
greg_n_sam's Avatar
Images: 11
Very true georgezink and Wayward.... Just thought I would add a little of what is possible when towing anything... Even though Airstreams pull better than most anything out there, it is always better to be safe than sorry..
But, I am a new owner as well... and am still a bit afraid of towing anything behind any vehical. Honda's just have a sour tast in my mouth still I guess.
Old 03-10-2008, 10:14 AM   #20
Profile:  Blue Mounds , Wisconsin
Ok, I am quite confused now, but if I install an Equalizer hitch on the 16' DWR and hitch it up to the Pilot with the Honda tow package- which includes the transmission cooler, etc. and I am very careful about the load in the trailer and the Pilot? Am I missing anything- would this be a safe way to begin?
We have a Tacoma- older one, not a great tow vehicle at all- it is the farm chore truck here. I suppose if the Pilot didn't work out I could trade that one in for the newer V6 Tacoma- I think they have 6500lb tow ratings now.
kestrel1651 is offline   Reply With Quote
Old 03-10-2008, 11:10 AM   #21
1 Rivet Short
Profile:  1989 25' Excella
By The Bay , Rhode Island
Yikes!
I cannot recall one of these tales of (near) tragedy on this forum that does not involve a short wheel base SUV (or overloaded ½ ton, Gardenofjoy’s experience comes to mind).
kestrel; Why on earth would you want to “pack carefully” and risk your loved ones (be they 2 legged or four) by trying to tow with a vehicle loaded to it’s max capacity (or beyond). You are doing quite a bit of traveling- 18 trips/year?
I do not believe you can even put a WD hitch on a unibody vehicle (there are other posts here that address this).
There is lots of advice/opinions on this site. Not all if it is sound.
No one here has ever commented that they had too much TV.
Good luck, be safe.
Bill
Life is Good-Camping all around New England
Good people drink good beer-Hunter S Thompson
BillTex is offline   Reply With Quote
Old 03-10-2008, 02:15 PM   #22
Thanks for your concern Bill. The thing is- I am not the least bit interested in putting my 2 or 4 legged loved ones, myself, or anyone else on the road at risk- that is why I am asking these questions in hopes that those of you with more knowledge can direct me. The dealer I spoke to when I looked at the unit informed me that it would be "absolutely no problem" to tow the DWR behind my Pilot, but I suspected that he was more interested in the sale than the safety, although he would certainly have known more about towing an Airstream than I. (Hence, the confusion and questions.)
So, what I meant by "packing carefully"- would be carefully distributing my essentials in the Airstream, maybe not towing with full tanks or extra batteries, leaving my 300lb olympic weight set at home, etc. (so as not to exceed the weight limits) and using the safest hitch set up available for the Pilot (it is still not clear to me what that would be.)
If it's not possible to do it safely, then I'll stick wth my T@b until I can afford to purchase a more substantial TV, rather than adding another tale of tragedy to the forum.
Old 03-10-2008, 02:21 PM   #23
1 Rivet Short
I think a good part of your motivation is to have more space and amenities; full water tank, a bathroom, dog cages, etc. Leaving most of your "stuff" at home is not really travelling in style.These all add up to weight. You may be able to do that with the right new AirStream (as noted above 3500#? or one of the Vintage units-much lighter). You would not want to try the 4500# unit.
The last thing I want to do is discourage you from AS's. We would rather you pursue them safely.
Hope this helps narrow your search.
Bill
Old 03-10-2008, 03:04 PM   #24
I did not find your posts discouraging in the least.
Thanks.
Old 03-10-2008, 04:17 PM   #25
bocotim's Avatar
Profile:  2006 16' International CCD
Boulder , Colorado
Upgrading from a Tab
Any thoughts on towing a 16' Bambi ....I tow a small T@b trailer at the moment with no problem,.... I'd like to upgrade to the 16' Airstream, but I'd like to keep the Pilot. Thanks.
Hi Kestrel,
For what it's worth and as another 'data point': I too owned a Tab camper, and although I loved that little trailer and used it on many trips, I recently (3 weeks ago) upgraded to a 16' Bambi (3500 lb GVWR). I also upgraded my tow vehicle from a mid-size SUV, Nissan Xterra with a 5000 lb tow rating, to an '06 Nissan Frontier (6100 lb tow rating) even though a local Airstream salesman assured me the Xterra would do the job. I really wanted to keep it, but folks on this group and others convinced me to get something with a longer wheel base and lower center of gravity for safety reasons.
I am sure there are better TVs out there than a Frontier, but my experience has been that it is adequate for the job, and probably safer than the Xterra. It gives me some peace of mind knowing this, and I enjoy the towing experience more (which for me is a big part of owning and using a trailer). I pulled the Bambi from Albuquerque to Denver over an 8000' pass with no issues (Camper was not fully loaded though, and I had a WD hitch and sway bars). Still need to test it out on higher passes, but so far so good.
Best of luck on your decision!
Tim
Boulder, CO
bocotim is offline   Reply With Quote
Old 03-10-2008, 04:59 PM   #26
2airishuman's Avatar
Profile:
boco kestrel and others...
your frontier does have a longer wheelbase, which is a plus.
but the suspension on the pilot is MUCH better dynamically.
there are LOTS of ways to to get from point a 2 point b...
http://www.airforums.com/forums/f238...ent-19446.html
http://www.airforums.com/forums/f238...-ii-21000.html
there are happy folks here towing bambi with 'yota hilanders, which are a t@d bit smaller than the honda...
http://www.airforums.com/forums/511004-post21.html
http://www.airforums.com/forums/f238...rid-28016.html
http://www.airforums.com/forums/f463...mbi-30715.html
but bad things can happen EVEN with big detroit iron on the nose.
http://www.airforums.com/forums/f238...rol-17986.html
so it pays to do your homework and include a margin of safety...
and remember always that....
replies vary here by who's reading, who's willing to jump in, and finding folks ACTUALLY using the specific combo...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 03-11-2008, 05:28 AM   #27
Wayward's Avatar
That sums it up. Looks like you can tow well within the Honda and Airstream specs. I shared your confusion when I started out on the boards - lots of opinions to digest so, I just look at the specifications the OEM engineers provide.
There are alot of well intentioned "scared safe" stories - unfortunately they end up scaring many people off before they take the time to do the math. Just post back if you want more help with the load calculations.
A Bambi/Pilot looks like a comfortable, capable and fuel efficient rig that should give you a great start to Airstreaming! The biggest safety factor is behind the wheel.
........Scott
2006 Safari SE FB
2000 F150 4.2L
Raleigh, NC
Old 03-11-2008, 06:40 AM   #28
Profile:  2008 25' International CCD
St. Pete Beach , Florida
I am confused about the Honda Odyssey being such a great tow vehicle. I have one and was told that they are built as passenger vehicles, not tow vehicles. In order to put a tow hitch on it, you have to add a complete tow package or some warranties will not no longer be in effect. I was steered away from towing with the odyssey by my dealer.
SurfinSuz
salvarez is offline   Reply With Quote
Bambi 16' towing woes unclemax 2007 Bambi all models 27 01-10-2009 01:08 AM
Towing with a Honda Ridgeline? lloydnc Tow Vehicles 9 11-19-2007 08:24 AM
Towing with a Honda Ridgeline air19 Tow Vehicles 17 10-26-2006 11:58 PM
16' Ccd & 16' Bambi Ron Edwords Waste Systems, Tanks & Totes 2 03-27-2006 12:30 AM
Towing 16' Bambi to Alaska soarfeat Member Introductions 13 01-24-2006 11:09 AM
