Old 09-19-2007, 07:58 PM   #1
Registered User
coo978's Avatar
Murfreesboro , Tennessee
Images: 8
Towing 13000#s
I traded for 2002 model 5th wheel, with 3 slides, tri-axle and 35', it weighs in at approximately 13000#s and is more like a house trailer than a camper.
I traded for it and have no idea how to tow anything this big, plus its a 5th wheel. I've towed our 31' Soverign, but never a 5th wheel. I'm not sure if I'm keeping it or selling it, but if I keep this beheamoth what am I going to tow it with??? I don't own a truck.
coo978 is offline   Reply With Quote
Old 09-19-2007, 08:06 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
You need a rock solid 1 ton pickup, equipped for towing such a large contraption.
This is why God made someone make diesel duallies. One of the rare cases where those are actually handy to have.
Uwe
www.area63productions.com
Old 09-19-2007, 08:17 PM   #3
Registered User
coo978's Avatar
Images: 8
Beheamoth
Oh, in case your wondering why I traded for this thing, it was part of a package deal....
Old 09-25-2007, 11:09 PM   #4
2007 25' Safari SS SE
Alton , Illinois
When you say 13,000 lbs., if thats fully loaded than a 1 ton diesel will probably handle it but if thats empty and you have to add water, food, stuff and people you are now in F450 or ton and a half territory and you'll need a 16K hitch or so. I would err on the side of caution and get an F450 or better yet a Chevy Kodiak 4500. I had a 30' 5th wheel. It was a happy day when I sold it. The AS was night and day better.
The "Ann Rutledge"
Brad Hunt is offline   Reply With Quote
Old 09-25-2007, 11:41 PM   #5
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
It will be much cheaper to sell it than buy a tow vehicle.
Myself, I would never consider pulling something that heavy. My house is on a foundation and that is the way it is suppose to be.
A friend of mine had one, still does, and he towed with a 3500 turbo dually. He had the transmission oil tested at about 48,000 and the wear particles in the fluid showed excessive wear. That's why I would never want a used turbo diesel. You can't tell how heavy it has pulled. And if it has, it is only a matter of time until you need a transmission.
wingfoot321 is offline   Reply With Quote
Old 09-26-2007, 07:18 AM   #6
LJH
LJH's Avatar
1985 27' Sovereign
Defiance , Ohio
Sell it, or park it at the lake. LJH 6196
LJH is offline   Reply With Quote
Old 10-02-2007, 10:46 PM   #7
DFord79's Avatar
Yakima , Washington
https://www.fleet.ford.com/showroom/...08_default.asp
Fact of the matter is you can tow that 13,000# 5th wheel with a Ford 3/4 ton properly equipped. The proof is in the towing guide. YOU be the judge. The link is to Fords towing guide.
DFord79 is offline   Reply With Quote
Old 10-03-2007, 04:34 AM   #8
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
The pin weight of a fiver is 18-22% or more of the total weight. That's 2,340 - 2,860 pounds in the bed, plus the weight of the hitch. I've had 2,300 pounds of roofing in the bed of our F250 (same springs as the SRW F350), and one end of the auxiliary springs was just beginning to touch the stops. To me, that's absolute max bed weight, where you have a limited amount of suspension travel left.
What the towing guide doesn't tell you is about the stability. Just as a conventional hitch puts the tongue weight behind the axle and can yaw the tow vehicle, a fiver puts the load above the axle, where it influences the tow vehicle in the roll plane. Even an F350 dually will have MUCH more stability towing a fiver than an F250. I've delivered them with both SRW and DRW trucks and wouldn't own a big fiver without a dually.
Maurice
Old 10-03-2007, 04:51 AM   #9
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
one of those monsters parked next to me in mackinaw... it blocked out the sun from our campsite
boondockdad is offline   Reply With Quote
Old 10-10-2007, 04:43 PM   #10
2007 25' International CCD
Arlington , Virginia
At least you did not have to unroll your awning!
Streamer1 is offline   Reply With Quote
Towing behind an A/S Neophyte Towing, Tow Vehicles & Hitches 13 02-21-2006 08:57 PM
Help with towing Mom2abidrew Off Topic Forum 5 04-12-2004 03:02 PM
Towing - 1965 65trotter 1965 - 1969 Globetrotter 9 08-10-2003 09:19 AM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
Towing COArgosy78 1965 - 1969 Overlander 5 09-05-2002 10:18 AM
