03-05-2016, 01:05 PM
1987 29' Sovereign
Atascadero
Towability of Classic with older Diesel
My wife and I are considering purchasing a newer (2007-2012) 27' Classic. We currently have a very nice 1987 29' Sovereign. My main concern is the impact on towing of the added weight of the Classic. The Unit Base Weight of the Classic is 6592# and the Sovereign is 5300#. Our tow vehicle is a 2002 Chevy Duramax--it's in excellent condition with only 200K miles. However, that generation Duramax has less power (300hp and 520 lb-ft torque) than newer versions but we do not want to also purchase a new tow vehicle. I would appreciate input on the impact of the added weight on this tow vehicle--should I be concerned? And, are the features of the Classic worth the added weight. Thanks
Steve
03-05-2016, 01:25 PM
Princeton
, New Jersey
You might call John at Kennedy diesel and ask the question. If there is a limit to your truck, and I doubt there is, he will be able to tell you how to overcome it. That engine is not even broken in yet.
www.kennedydiesel.com
2004 Excursion 4x4
03-05-2016, 01:38 PM
2013 31' Classic
billings
, Montana
It will handle the classic with no problems, just drive it....
03-05-2016, 02:11 PM
Oswego
You're fine.....and I do think the Classic is worth the weight.
-Rich-
03-05-2016, 03:13 PM
1998 30' Excella 1000
Livingston
My Classic weighs in at 7600 lb when loaded for towing. I pulled all through the West for 16 years with a Ford 5.4L with 235 HP and 330 Torque. I did slow down on steep, high elevation passes, but you'll obviously do better. You'll be fine.
1994 34' Excella
Warren
, Manitoba
I pull our 1994 34' with a 2002 Duramax 4X4 extended cab and have no problems. Ours gets better mileage than most of the newer Duramax models, and have no problems with any hills we have encountered. It would be nice to have the newer model with the exhaust brake. Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
03-05-2016, 11:52 PM
1987 29' Sovereign
Atascadero
Thanks everyone for the feedback--I'm really looking forward to trying out the Classic. To experiment, today I filled all three tanks of my Sovereign and drove up a long 6%/7% grade and the cruise control held 60mpg--only about 2 mpg less than with the tanks empty. I agree, the weight of the Classic will not be an issue. Thanks again.
03-06-2016, 11:11 AM
1996 34' Excella
Elberta
, Alabama
You won't have a problem, mine TV is a 2003 Dodge/Cummins, with 115K miles, of which about 100K of that has been towing our 30' Excella, and more recently our 34' Excella.
Regardless of what some people say about it "not even broke in yet", my truck, and your also, are well broke in, and should be just fine for at least double, or triple the mileage we currently have on the trucks, and that's a good thing.
The main thing is, we don't owe any money on them, and we don't have to brag about driving a $65,000, to $75,000 truck.....and that is a really good thing..
Larry C
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
03-06-2016, 11:44 AM
2003 31' Classic
Terra Alta
, West Virginia
What they all said.
Dave with 2002 7.3 and Classic 31. Just go
03-06-2016, 12:05 PM
ShinyPete
2014 27' Flying Cloud
Bushnell
Agreed here too, hook up and go with your '02 D'Max beast. We had an '03 like it that towed a 30' two slide SunnyBrook tt that was 9000 lb dry and super boxy and tall. You're gonna love that truck with any Airstream.
03-07-2016, 07:22 AM
2013 30' Classic
Greenwood
, Mississippi
Your truck will do fine.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
03-07-2016, 01:37 PM
1990 32' Excella
jonesboro
, Arkansas
I tow a 90 32 excella with a 2003 duramax with 180000 miles. Pull mostly in hills and mountains without breaking a sweat. Enjoy the new rig.
03-09-2016, 04:22 PM
1999 34' Excella
Cinnaminson
, New Jersey
no problems. I tow a 34' (9800 lb gvw)with an 03 -F350 7.3.... 250HP and 525TQ and only a 4 speed auto. I set the cruise at 70 and let run. Piece of cake.
