Old 11-19-2015, 11:30 AM   #1
MACINRIC's Avatar
1977 29' Ambassador
Richmond , Virginia
Tow without a hitch? a 30 footer?
Does anyone out there regularly tow without a WD hitch? Seems like I can drive 55 under near perfect conditions and fair ok. However, it also looks like a WD hitch is quickly rising to the top of my Necessary list of acquisitions. Just behind a P3 break controller and ahead of the desired renovations. So for now, I have new tires and wheels will install the break controller, acquire a 9V battery and convert to LED's and plan to get a WD hitch ahead of a fixing or replacing the generator, functional plumbing, built in heating, stopping the few leaks and a full restore. oh that list.
MACINRIC is offline   Reply With Quote
Old 11-19-2015, 11:39 AM   #2
SteveH's Avatar
Common Sense , Texas
Just my opinion, but I wouldn't tow a 30 footer around the block without a properly setup WD hitch with anything short of a Kenworth. Also, I wouldn't tow it at all without a properly working brake controller.
However, some may consider me overly cautious.
Regards,
Steve
Old 11-19-2015, 11:50 AM   #3
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
I totally agree! Better safe then sorry
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 11-19-2015, 11:57 AM   #4
mandolindave's Avatar
Ditto what Macnric said
I meant to say what steve said
Also…..do you mean a 12 volt battery
About the WD hitch, besides the more important safety issues. Not having weight distribution will cause the rig to bob up and down, if you go over bumps or seams in the highway.
About brake controller. IT'S ILLEGAL to not have brakes on a trailer that is over 2000 lbs. ( laws vary state to state ) You are inviting a jack knife situation, and are endangering others on the road. Also your increased stopping distance could cause an accident as well.
mandolindave is offline   Reply With Quote
Old 11-20-2015, 01:35 PM   #5
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
definitely not 30 ft , but we drove the entire 11,000 mile round trip in two months , to Alaska and back using nothing but a 2.5/16 ball and a single sway bar .
Had a wonderful time with no problems or concerns whatsoever .
dannydimitt is offline   Reply With Quote
Old 11-20-2015, 02:53 PM   #6
PeterKV's Avatar
1985 25' Sovereign
Wichita Falls , Texas
There are a lot of things you can do, back in the 50's and 60's we pulled all kinds of trailers with only a plate bolted to a car bumper with a ball attached but back then we drove slower, dealt with much less traffic and did not know any better. Today most roads have heavy traffic going 70+ and we have numerous safety features we can take advantage of so why not be as safe as possible, I enjoy the road trips more when I am relaxed and not worried about getting a high speed wiggle or if I can safely stop.
PeterKV is offline   Reply With Quote
Old 11-20-2015, 03:08 PM   #7
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
What he said.....
PaulnGina is offline   Reply With Quote
Old 11-20-2015, 03:22 PM   #8
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Have a 30', have had another also and would never tow without a WD.
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 11-20-2015, 03:29 PM   #9
2000 30' Excella
2014 30' Classic
Princeton , Iowa
I have been pulling a 30' Classic for 5 yrs, half the time with WD hitch and half with out. I would never go back to a WD hitch. I have pulled almost 15,000 miles with out the hitch. Easy hook up, not heavy stuff to lift. Yes, going down hill in the wind at speeds over 65 you can have trouble. I do not go down hill in the wind at 65 miles per hour. It is true I am 73 years of age and I am not it a hurry.
Now I have not checked it out, but when it comes to Weight distribution there are 2 things. My ball is about 9 inches closer to the back of my truck so the weight of the trailer has less effect on the weight on my rear end. Two setting normal there is about 800 less weight on my rear end than front end. Now I add 750 lbs. from my trailer and my rear end is just a little heavier than my front end.
Ask the people who tow the trailers from the factory to the dealers, they do not use WD hitches.
larryglarson is offline   Reply With Quote
Old 11-20-2015, 03:42 PM   #10
Gainesville , Florida
I tow a thirty foot Avion with two sway controls and no WD. Of course I have a one ton truck. Anything less and I would use WD.
Old 11-20-2015, 03:45 PM   #11
1973 31' Sovereign
Middletown , California
I would go for good brakes way before a WD hitch! My 3/4 ton Chevy doesn't need anything other than a ball when towing my 31 footer although passing semi-trucks does cause a little lane wobble. I'm very curious if any hitch could fix the bow wave of a large truck pushing sideways on my trailer? The handling of every rig is different and there are many variables, the most important thing is being able to stop straight and quickly. Most rigs would probably benefit from a WD hitch but if you luck out on the way the tongue weight, hitch overhang, wheelbase and tire flex combines you might not need one. Leland
ijustlee is offline   Reply With Quote
Old 11-20-2015, 04:29 PM   #12
Center Moriches , New York
No SteveH, you're NOT overly cautious.
NY24 is offline   Reply With Quote
Old 11-20-2015, 04:37 PM   #13
2007 22' International CCD
Hensley design hitches or ProPride version flat eliminates the bow wave issue, the crosswind issues, and downhill heavy braking issues. Flat can't sway. I won't tow without one
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 11-20-2015, 04:38 PM   #14
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I do not if out on vacation with unloaded car. i do when loaded for festivals. I use a 3/4 ton and have Bambi.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Safe without the WD hitch for a interstate tow? BoldAdventure Hitches, Couplers & Balls 27 08-17-2014 09:45 AM
Towing with a Pilot without an equalizer hitch Globie64 Tow Vehicles 78 09-09-2013 10:54 AM
25-footer vs 30/31 footer fultime on the road kingfisher24 On The Road... 29 09-14-2010 11:06 AM
GREAT TRIP without a hitch! swanky Classic Motorhomes 11 08-04-2009 10:59 AM
