Old 08-04-2016, 08:03 AM   #1
Chicago , Illinois
Tow Vehicle - newbie
We are seriously considering buying a 2017 Classic J - GVWR 10000 - we, however, want a TV that can seat 6 - 4 adults and our two labs. Is it reasonable to think that we cd get a Yukon 2500 (used or new - retrofitted with a Duramax diesel) and it will be enough to tow all this - or is (1) the length of the cab going to be a problem in towing or (2) the weight of the passengers etc a problem?
SMWASONMYMD is offline   Reply With Quote
Old 08-04-2016, 08:19 AM   #2
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Check the payload sticker on the driver's door jamb. Then add at least 1000 lb tongue weight in addition to passenger/cargo weight.
That'd be a start.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 08-04-2016, 08:34 AM   #3
Chicago , Illinois
Thanks - and btw - if this makes any difference- I am going to get either a Hensley or Propride hitch.
Old 08-04-2016, 08:59 AM   #4
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
You are on the right track with the idea of a 2500 Duramax. As mentioned, figure out your expected weights and go from there.
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
Blessed and highly favored
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 08-04-2016, 10:15 AM   #5
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
You'll get differing opinions on whether the added weight of the hitch is considered tongue weight or not.
I'll just say that it's an undisputed fact that those hitches are significantly heavier than a standard Equalizer type hitch. That weight has to be accounted for somewhere.
Old 08-04-2016, 10:47 AM   #6
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
In my opinion, which is worth exactly what you paid for it, the differing opinions are due to imprecise definitions. Tongue weight is a parameter of the trailer. The actual tongue weight is applied to the WD hitch and the hitch has a spec for that. With WD not engaged, the tongue weight of the trailer and the weight of the hitch are applied to the ball. This weight should be compared to the tongue weight spec for the receiver. Most receivers have two tongue weight specs, one for pull and one for WD. The simplest way to determine compliance with the hitch receiver specs is to weigh the tow vehicle without the hitch or trailer, and then weigh the tow vehicle with the trailer hooked up and WD engaged. The difference in the two weights, assuming nothing else has changed (passengers, cargo, fuel level, etc.) is the weight applied to the receiver and should be less than the tongue weight spec for the hitch.
IMHO, YMMV, etc.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 08-04-2016, 11:00 AM   #7
PaulnGina's Avatar
Good Ol' , USA
IMHO, YMMV, etc.
Al
Al said it exactly how I would have said it if I could have figured out how to say it! 😀👍👌
PaulnGina
1987 Avion 34W
1987 Avion 34W
Old 08-04-2016, 12:02 PM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
How do 4 adults and 2 labs sleep in a Classic?
How much is a Duraburb?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-04-2016, 03:57 PM   #9
Chicago , Illinois
Another newbie question - what is WD?
Old 08-04-2016, 04:06 PM   #10
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Weight Distribution.
SeaLevel is offline   Reply With Quote
Old 08-04-2016, 07:48 PM   #11
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
___________________
We had an old 2500 4x4 GMC Suburban with the 7.4 L gas engine that towed well but they don't make it any more. All of the new Yukon/Suburban XL are half ton. The new gas 6.2 engine could probably tow the Airstream, and fit everyone in, but the cargo weight capacity is probably way short if you load gear behind the rear seats.
I don't think you can retrofit economically a Yukon XL with a Duramax/Allison combination as that puts great weight on the front axle, and you would wind up rebuilding at considerable expense, with new front and rear axles as well as the engine transmission combination, and all the computer electronics etc. Just forget about that idea. It would also void the warranty and might not be able to be certified in many states.
We went with a five passenger 2016 GMC Sierra SLT 2500 HD 4x4 CrewCab with a 6.5 box and a Leer custom topper wired so lock/unlock does the shell as well. We can get two very comfortably in the front buckets, and the rear seats, which fold, seat three and are very comfortable. If you have to have seating for six you could special order such a unit with a front bench seat that seats three, though not in luxury. How big are the 4 people? If two are small it might work.
+David
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 08-04-2016, 08:51 PM   #12
m.hony's Avatar
2013 30' Classic
I've often wondered why the key fob lock and unlock doesn't do the tailgate too...
TAC #MS-10
Airforums #70955
Old 08-04-2016, 09:08 PM   #13
ericpeltier's Avatar
Superior , Colorado
Related - GAAAAWD I want a full size non-german SUV with a honkin'-big diesel in it. The new Ford Superduty with 920ftlb of torque is making me insane.
OK, I'm done whining.
It's true, the tongue weight of a trailer that size will use up heaps of available payload.
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 08-04-2016, 09:21 PM   #14
Islamorada , Florida
I almost totally agree with dcasr, except my suggestion would be the new 2017 Ford F-350 Super Duty crew cab with the 6.7L PowerStroke diesel :-). 925 ft-lbs of torque should be awesome! I once did a retrofit of a small-block Chevy into a Toyota Landcuiser, and while it worked out fine, I remember always being a little anxious about getting too far away from the guy who did the work!
flycastr is offline   Reply With Quote
Old 08-04-2016, 11:38 PM   #15
Thiss's Avatar
1971 27' Overlander
Monmouth , Oregon
They do on the 2016 and newer Rams
I vote Ram Cummins Crew Cab
For the labs, a nice 2 Hole Mountain Top Custom Kennel. Insulated, locking doors, and Fantastic Fan for ventilation all makes happy cool/warm pups.
Happy shopping!
Thiss is offline   Reply With Quote
Old 08-05-2016, 05:44 AM   #16
RobH41's Avatar
1978 Argosy Minuet 6.0 Metre
Nashville , Tennessee
Our tow vehicle is an '06 GMC 2500HD with the YBZ series diesel. Now with close to 130k miles on it with no issues whatsoever. We tow a 25' Safari and 2 sailboats on occasion, with one weighing in at almost 12k. The Allison transmissions keep us in the GMC family and the Duramax engines are much quieter than the others. Ours is a crew cap with a short bed with a topper over the bed. Big back seat with good leg room.
RobH41 is offline   Reply With Quote
Old 08-05-2016, 06:44 AM   #17
2014 25' FB Flying Cloud
Hillsborough , North Carolina
Do Not exceed 80% of rated capacity
Another interesting point is that many threads recommend to not exceed 80% of rated Capacity.
The longer wheel base of the F-250 Super Crew 6.5' bed (or Chevy / Doge equivalent) will make a much more stable towing experience.
The short wheel base of a Yukon/Tahoe will make backing easier, but at a huge risk of less stability when towing.
Unless the Yukon 2017 is dramatically different than the 2016, you are no where near the towing capacity of a 10,000# Classic with only 8,100 towing capacity. Add in the 80% factor as a good rule, and it rules out the Yukon / Tahoe.
The previous thread that suggested the F-350 is a great idea. with 10,000# get all the truck you can.
GeeSag is offline   Reply With Quote
Old 08-05-2016, 06:47 AM   #18
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Full size van.
Old 08-05-2016, 06:54 AM   #19
m.hony's Avatar
2013 30' Classic
What about a 6 passenger crew cab truck with a sliding window and truck bed cap with fans for the labs?
TAC #MS-10
Airforums #70955
Old 08-05-2016, 06:56 AM   #20
m.hony's Avatar
2013 30' Classic
The full size vans aren't what they used to be unless you can get a Chevy Express/GMC Savana 2500 or 3500.
I still want to know where 6 people and 2 big dogs are going to sleep in a Classic...
TAC #MS-10
Airforums #70955
Tow Vehicle/STOW Vehicle for Full-Timers Foiled Again Full-Timing 13 06-28-2014 12:55 PM
Tundra as tow vehicle? (Newbie) zagarino Tow Vehicles 21 06-21-2011 05:55 PM
Newbie Request Feedback on Jeep Wagoneer as Tow Vehicle LiLNomad Tow Vehicles 16 07-21-2010 06:18 PM
Newbie Tow Vehicle Question: Ford Expedition Pinky65 Tow Vehicles 6 07-16-2010 09:31 PM
Newbie - Questions about tow vehicle goswick Tow Vehicles 6 02-08-2009 09:23 AM
